I could be reading this wrong, but I think my card is capable of 1000mb/s.
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: on (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
I have tried but been unable to change from 100mb/s, any advice?
Have just bought new cat 6 cables for the house but now might have to get new card if it cant be changed.
Tried this
sudo ethtool -s eth0 speed 1000 duplex full autoneg off
Now you’ve asked a question there.
I assumed it was having had it for less than a year but some quick googling suggests it might not be.
Will get back to you with a definite answer.
You can have a gigabit capable network card, but it will still only connect to your router with the speed the router supports.
You could put in a gigabit network switch and connect your router to that. That way you could connect your machine to the switch with gigabit speed.
That’s my set up anyway.
The router and PC are at one side of the room and all my media stuff at the other.
I have a 16 port gigabit switch behind the media stand, everything connected to it with cat 6 cables and a cat 6 across the room to the router.
The PC though is connected via a cat 6 directly to the router.
Got a spare cat 6, if I run that to the switch from the PC (p.i.t.a but what ya gonna do) and that should sort out the gigabit network as the router will then only be supplying the modem part for internet access.
If all that seems right there is still the issue with the card.
Did I do it right or wrong, more importantly, is it a gigabit card or did I read that wrong.
