Hi.
I start Python course.
Now I have that a problem.
I try find something but still is that same.
Please help, thanks.
I using with fresh updates:
5.19.0-35-generic #36~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Fri Feb 17 15:17:25 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
pip3 install PySide6
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: PySide6 in ./.local/lib/python3.10/site-packages (6.4.3)
Requirement already satisfied: shiboken6==6.4.3 in ./.local/lib/python3.10/site-packages (from PySide6) (6.4.3)
Requirement already satisfied: PySide6-Essentials==6.4.3 in ./.local/lib/python3.10/site-packages (from PySide6) (6.4.3)
Requirement already satisfied: PySide6-Addons==6.4.3 in ./.local/lib/python3.10/site-packages (from PySide6) (6.4.3)
type or paste copython3 -m pip install “SomeProject”
ERROR: Could not find a version that satisfies the requirement SomeProject (from versions: none)
ERROR: No matching distribution found for SomeProject
python3 -m pip install “SomeProject==1.4”
ERROR: Could not find a version that satisfies the requirement SomeProject==1.4 (from versions: none)
ERROR: No matching distribution found for SomeProject==1.4
python3 -m pip install “SomeProject>=1,<2”
ERROR: Could not find a version that satisfies the requirement SomeProject<2,>=1 (from versions: none)
ERROR: No matching distribution found for SomeProject<2,>=1
python3 -m pip install “SomeProject~=1.4.2”
ERROR: Could not find a version that satisfies the requirement SomeProject~=1.4.2 (from versions: none)
ERROR: No matching distribution found for SomeProject~=1.4.2
pip install PySide6
python setup.py install --qtpaths=/path/to/bin/qtpaths6 --parallel=8 --build-tests
Command ‘python’ not found, did you mean:
command ‘python3’ from deb python3
command ‘python’ from deb python-is-python3
