I booted without the cd and run it all went through did’nt return any errors looks like it done a lot of installing… I checked theres no sound but I think you expected that?
If it installed updates, apt and dpkg must be working…
Now to the sound card then… can you send the output from these 4 commands entered into a terminal:
sudo lshw -C multimedia
sudo aplay -l
cat /proc/asound/card0/codec#* | grep Codec
lsmod | grep snd
output
snd_hda_codec_idt 60537 1
snd_hda_intel 24113 2
snd_hda_codec 90901 2 snd_hda_codec_idt,snd_hda_intel
snd_hwdep 13274 1 snd_hda_codec
snd_pcm 80042 2 snd_hda_intel,snd_hda_codec
snd_seq_midi 13132 0
snd_rawmidi 25269 1 snd_seq_midi
snd_seq_midi_event 14475 1 snd_seq_midi
snd_seq 51291 2 snd_seq_midi,snd_seq_midi_event
snd_timer 28659 2 snd_pcm,snd_seq
snd_seq_device 14110 3 snd_seq_midi,snd_rawmidi,snd_seq
snd 55295 13 snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore 12600 1 snd
snd_page_alloc 14073 2 snd_hda_intel,snd_pcm
[sudo] password for theporter2000:
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: STAC92xx Analog [STAC92xx Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
Codec: SigmaTel STAC9227
And the other 2 commands ?
also… if this is a laptop, can you state the make/model.
theporter2000@theporter2000-desktop:~$ sudo umunt /mnt/natty/proc
sudo: umunt: command not found
theporter2000@theporter2000-desktop:~$ sudo umount /mnt/natty/proc
umount: /mnt/natty/proc: not found
umount: /mnt/natty: not mounted
NO… you only sent the output from 2 of these 4 commands -
sudo aplay -l
lsmod | grep snd
So I still need the output from:
2 questions…
a) If this is a laptop… what is the make/model ?
b) is this the same PC where we dealt with the sound issue here:
http://linuxforums.org.uk/general-help-advice/getting-sound-and-video/
no its a full size dell
yes I’ve only ever had one pc with linux
sorry I must have missed that my fault
theporter2000@theporter2000-desktop:~$ sudo lshw -C multimedia
-multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
vendor: Intel Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
version: 02
width: 64 bits
configuration: driver=HDA Intel latency=0
resources: irq:47 memory:50420000-50423fff
theporter2000@theporter2000-desktop:~$ cat /proc/asound/card0/codec# | grep Codec
Run this command:
gedit /etc/modprobe.d/alsa-base.conf
when gedit opens, see if there is a line that reads:
options snd-hda-intel model=ref
towards the bottom, and let me know.
no there is no line like that
OK, run:
sudo gedit /etc/modprobe.d/alsa-base.conf
When gedit opens, add a NEW LINE at the bottom that reads:
Now run:
sudo alsa force-reload
is your sound now working ?
