I’m busy this evening trying to upgrade a friends PC from peppermint 4 to Peppermint 5 and I a strange problem, which is when I log out the screen goes completely black and I have no means of logging back in again I have to power off then reboot then it will display the login screen ok, I’ve tried other greeter images but nothing makes any difference
When you say "upgrade" .. was this a fresh install ?
Yes it was a fresh install
When booted to the liveCD will it logout without going black ?
I’d love to be able to answer that but now it’s decided it won’t boot from the same CD I installed it with, but I’ll try to sort it out as quick as I can and get back to you
but you won’t believe this when I tried to boot into same live cd I installed it with I selected “Try Peppermint” and it it took an age for the red progress to reach the end then it came up with an Elementary logo
anyway if things aren’t bad enough (Ctrl+Alt+F3) does nothing
I’m almost finished burning a new disc i’ll try it shortly
Is there no fglrx drivers being offered by "Additional Drivers" ?
No
What happens if you log into the guest account and log out ?
It’s just the same
but I installed fglrx from the repos after which I couldnt get a decent resolution whatever I did and the ATI control centre was telling me I didn’t have an ATI card installed (which I did) or the wrong driver was installed, so i uninstalled fglrx and the card and installed an Nvidia FX5900 but that made no difference either even after installing the proprietary driver, I then tried reinstalling lightdm and I noticed that the green box beside it had an exclamation mark inside it indicating an error and the option to reinstall was greyed out but there was an option to upgrade so I did that and it popped up some error message which i cant remember but it removed the exclamation mark and i had a green box but that still didn’t work, in a final act of desperation, I installed Pantheon greeter as per the instructions you gave me previously but need I say it that doesn’t work either, I’ve also tried various resolutions in the monitor settings
I’ve tried using a different background image in /etc/lightdm/lightdm-greeter.conf and tried uncommenting out the background image completely all to no avail, I also compared the file against the same file on my own PC and it’s exactly the same word for word
To put closure on this I reinstalled Peppermint 5 and all’s well
For all it’s worth I think the problem was caused by a bad graphics card that was installed in the PC during installation, although I replaced the card after installation I think the bad card corrupted the installation in some way and I don’t think this was fixable but I suppose we.ll never know for sure, anyway it’s sorted now
