not able to access internet in linux from scratch on virtual box
Hi all,
i installed lfs (linux from scratch)live CD on virtual box and powered on the machine .
After logging in ,i did a wget to download some pdf, i got this error message
" Temporary failure in name resolution"
i know its a DNS issue .
then i did ping 74.125.225,50 (google.com)now i got this
“Destination host unreachable”.
then i did ifconfig, i did not find ip on eth0 ,
then i checked the virtual machine setting , the network adapter was set to NAT .
my host OS has internet connected ,but i am not able to access internet in my virtual machine .
please help .
Thanks
Pradeep.
LFS, wow :o
Have you compiled & install the networking tools?
Edit: And, have you compiled the kernel with support for the Virtualbox network adaptor?
load the network drivers (vboxnetflt)
sudo modprobe vboxnetflt
That’s assuming that sudo is compiled & installed…!
You can replace “sudo” with “su -c” in most instances (including this one)
