I was just wondering if it is at all possible to create a dual/multi boot USB Stick with various OS’s on it such as Ubuntu, Mint, Peppermint and have the option/choice of which one to try/install?
Thanks a billion Mark, that’s fantastic.
If you get stuck installing MultiSystem … let me know.
It allows you to add ISO images to the USB stick directly (ie. without having to be unpacked and “burned”) … it even supports booting Win7 and XP CD/DVD images (obviously those can only be used for installation) … Linux distros can be used in Live mode as well as installation media.
That’s great, however - I do have an XP Pro install CD but not a WIN7 one, any ideas on how I can obtain one? as I’d like to see if I can get to grips with WIN7 as we got a Toshiba lappy with a dead HD in it and was going to get it fixed and make it a dual/multi boot with Ubuntu/XP/WIN7/other.
Buy one … you don’t expect me to condone or discuss piracy do you ?
This is a Linux forum … so a bit of an odd question really … I was pointing out it could be done, not offering to help with Windows.
I charge for Windows assistance
That’s what I was asking, ‘is the only way I can get one is from a shop’
I’ve downloaded the multi boot iso and I’m reading some mention of something called ‘plop’
Do I need to download it or just ‘burn’ multi boot to the USB?
Install and run the application … if you need to add the XP iso … it should download/install plop for you.
IIRC, PLoP is only necessary for windows images … but it installs it for you anyway.
ta.
And re your next to last post, i know you was (only offering advice)
This may contain sommat useful … I haven’t really had much use for MultiSystem for a while, so haven’t played with it much lately.
http://linuxforums.org.uk/index.php?topic=4032.msg28882#msg28882
I’m having a problem getting the multiboot.iso on the USB as Brassero cant see the USB? What can I use?
No … add the repo, then install MultiSystem on your Linux PC (not to a CD/DVD)
First make sure zenity and xterm are installed:
sudo apt-get install zenity xterm
Then add the MultiSystem repo and key, then install multisystem … by running:
sudo apt-add-repository 'deb http://liveusb.info/multisystem/depot all main'
wget -qO - http://liveusb.info/multisystem/depot/multisystem.asc | sudo apt-key add -
sudo apt-get install multisystem
You’ll then find MultiSystem in your menus somewhere
Also, read the link in my last response.
Sorry, from how I understood it on the site you pointed me to was that I downloaded the .ISO and put it on the USB Stick!
Got a problem with it…
pooky2483@pooky2483-ubuntu12:~$ sudo apt-add-repository ‘deb http://liveusb.info/multisystem/depot all hand’
[sudo] password for pooky2483:
pooky2483@pooky2483-ubuntu12:~$ wget-q-O-http://liveusb.info/multisystem/depot/multisystem.asc | sudo apt-key add -
bash: wget-q-O-http://liveusb.info/multisystem/depot/multisystem.asc: No such file or directory
gpg: no valid OpenPGP data found.
2 secs … testing
I’ve fixed the instructions above (for anyone else hat follows them)
But there’s another method of installing it below.
While you wait … make sure these are installed:
Once you’ve installed the 2 packages in my last posting … post the contents of:
gedit /etc/apt/sources.list
[spoiler]# deb cdrom:[Ubuntu 12.04 LTS Precise Pangolin - Release amd64 (20120425)]/ dists/precise/main/binary-i386/
deb cdrom:[Ubuntu 12.04 LTS Precise Pangolin - Release amd64 (20120425)]/ dists/precise/restricted/binary-i386/
deb cdrom:[Ubuntu 12.04 LTS Precise Pangolin - Release amd64 (20120425)]/ precise main restricted
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu precise main restricted
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu precise-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu precise universe
deb Index of /ubuntu precise-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu precise multiverse
deb Index of /ubuntu precise-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu precise-backports main restricted universe multiverse
deb Index of /ubuntu precise-security main restricted
deb Index of /ubuntu precise-security universe
deb Index of /ubuntu precise-security multiverse
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu precise partner
deb-src Index of /ubuntu precise partner
This software is not part of Ubuntu, but is offered by third-party
developers who want to ship their latest software.
