Please help guys! I am needing to use pic monkey to edit an art work and it says I need Adobe Flash 11 or higher. I have looked at my firefox plug in and it says I already have Shockwave Flash 11.2. What can I do?!! This is for my Peppermint 3 laptop.
I will do Mark thanks! I had to use another editor last night- it was ok but I like pic monkey better. For the life of me I can’t figure out how to use Gimp except for cropping and sharpening stuff.
I’ve gotta agree, GIMP is like photoshop, which is massive overkill for a lot of people. It’s simply not intuitive enough, and it’s not worth spending the time learning the tool if you only use it a couple of times a year.
I am on the Mint netbook- pic monkey worked here, though slow as usual. I had updated the repositories.I had done that on Peppermint laptop, just seen it has 27 updates- will do that.
If all else fails I would suggest Pinta it’s a simple photo editor /drawing program that’s not nearly as complex as Gimp but has a lot of neat features, you’ll find it in the repos or
I've never tried pinta .. I've seen it in the repos, but never gotten around to trying it .. any good ?
I think it’s very good it’s classed mainly as a drawing program but it does some clever photo editing stuff as well, it’s like a stripped down version of Gimp
