For some reason I cant get my Grand-Daughters printer to work with tux paint, it works in other applications such as gedit, but when she tries to print directly from tux paint she just get an error message “cannot print”, I have the tux paint config tool and it’s set to allow printing, I’ve tried reasearching the problem online but can’t find a solution, another odd thing which may or may not be connected is that I can’t log into the cups interface, it wont accept username & password, So I’m not sure if this could be some kind of permissions problem, I have 2 users on that PC “family” & “chloe” and I can’t log in with either of them, I also looked into the etc/tuxpaint/tuxpaint.config file to see if I could find the problem there, but every setting is commented out with a # so it doesn’t look like it’s reading from that file but I’m probably misunderstanding that.
I also looked into the etc/tuxpaint/tuxpaint.config file to see if I could find the problem there, but every setting is commented out with a # so it doesn't look like it's reading from that file
Have you tried to look in "~/.tuxpaintrc" like this:
cat ~/.tuxpaintrc
As I understand this overrides etc/tuxpaint/tuxpaint.config
You might want to look at printcommand=COMMAND
as described here
Which printer are you trying to print to .. and is it set as the default printer in:-
I’m not trying to print to any printer in particular, as I don’t get the printer dialogue showing up to select a printer, when i click on the print icon within tuxpaint I immediately get an error message saying “sorry! your picture could not be printed” so I don’t get to select a printer.
For some reason i seem to have the Brother printer installed twice (MFC-210C & MFC-210C@192.168.2.3) but the default is MFC-210C
after i first edited the file as you instructed and saved it it was just the same, then I went into the tuxpaint config tool and clicked use “all users” settings, then I checked the tuxpaintrc and it was completely wiped, so I followed your instructions again and now it’s working