deb-src Index of /ubuntu precise main
deb Index of http://download.virtualbox.org/virtualbox/debian precise contrib
deb http://debian.scribus.net/debian/ precise main
deb-src http://debian.scribus.net/debian/ precise main
deb Index of /debian precise main
deb-src Index of /debian precise main
deb Jeffrey Ratcliffe in Launchpad precise main
deb-src Jeffrey Ratcliffe in Launchpad precise main
deb-src http://liveusb.info/multisystem/depot all hand[/spoiler]
Run:
now remove the last 2 lines that read:-
deb http://liveusb.info/multisystem/depot all hand deb-src http://liveusb.info/multisystem/depot all hand
Back in the terminal run:
mkdir ~/MultiSystem-installer
cd ~/MultiSystem-installer
wget http://liveusb.info/multisystem/install-depot-multisystem.sh.tar.bz2
tar -xjvf install-depot-multisystem.sh.tar.bz2
sudo ./install-depot-multisystem.sh
Done it and I saw a warning in there somewhere (in red)
[spoiler]pooky2483@pooky2483-ubuntu12:~/MultiSystem-installer$ sudo ./install-depot-multisystem.sh
Depôt MultiSystem
OK
Ign http://liveusb.info all InRelease
Ign http://extras.ubuntu.com precise InRelease
Ign http://ppa.launchpad.net precise InRelease
Hit http://deb.playonlinux.com precise InRelease
Ign http://gb.archive.ubuntu.com precise InRelease
Ign http://gb.archive.ubuntu.com precise-updates InRelease
Ign http://gb.archive.ubuntu.com precise-backports InRelease
Ign http://archive.canonical.com precise InRelease
Ign http://debian.scribus.net precise InRelease
Get:1 http://liveusb.info all Release.gpg [490 B]
Ign http://security.ubuntu.com precise-security InRelease
Get:2 http://extras.ubuntu.com precise Release.gpg [72 B]
Hit http://download.virtualbox.org precise InRelease
Hit http://gb.archive.ubuntu.com precise Release.gpg
Hit http://gb.archive.ubuntu.com precise-updates Release.gpg
Hit http://archive.canonical.com precise Release.gpg
Hit http://extras.ubuntu.com precise Release
Hit http://debian.scribus.net precise Release.gpg
Get:3 http://liveusb.info all Release [4,641 B]
Hit http://security.ubuntu.com precise-security Release.gpg
Hit http://deb.playonlinux.com precise/main amd64 Packages
Hit http://gb.archive.ubuntu.com precise-backports Release.gpg
Hit http://ppa.launchpad.net precise Release.gpg
Hit http://extras.ubuntu.com precise/main Sources
Hit http://deb.playonlinux.com precise/main i386 Packages
Get:4 http://liveusb.info all/main amd64 Packages [1,250 B]
Ign http://debian.tagancha.org precise InRelease
Ign http://deb.playonlinux.com precise/main TranslationIndex
Get:5 http://ppa.launchpad.net precise Release.gpg [316 B]
Hit http://archive.canonical.com precise/partner amd64 Packages
Hit http://extras.ubuntu.com precise/main amd64 Packages
Hit http://extras.ubuntu.com precise/main i386 Packages
Get:6 http://liveusb.info all/main i386 Packages [1,249 B]
Ign http://liveusb.info all/main TranslationIndex
Hit http://download.virtualbox.org precise/contrib amd64 Packages
Hit http://gb.archive.ubuntu.com precise/main amd64 Packages
Hit http://gb.archive.ubuntu.com precise/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com precise/universe amd64 Packages
Hit http://gb.archive.ubuntu.com precise/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com precise/main i386 Packages
Hit http://gb.archive.ubuntu.com precise/restricted i386 Packages
Hit http://archive.canonical.com precise/partner i386 Packages
Ign http://archive.canonical.com precise/partner TranslationIndex
Ign http://extras.ubuntu.com precise/main TranslationIndex
Hit http://gb.archive.ubuntu.com precise/universe i386 Packages
Hit http://gb.archive.ubuntu.com precise/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com precise/main TranslationIndex
Hit http://gb.archive.ubuntu.com precise/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com precise/restricted TranslationIndex
Hit http://gb.archive.ubuntu.com precise/universe TranslationIndex
