fdisk -l =
Disk /dev/sda: 160.0 GB, 160040803840 bytes
255 heads, 63 sectors/track, 19457 cylinders, total 312579695 sectors
Disk identifier: 0x000204fb
/dev/sda1 * 63 312560639 156280288+ 7 HPFS/NTFS/exFAT
/dev/sda2 312560640 312576704 8032+ 5 Extended
/dev/sda5 312560703 312576704 8001 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 40.0 GB, 40019582464 bytes
255 heads, 63 sectors/track, 4865 cylinders, total 78163247 sectors
Disk identifier: 0x0005d6c2
/dev/sdb1 * 2048 61388799 30693376 83 Linux
/dev/sdb2 61390846 78161919 8385537 5 Extended
/dev/sdb5 61390848 78161919 8385536 82 Linux swap / Solaris
Disk /dev/sdc: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders, total 156301488 sectors
Disk identifier: 0xb4b3b4b3
/dev/sdc2 * 16065 156296384 78140160 5 Extended
/dev/sdc5 16135 20482874 10233370 7 HPFS/NTFS/exFAT
/dev/sdc6 20482939 156296384 67906723 7 HPFS/NTFS/exFAT
gedit boot/grub/grub.cfg =
DO NOT EDIT THIS FILE
It is automatically generated by grub-mkconfig using templates
from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default=“0”
if [ “${prev_saved_entry}” ]; then
set saved_entry=“${prev_saved_entry}”
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z “${boot_once}” ]; then
saved_entry=“${chosen}”
fi
function recordfail {
set recordfail=1
if [ -n “${have_grubenv}” ]; then if [ -z “${boot_once}” ]; then save_env recordfail; fi; fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root=‘(hd1,msdos1)’
search --no-floppy --fs-uuid --set=root 356591ee-d91d-4187-ba86-4119ed52848b
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=en_GB
insmod gettext
fi
terminal_output gfxterm
if [ “${recordfail}” = 1 ]; then
set timeout=-1
else
set timeout=10
fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/06_mint_theme
set menu_color_highlight=white/light-gray
END /etc/grub.d/06_mint_theme
BEGIN /etc/grub.d/10_linux
function gfxmode {
set gfxpayload=“$1”
if [ “$1” = “keep” ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ “$linux_gfx_mode” != “text” ]; then load_video; fi
menuentry ‘Linux Mint 13 Cinnamon 64-bit, 3.2.0-23-generic (/dev/sdb1)’ --class linuxmint --class gnu-linux --class gnu --class os {
recordfail
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.2.0-23-generic root=UUID=356591ee-d91d-4187-ba86-4119ed52848b ro quiet splash hpet=force clocksource=hpet $vt_handoff
initrd /boot/initrd.img-3.2.0-23-generic
menuentry ‘Linux Mint 13 Cinnamon 64-bit, 3.2.0-23-generic (/dev/sdb1) – recovery mode’ --class linuxmint --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
echo ‘Loading Linux 3.2.0-23-generic …’
linux /boot/vmlinuz-3.2.0-23-generic root=UUID=356591ee-d91d-4187-ba86-4119ed52848b ro recovery nomodeset
echo ‘Loading initial ramdisk …’
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/10_lupin
END /etc/grub.d/10_lupin
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
menuentry “Memory test (memtest86+)” {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin
menuentry “Memory test (memtest86+, serial console 115200)” {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
if [ “x${timeout}” != “x-1” ]; then
if keystatus; then
if keystatus --shift; then
set timeout=-1
else
set timeout=0
fi
else
if sleep --interruptible 3 ; then
set timeout=0
fi
fi
fi
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the ‘exec tail’ line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
END /etc/grub.d/41_custom
Long, isn’t it?
Thanks for your help Mark
Tony N
