Installed MInt 15 on my desktop after a reasonably good experience with my Lenovo laptop.
No such luck this time though. Worst thing wrong is that I have no music from speaker - an absolute showstopper for me. (and needless to say it works perfectly on Win XP).
drive manager prompted me to change driver to nvidia-310 (on NVIDIA G86 (geForce 8400 GS). still no luck. Someone said elsewhere (this seems a worryingly common problem) to run
lspci | grep -i audio and smod | grep snd
the output follows. Can anyone help me on this - really don’t want to have to go back to windows
brief update
-is this something to do with preferences within sound. I did somehow get some music out, but it sounded like someone was singing through a cup of water!
in sound > prefencces I have
Built in Audio - analoogue stero output
CM18738/CM18768 PCI (IEC958 output)
Only with the latter do I get a positive result with speaker test.
But when I close and repoen, the hardware tab has reverted to Built In Audio, although the output tab remains at CMI etc.
I reiterate this is a brand new install, I have edited no files thro’ terminal etc
Hi there
I get
wayne@wayne-System-Product-Name ~ $ sudo modprobe -r snd_hda_intel
[sudo] password for wayne:
FATAL: Module snd_hda_intel is in use.
the graphics card is quite old and certainty doesn’t have HDMI on it
However…setting sounds > preferences > output to CMI8738/CMI8768 now does work. I get sound!!! BUT its still unlistenable, both in VLC and in that dreadful Banshee app. (Background vocals are particularly bad and the output thro headphones is as bad as the speaker)
Ive set sounds > preferences > hardware for CMI8738/CMI8768 to various settings but none of it seems to improve…
I’m going tto guess you DO have an onboard sound card … even if there are no obvious external audio sockets, it may have required a cable attached to a header on the motherboard.
Is there ANY option in the BIOS to disable onboard audio
Wow - that was some diagnosis.
You were absolutely correct, there WAS onboard sound!! Ive disabled this in the BIOS and it has duly vanished form sounds > preferences.
However…once disabled, the sound is still wrong, both in VLC and BAnshee…
the sound is tunny and fuzzy, with background vocals sometimes hardly present. I tested the same tune on my smartphone and the lack of clarity and balance was total
trying with headphones - i can hear it, faintly, but definitely there, so the phones are plugged in correctly. But here I hear it faintly at 100% volume, whereas on my laptop it blows my head off at 50%