Hit http://gb.archive.ubuntu.com precise-updates/main amd64 Packages
Hit http://gb.archive.ubuntu.com precise-updates/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com precise-updates/universe amd64 Packages
Hit http://debian.tagancha.org precise Release.gpg
Hit http://gb.archive.ubuntu.com precise-updates/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com precise-updates/main i386 Packages
Hit http://gb.archive.ubuntu.com precise-updates/restricted i386 Packages
Hit http://gb.archive.ubuntu.com precise-updates/universe i386 Packages
Hit http://gb.archive.ubuntu.com precise-updates/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com precise-updates/main TranslationIndex
Hit http://security.ubuntu.com precise-security/main amd64 Packages
Hit http://gb.archive.ubuntu.com precise-updates/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com precise-updates/restricted TranslationIndex
Hit http://gb.archive.ubuntu.com precise-updates/universe TranslationIndex
Hit http://gb.archive.ubuntu.com precise-backports/main amd64 Packages
Hit http://download.virtualbox.org precise/contrib i386 Packages
Get:7 http://ppa.launchpad.net precise Release [11.8 kB]
Hit http://gb.archive.ubuntu.com precise-backports/restricted amd64 Packages
Hit http://debian.scribus.net precise/main Sources
Hit http://gb.archive.ubuntu.com precise-backports/universe amd64 Packages
Hit http://gb.archive.ubuntu.com precise-backports/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com precise-backports/main i386 Packages
Hit http://gb.archive.ubuntu.com precise-backports/restricted i386 Packages
Hit http://gb.archive.ubuntu.com precise-backports/universe i386 Packages
Hit http://gb.archive.ubuntu.com precise-backports/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com precise-backports/main TranslationIndex
Hit http://gb.archive.ubuntu.com precise-backports/multiverse TranslationIndex
Hit http://gb.archive.ubuntu.com precise-backports/restricted TranslationIndex
Ign https://private-ppa.launchpad.net precise InRelease
Hit http://gb.archive.ubuntu.com precise-backports/universe TranslationIndex
Get:8 http://gb.archive.ubuntu.com precise/main Translation-en_GB [96.4 kB]
Hit http://security.ubuntu.com precise-security/restricted amd64 Packages
Hit http://security.ubuntu.com precise-security/universe amd64 Packages
Hit http://security.ubuntu.com precise-security/multiverse amd64 Packages
Hit http://security.ubuntu.com precise-security/main i386 Packages
Hit http://security.ubuntu.com precise-security/restricted i386 Packages
Hit http://security.ubuntu.com precise-security/universe i386 Packages
Hit http://security.ubuntu.com precise-security/multiverse i386 Packages
Hit http://security.ubuntu.com precise-security/main TranslationIndex
Hit http://security.ubuntu.com precise-security/multiverse TranslationIndex
Hit http://security.ubuntu.com precise-security/restricted TranslationIndex
Ign http://download.virtualbox.org precise/contrib TranslationIndex
Hit http://debian.scribus.net precise/main amd64 Packages
Hit http://ppa.launchpad.net precise/main Sources
Hit http://ppa.launchpad.net precise/main amd64 Packages
Hit http://ppa.launchpad.net precise/main i386 Packages
Ign http://ppa.launchpad.net precise/main TranslationIndex
Ign http://archive.canonical.com precise/partner Translation-en_GB
Ign http://extras.ubuntu.com precise/main Translation-en_GB
Hit http://security.ubuntu.com precise-security/universe TranslationIndex
Hit http://gb.archive.ubuntu.com precise/main Translation-en
Get:9 http://gb.archive.ubuntu.com precise/multiverse Translation-en_GB [79.8 kB]
Hit http://debian.scribus.net precise/main i386 Packages
Ign http://liveusb.info all/main Translation-en_GB
Ign http://deb.playonlinux.com precise/main Translation-en_GB
Hit http://debian.tagancha.org precise/main Sources
Get:10 http://ppa.launchpad.net precise/main Sources [36.4 kB]
