hye guys,i wanted to set baudrate,data bit,partity bit, start bit, and stop bit in MINICOM, how can i do that? please lend me your idea guys. thanks
minicom -s => Serial Port Setup => E (eg; 9600 8N1) => Save setup as dfl => Exit .. this will deposit you into a terminal session ..
I guess I’m showing my age now …
tq so much…if i’m not using minicom, how can i set all these in terminal?
Erm, depends on what you mean by ‘terminal’ ?!
Do you mean you have an old-style serial console and you’re trying to log that on to a serial line ??
If so, check out /etc/init for files tty?.conf, which look something like this;
# tty1 - getty
# This service maintains a getty on tty1 from the point the system is
# started until it is shut down again.
start on stopped rc RUNLEVEL=[2345] and (
not-container or
container CONTAINER=lxc or
container CONTAINER=lxc-libvirt)
stop on runlevel [!2345]
respawn
exec /sbin/getty -8 38400 tty1
If you want to add a serial line, create a file called ttyS0 (for example, serial console 0) and change the last line as appropriate. You can get more detail re; stop bits / parity etc from “man getty”.
To activate the file do;
initctl reload ttyS0
i’m not quite familiar with getty but it seems interesting, but how do i configure the data bits value, parity bits, start/stop bits, and baudrate using it? and how to send command to the serial port also?
Try “man getty” for details (!)