autoloader aliases
install sound-slot-0 /sbin/modprobe snd-card-0
install sound-slot-1 /sbin/modprobe snd-card-1
install sound-slot-2 /sbin/modprobe snd-card-2
install sound-slot-3 /sbin/modprobe snd-card-3
install sound-slot-4 /sbin/modprobe snd-card-4
install sound-slot-5 /sbin/modprobe snd-card-5
install sound-slot-6 /sbin/modprobe snd-card-6
install sound-slot-7 /sbin/modprobe snd-card-7
Cause optional modules to be loaded above generic modules
install snd /sbin/modprobe --ignore-install snd $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-ioctl32 ; /sbin/modprobe --quiet --use-blacklist snd-seq ; }
Workaround at bug #499695 (reverted in Ubuntu see LP #319505)
install snd-pcm /sbin/modprobe --ignore-install snd-pcm $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-pcm-oss ; : ; }
install snd-mixer /sbin/modprobe --ignore-install snd-mixer $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-mixer-oss ; : ; }
install snd-seq /sbin/modprobe --ignore-install snd-seq $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; /sbin/modprobe --quiet --use-blacklist snd-seq-oss ; : ; }
install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq-midi ; : ; }
Cause optional modules to be loaded above sound card driver modules
install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-emu10k1-synth ; }
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist snd-seq ; }
Load saa7134-alsa instead of saa7134 (which gets dragged in by it anyway)
install saa7134 /sbin/modprobe --ignore-install saa7134 $CMDLINE_OPTS && { /sbin/modprobe --quiet --use-blacklist saa7134-alsa ; : ; }
Prevent abnormal drivers from grabbing index 0
options bt87x index=-2
options cx88_alsa index=-2
options saa7134-alsa index=-2
options snd-atiixp-modem index=-2
options snd-intel8x0m index=-2
options snd-via82xx-modem index=-2
options snd-usb-audio index=-2
options snd-usb-caiaq index=-2
options snd-usb-ua101 index=-2
options snd-usb-us122l index=-2
options snd-usb-usx2y index=-2
Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
Keep snd-usb-audio from beeing loaded as first soundcard
theporter2000@theporter2000-desktop:~$ sudo alsa force-reload
lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
Output information may be incomplete.
Terminating processes: 1386lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
2331lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
2346lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
2361lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
(with SIGKILL:) 2376lsof: WARNING: can’t stat() fuse.gvfs-fuse-daemon file system /home/theporter2000/.gvfs
(failed: processes still using sound devices: 2391(pulseaudio)).
/sbin/alsa: Warning: Processes using sound devices: 2391(pulseaudio).
Unloading ALSA sound driver modules: snd-hda-codec-idt snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-timer snd-seq-device snd-page-alloc (failed: modules still loaded: snd-hda-codec-idt snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-timer snd-page-alloc).
Loading ALSA sound driver modules: snd-hda-codec-idt snd-hda-intel snd-hda-codec snd-hwdep snd-pcm snd-seq-midi snd-rawmidi snd-seq-midi-event snd-seq snd-timer snd-seq-device snd-page-alloc.
WHAT ARE YOU DOING ?
That’s twice now you’ve double posted, and I’ve had to remove the duplicates.
Nor did I ask for any output in my last posting… READ IT AGAIN.
I’ve cleary got lost sorry, please can you tell me again so I get the wright one, but it will have be tomorrow night now sorry again
OK, let’s do this a different way…
Open a terminal, and enter:
sudo cp -v /etc/modprobe.d/alsa-base.conf /etc/modprobe.d/alsa-base.conf.bak
Hit enter, and your password when asked.
Now enter:
sudo sh -c "echo options snd-hda-intel model=ref >> /etc/modprobe.d/alsa-base.conf"
Hit enter, and your password if/when asked.
Now REBOOT.
When your PC restarts, does your sound work ?
ubuntu@ubuntu:~$ sudo cp -v /etc/modprobe.d/alsa-base.conf /etc/modprobe.d/alsa-base.conf.bak
/etc/modprobe.d/alsa-base.conf' ->
/etc/modprobe.d/alsa-base.conf.bak’
ubuntu@ubuntu:~$ sudo sh -c “echo options snd-hda-intel model=ref >> /etc/modprobe.d/alsa-base.conf”
ubuntu@ubuntu:~$
it did’nt ask me for a password or to hit enter at any time?
You’re not doing this from the LiveCD are you ?
Yes I was should have relised with you saying paswd sorry!
I’ve run it again through the hard drive heres the output
theporter2000@theporter2000-desktop:~$ sudo cp -v /etc/modprobe.d/alsa-base.conf /etc/modprobe.d/alsa-base.conf.bak
theporter2000@theporter2000-desktop:~$ sudo sh -c “echo options snd-hda-intel model=ref >> /etc/modprobe.d/alsa-base.conf”
theporter2000@theporter2000-desktop:~$ It wasn’t working at first then I rebooted now it dos thank you
No problem