Hit http://security.ubuntu.com precise-security/main Translation-en
Hit http://security.ubuntu.com precise-security/multiverse Translation-en
Ign http://debian.scribus.net precise/main TranslationIndex
Hit http://gb.archive.ubuntu.com precise/multiverse Translation-en
Get:11 http://gb.archive.ubuntu.com precise/restricted Translation-en_GB [2,406 B]
Get:12 http://ppa.launchpad.net precise/main amd64 Packages [72.7 kB]
Hit http://debian.tagancha.org precise/main amd64 Packages
Hit http://debian.tagancha.org precise/main i386 Packages
Ign http://debian.tagancha.org precise/main TranslationIndex
Hit http://gb.archive.ubuntu.com precise/restricted Translation-en
Get:13 http://gb.archive.ubuntu.com precise/universe Translation-en_GB [5,492 B]
Hit http://gb.archive.ubuntu.com precise/universe Translation-en
Get:14 http://gb.archive.ubuntu.com precise-updates/main Translation-en_GB [96.4 kB]
Hit http://security.ubuntu.com precise-security/restricted Translation-en
Get:15 http://ppa.launchpad.net precise/main i386 Packages [72.6 kB]
Hit http://security.ubuntu.com precise-security/universe Translation-en
Hit http://gb.archive.ubuntu.com precise-updates/main Translation-en
Get:16 http://gb.archive.ubuntu.com precise-updates/multiverse Translation-en_GB [79.8 kB]
Hit http://packages.medibuntu.org precise InRelease
Hit http://gb.archive.ubuntu.com precise-updates/multiverse Translation-en
Get:17 http://gb.archive.ubuntu.com precise-updates/restricted Translation-en_GB [2,406 B]
Hit http://gb.archive.ubuntu.com precise-updates/restricted Translation-en
Get:18 http://gb.archive.ubuntu.com precise-updates/universe Translation-en_GB [5,492 B]
Hit http://gb.archive.ubuntu.com precise-updates/universe Translation-en
Hit http://gb.archive.ubuntu.com precise-backports/main Translation-en
Hit http://gb.archive.ubuntu.com precise-backports/multiverse Translation-en
Hit http://gb.archive.ubuntu.com precise-backports/restricted Translation-en
Hit http://gb.archive.ubuntu.com precise-backports/universe Translation-en
Ign http://debian.scribus.net precise/main Translation-en_GB
Hit http://packages.medibuntu.org precise/free amd64 Packages
Hit http://packages.medibuntu.org precise/non-free amd64 Packages
Hit http://packages.medibuntu.org precise/free i386 Packages
Hit http://packages.medibuntu.org precise/non-free i386 Packages
Hit https://private-ppa.launchpad.net precise Release.gpg
Ign http://packages.medibuntu.org precise/free TranslationIndex
Ign http://packages.medibuntu.org precise/non-free TranslationIndex
Hit https://private-ppa.launchpad.net precise/main amd64 Packages
Hit https://private-ppa.launchpad.net precise/main i386 Packages
Ign http://download.virtualbox.org precise/contrib Translation-en_GB
Ign https://private-ppa.launchpad.net precise/main TranslationIndex
Ign http://ppa.launchpad.net precise/main Translation-en_GB
Ign http://debian.tagancha.org precise/main Translation-en_GB
Ign http://packages.medibuntu.org precise/free Translation-en_GB
Ign http://packages.medibuntu.org precise/non-free Translation-en_GB
Ign https://private-ppa.launchpad.net precise/main Translation-en_GB
Fetched 570 kB in 8s (66.8 kB/s)
Reading package lists…
Building dependency tree…
Reading state information…
ttf-umefont ttf-unfonts-core ttf-droid
bridge-utils cpu-checker cryptsetup fatresize gtkdialog kvm-ipxe libaio1
librados2 librbd1 libxdo2 msr-tools qemu qemu-common qemu-kvm qemu-utils
seabios squashfs-tools vgabios wmctrl xdotool
Suggested packages:
busybox mol-drivers-macosx openbios-sparc ubuntu-vm-builder uml-utilities
librados2 librbd1 libxdo2 msr-tools multisystem qemu qemu-common qemu-kvm
qemu-utils seabios squashfs-tools vgabios wmctrl xdotool
0 upgraded, 21 newly installed, 0 to remove and 0 not upgraded.
Need to get 15.2 MB of archives.
After this operation, 39.2 MB of additional disk space will be used.
