Netgear wg111t
yeh, let me know … with a little luck, ndiswrapper being loaded may have been confusing things (though that would probably be too easy) ???
What happens if you delete ALL wireless connections, then set up a new connection manually, and set IPv6 to “Ignore” (for the wireless connection) ?
Had a few problems and think I’ve stuffed it up!
I was getting a constant Nautilus error and stupidly thought I could reinstall it. After removing Nautilus via terminal, Ubuntu crashed and was unresponsive so I have to power off. I’ve managed to boot, but cannot log into any account. Nor sure what to do now, feel like a complete numpty, lol. A reinstall sounds like a tempting option now. :o
you’re probably right … it would be possible to reinstall nautilus from the command line with:
sudo apt-get install nautilus
but my guess is removing the nautilus file manager will also have ripped out a ton of dependencies.
So up to you which route you wanna take … at least a fresh install will give me the chance to test the latest ar5523 drivers from svn.berlios.de
Just been reading about those drivers so yes, going to reinstall Ubuntu now. :slight_smile:
Thanks Mark
I’ll test the other drivers tomorrow … so reinstall Ubuntu, then wait till you see my next posting before adding any wireless drivers … c’ya tomorrow :slight_smile:
OK reinstall complete.
Thanks
OK, sorry it took me a while to respond, I had a fight with Ubuntu 12.04 running in a VM so gave up and installed it on a USB stick.
Anyway, the good news is that the Debian instructions seem to work just fine (with slight modification) … I can’t test them with a WG111T as I don’t have one but the module and firmware seems to build/install properly.
OK, let’s get on with it eh ? …
If at any stage during this tutorial you see an error after running a command … stop … and tell me which command caused it, and post the output from that command.
First lets make sure your system is up to date:
sudo apt-get upgrade
Now REBOOT.
When the system comes back up, open a terminal and run:
sudo apt-get install build-essential debhelper module-assistant quilt subversion wget wireless-tools
and if asked, hit “y” to accept all the packages … then run:
svn co svn://svn.berlios.de/fullstory/ar5523/trunk/ ar5523
wget http://verein.lst.de/~hch/ar5523.tgz
tar -xvf ar5523.tgz ar5523/uath-ar5523.bin --strip 1
cd ar5523
dpkg-buildpackage -us -uc
sudo dpkg -i ../ar5523-source*deb
sudo m-a a-i ar5523
sudo mv -v ../uath-ar5523.bin /lib/firmware
Now load the driver with:
sudo modprobe ar5523
And with a bit of luck your wireless should spring to life :slight_smile:
Please let me know if it works … so future readers will know.
We may have to add those 3 lines from earlier to /etc/modules … to make it hot pluggable (but we’ll decide that once the drivers/firmware are installed and working)
I get ‘cannot move… permission denied’.
Should this be ‘sudo mv’ maybe?
My mistake:
sudo mv ../uath-ar5523.bin /lib/firmware
I’ll also fix it in my last response :slight_smile:
Thanks. Should there be any output when that command is entered? There was none.
Nope (but if there was no error, it worked) … but I’ll fix that too by adding the -v (verbose output) option above :slight_smile:
as in:
Fixed above too :slight_smile:
you can double check it worked if you want by running:
ls -al /lib/firmware/uath-ar5523.bin
if that doesn’t error, and displays the file info … it moved properly :slight_smile:
OK. Good news and bad. The adapter sprung to life as you predicted; the blue light flashed, I saw a list of SSID’s, selected my own, entered my password and waited for connection watching the WiFi icon flutter.
Then, the blue light went off and when I went to use the keyboard and mouse I found my USB ports had all died. Poop!
Looks like I’m going to have to power-off but will wait for you to reply first.
If you only have a USB keyboard, you’ve no option other than to do a cold power off.
but if the Keyboard is working, hit Ctrl+Alt+T to open a terminal and run:
sudo shutdown -P now
Hold Alt+SysRq and whilst holding them type REISUB … leaving a few seconds between each key stroke.
that will reboot safely … but obviously only if your keyboard is working (which it may still be, so try that BEFORE doing a cold power off).
Couldn’t get any response at all so powered off. :frowning:
Have restarted with both mouse and keyboard in USB=>PS/2 adapters. Only the WiFi adapter is USB now.
Will any of the previous settings have been lost?
No … is it working ?
because it may still be best to add those 3 lines to /etc/modules
don’t do that yet, just tell me if it’s now working.
It’s working, in that it is trying to connect. USB is working for other devices too - PS/2 mouse wasn’t responding so plugged it into USB and it’s working alongside the WiFi adapter. Blue light is flashing on the WG111T, it’s attempting to connect and all the other SSID’s look fine - no garbled text.
I’m guessing we need those lines in /etc/modules/ then ?
what do you mean by “trying to connect” … isn’t it connecting ?
I mean the WiFi icon next to the clock is running (not exactly flashing but ‘active’), but it won’t actually connect. I’ve tried a couple of times, it asks for the password, I enter it but it still doesn’t connect.
What’s the output from:
ifconfig
iwconfig
rfkill list
iwlist scanning
lsmod
ifconfig
eth0      Link encap:Ethernet  HWaddr 00:19:bb:db:24:00
          inet6 addr: fe80::219:bbff:fedb:2400/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:9449 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4932 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:13939813 (13.9 MB)  TX bytes:384466 (384.4 KB)
          Interrupt:19 Memory:f0500000-f0520000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:66 errors:0 dropped:0 overruns:0 frame:0
          TX packets:66 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:4724 (4.7 KB)  TX bytes:4724 (4.7 KB)
wlan0     Link encap:Ethernet  HWaddr 00:14:6c:e8:40:0a
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
iwconfig
wlan0     IEEE 802.11bg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
eth0      no wireless extensions.
rfkill list
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
iwlist scanning
wlan0     No scan results
lsmod
Module                  Size  Used by
joydev                 17393  0
usbhid                 41906  0
hid                    77367  1 usbhid
arc4                   12473  2
ar5523                 21736  0
mac80211              436455  1 ar5523
cfg80211              178679  2 ar5523,mac80211
parport_pc             32114  0
ppdev                  12849  0
rfcomm                 38139  0
bnep                   17830  2
bluetooth             158438  10 rfcomm,bnep
hp_wmi                 13652  0
sparse_keymap          13658  1 hp_wmi
binfmt_misc            17292  1
snd_hda_codec_realtek   174055  1
psmouse                72919  0
snd_hda_intel          32765  3
snd_hda_codec         109562  2 snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              13276  1 snd_hda_codec
snd_pcm                80845  2 snd_hda_intel,snd_hda_codec
snd_seq_midi           13132  0
snd_rawmidi            25424  1 snd_seq_midi
snd_seq_midi_event     14475  1 snd_seq_midi
snd_seq                51567  2 snd_seq_midi,snd_seq_midi_event
snd_timer              28931  2 snd_pcm,snd_seq
snd_seq_device         14172  3 snd_seq_midi,snd_rawmidi,snd_seq
serio_raw              13027  0
i915                  414655  3
snd                    62064  15 snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
wmi                    18744  1 hp_wmi
mac_hid                13077  0
soundcore              14635  1 snd
drm_kms_helper         45466  1 i915
drm                   197692  4 i915,drm_kms_helper
snd_page_alloc         14108  2 snd_hda_intel,snd_pcm
i2c_algo_bit           13199  1 i915
video                  19068  1 i915
mei                    36570  0
lp                     17455  0
parport                40930  3 parport_pc,ppdev,lp
floppy                 60310  0
e1000e                140005  0