Get:1 http://liveusb.info/multisystem/depot/ all/main gtkdialog amd64 2:0.8.3-1 [325 kB]
Get:2 Index of /ubuntu precise-updates/main bridge-utils amd64 1.5-2ubuntu7 [32.0 kB]
Get:3 Index of /ubuntu precise/main libaio1 amd64 0.3.109-2ubuntu1 [6,396 B]
Get:4 Index of /ubuntu precise/main squashfs-tools amd64 1:4.2-4build1 [136 kB]
Get:5 Index of /ubuntu precise/universe fatresize amd64 1.0.2-6ubuntu1 [10.8 kB]
Get:6 Index of /ubuntu precise/universe libxdo2 amd64 1:2.20110530.1-3ubuntu1 [24.2 kB]
Get:7 Index of /ubuntu precise/universe xdotool amd64 1:2.20110530.1-3ubuntu1 [42.8 kB]
Get:8 Index of /ubuntu precise/universe wmctrl amd64 1.07-6 [22.9 kB]
Get:9 Index of /ubuntu precise-updates/main seabios all 0.6.2-0ubuntu2.1 [70.5 kB]
Get:10 Index of /ubuntu precise/main vgabios all 0.6c-2ubuntu3 [164 kB]
Get:11 http://liveusb.info/multisystem/depot/ all/main multisystem all 1.0251 [9,233 kB]
Get:12 Index of /ubuntu precise-updates/main qemu-common all 1.0+noroms-0ubuntu14.7 [21.5 kB]
Get:13 Index of /ubuntu precise-updates/main librados2 amd64 0.41-1ubuntu2.1 [784 kB]
Get:14 Index of /ubuntu precise-updates/main librbd1 amd64 0.41-1ubuntu2.1 [49.8 kB]
Get:15 Index of /ubuntu precise-updates/main qemu-utils amd64 1.0+noroms-0ubuntu14.7 [353 kB]
Get:16 Index of /ubuntu precise-updates/main qemu-kvm amd64 1.0+noroms-0ubuntu14.7 [3,516 kB]
Get:17 Index of /ubuntu precise-updates/universe qemu amd64 1.0+noroms-0ubuntu14.7 [2,664 B]
Get:18 Index of /ubuntu precise/main cryptsetup amd64 2:1.4.1-2ubuntu4 [80.0 kB]
Get:19 Index of /ubuntu precise/main msr-tools amd64 1.2-3 [9,052 B]
Get:20 Index of /ubuntu precise/main cpu-checker amd64 0.7-0ubuntu1 [6,538 B]
Get:21 Index of /ubuntu precise/main kvm-ipxe all 1.0.0+git-3.55f6c88-0ubuntu1 [327 kB]
Preconfiguring packages …
Fetched 15.2 MB in 9s (1,541 kB/s)
Selecting previously unselected package bridge-utils.
(Reading database … 255976 files and directories currently installed.)
Unpacking bridge-utils (from …/bridge-utils_1.5-2ubuntu7_amd64.deb) …
Selecting previously unselected package libaio1.
Unpacking libaio1 (from …/libaio1_0.3.109-2ubuntu1_amd64.deb) …
Selecting previously unselected package gtkdialog.
Unpacking gtkdialog (from …/gtkdialog_2%3a0.8.3-1_amd64.deb) …
Selecting previously unselected package squashfs-tools.
Unpacking squashfs-tools (from …/squashfs-tools_1%3a4.2-4build1_amd64.deb) …
Selecting previously unselected package fatresize.
Unpacking fatresize (from …/fatresize_1.0.2-6ubuntu1_amd64.deb) …
Selecting previously unselected package libxdo2.
Unpacking libxdo2 (from …/libxdo2_1%3a2.20110530.1-3ubuntu1_amd64.deb) …
Selecting previously unselected package xdotool.
Unpacking xdotool (from …/xdotool_1%3a2.20110530.1-3ubuntu1_amd64.deb) …
Selecting previously unselected package wmctrl.
Unpacking wmctrl (from …/wmctrl_1.07-6_amd64.deb) …
Selecting previously unselected package seabios.
Unpacking seabios (from …/seabios_0.6.2-0ubuntu2.1_all.deb) …
Selecting previously unselected package vgabios.
Unpacking vgabios (from …/vgabios_0.6c-2ubuntu3_all.deb) …
Selecting previously unselected package qemu-common.
Unpacking qemu-common (from …/qemu-common_1.0+noroms-0ubuntu14.7_all.deb) …
Selecting previously unselected package librados2.
Unpacking librados2 (from …/librados2_0.41-1ubuntu2.1_amd64.deb) …
Selecting previously unselected package librbd1.
Unpacking librbd1 (from …/librbd1_0.41-1ubuntu2.1_amd64.deb) …
Selecting previously unselected package qemu-utils.
Unpacking qemu-utils (from …/qemu-utils_1.0+noroms-0ubuntu14.7_amd64.deb) …
Selecting previously unselected package qemu-kvm.
Unpacking qemu-kvm (from …/qemu-kvm_1.0+noroms-0ubuntu14.7_amd64.deb) …
Selecting previously unselected package qemu.
Unpacking qemu (from …/qemu_1.0+noroms-0ubuntu14.7_amd64.deb) …
Selecting previously unselected package cryptsetup.
Unpacking cryptsetup (from …/cryptsetup_2%3a1.4.1-2ubuntu4_amd64.deb) …
Processing triggers for man-db …
Processing triggers for hicolor-icon-theme …
Processing triggers for install-info …
install-info: warning: no info dir entry in `/usr/share/info/gtkdialog.info.gz’
Processing triggers for ureadahead …
ureadahead will be reprofiled on next reboot
Setting up gtkdialog (2:0.8.3-1) …
Selecting previously unselected package multisystem.
(Reading database … 256536 files and directories currently installed.)
Unpacking multisystem (from …/multisystem_1.0251_all.deb) …
Selecting previously unselected package msr-tools.
Unpacking msr-tools (from …/msr-tools_1.2-3_amd64.deb) …
Selecting previously unselected package cpu-checker.
Unpacking cpu-checker (from …/cpu-checker_0.7-0ubuntu1_amd64.deb) …
Selecting previously unselected package kvm-ipxe.
Unpacking kvm-ipxe (from …/kvm-ipxe_1.0.0+git-3.55f6c88-0ubuntu1_all.deb) …
Processing triggers for bamfdaemon …
Rebuilding /usr/share/applications/bamf.index…
Processing triggers for desktop-file-utils …
Processing triggers for gnome-menus …
Setting up bridge-utils (1.5-2ubuntu7) …
Setting up libaio1 (0.3.109-2ubuntu1) …
Setting up squashfs-tools (1:4.2-4build1) …
Setting up fatresize (1.0.2-6ubuntu1) …
Setting up libxdo2 (1:2.20110530.1-3ubuntu1) …
Setting up xdotool (1:2.20110530.1-3ubuntu1) …
Setting up wmctrl (1.07-6) …
Setting up seabios (0.6.2-0ubuntu2.1) …
Setting up vgabios (0.6c-2ubuntu3) …
Setting up qemu-common (1.0+noroms-0ubuntu14.7) …
Setting up librados2 (0.41-1ubuntu2.1) …
Setting up librbd1 (0.41-1ubuntu2.1) …
Setting up qemu-utils (1.0+noroms-0ubuntu14.7) …
Setting up qemu-kvm (1.0+noroms-0ubuntu14.7) …
qemu-kvm start/running
Setting up qemu (1.0+noroms-0ubuntu14.7) …
Setting up cryptsetup (2:1.4.1-2ubuntu4) …
update-initramfs: deferring update (trigger activated)
Setting up multisystem (1.0251) …
Setting up msr-tools (1.2-3) …
Setting up cpu-checker (0.7-0ubuntu1) …
Setting up kvm-ipxe (1.0.0+git-3.55f6c88-0ubuntu1) …
Processing triggers for libc-bin …
ldconfig deferred processing now taking place
Processing triggers for initramfs-tools …
update-initramfs: Generating /boot/initrd.img-3.2.0-37-generic
Processing triggers for menu …
Ajouter PATH: /usr/games
PATH=“/usr/games:$PATH”
pooky2483@pooky2483-ubuntu12:~/MultiSystem-installer$ Gtkdialog version: 0.8.3
English|en|en_US.UTF-8
LANG:en_GB.UTF-8
LANGUAGE:en_US.UTF-8
LANGSEL:English|en|en_US.UTF-8
device:
EXIT=“abort”
[/spoiler]
Is it anything to worry about?
