Peppermint 5 Updates (SOLVED)
I downloaded Owncloud 7 from the developers website to try it out but it looked a bit involved so I would be happy to remove it completely what would be the best way to do that ?
How did those PPA's get there in the first place ? .. openshot.developers and handbrake-release don't contain any packages for "trusty" ;) (you may as well delete them)
I added them because handbrake doesn’t seem to be available in the repos and I added the openshot PPA because it’s under active development and I thought by adding the PPA I’d keep up to date with the latest versions, (Is my thinking flawed here ?)
Well neither of those PPA’s contain anything for “trusty”, so they’re erroring out … remove them (or disable them) in
Synaptic > Settings > Repositories > Other Software (tab)
As for the opensuse repo … comment it out by placing a # at the beginning of the line (or remove the line altogether) in:
SAVE the file.
Now see if you get an errors from:
sudo apt update
I couldn’t find a reference to the opensource repo anywhere in /etc/apt/sources.list but was showing in Synaptic > Settings > Repositories > Other Software (tab) so I unchecked it, running an update now show a lot of duplicate sources, Do I just remove the duplicates from the sources list ?
Reading package lists... Done
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/multiverse amd64 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_multiverse_binary-amd64_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/restricted amd64 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_restricted_binary-amd64_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_main_binary-amd64_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/universe amd64 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_universe_binary-amd64_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/multiverse i386 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_multiverse_binary-i386_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/restricted i386 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_restricted_binary-i386_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/main i386 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_main_binary-i386_Packages)
W: Duplicate sources.list entry http://security.ubuntu.com/ubuntu/ trusty-security/universe i386 Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_trusty-security_universe_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
Many thanks
post the contents of your
# deb cdrom:[Peppermint 5 _Five_ - Release amd64 (20140617.2)]/ trusty main multiverse restricted universe
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu trusty main restricted
deb-src Index of /ubuntu trusty main restricted
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu trusty-updates restricted main
deb-src Index of /ubuntu trusty-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu trusty universe
deb-src Index of /ubuntu trusty universe
deb Index of /ubuntu trusty-updates universe
deb-src Index of /ubuntu trusty-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu trusty multiverse
deb-src Index of /ubuntu trusty multiverse
deb Index of /ubuntu trusty-updates multiverse
deb-src Index of /ubuntu trusty-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu trusty-backports main restricted universe multiverse
deb-src Index of /ubuntu trusty-backports main restricted universe multiverse
deb Index of /ubuntu trusty-security main restricted
deb-src Index of /ubuntu trusty-security main restricted
deb Index of /ubuntu trusty-security universe
deb-src Index of /ubuntu trusty-security universe
deb Index of /ubuntu trusty-security multiverse
deb-src Index of /ubuntu trusty-security multiverse
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu trusty partner
deb-src Index of /ubuntu trusty partner
This software is not part of Ubuntu, but is offered by third-party
developers who want to ship their latest software.
deb Index of /ubuntu trusty-proposed main restricted universe multiverse
deb Index of /ubuntu trusty-security multiverse restricted main universe
OK, you could just comment out the last line, but I have a feeling that’s the one added by the tick box … so probably best to do it this way
Comment out the lines in red
add the line in green
distribution.
security team.
[b]# deb Index of /ubuntu trusty-security main restricted
deb-src Index of /ubuntu trusty-security multiverse[/b]
deb-src Index of /ubuntu trusty-security multiverse restricted main universe
for comparison, here’s my sources.list … generated from here (after screwing up my default one):
[spoiler]
################### OFFICIAL UBUNTU REPOS ###################
Ubuntu Main Repos
deb Index of /ubuntu trusty main restricted universe multiverse
deb-src Index of /ubuntu trusty main restricted universe multiverse
Ubuntu Update Repos
deb http://archive.ubuntu.com/ubuntu/ trusty-security main restricted universe multiverse
deb Index of /ubuntu trusty-updates main restricted universe multiverse
deb Index of /ubuntu trusty-proposed universe multiverse restricted main
deb Index of /ubuntu trusty-backports universe multiverse restricted main
deb-src http://archive.ubuntu.com/ubuntu/ trusty-security main restricted universe multiverse
deb-src Index of /ubuntu trusty-updates main restricted universe multiverse
deb-src Index of /ubuntu trusty-proposed universe multiverse restricted main
deb-src Index of /ubuntu trusty-backports universe multiverse restricted main
Ubuntu Partner Repo
Ubuntu Extras Repo
[/spoiler]
Much tidier than the default layout innit ? :wink:
Ok I followed you instructions and that’s put a stop to the updates error (no more duplicates) after that I ran the Software Updater manually and worked perfectly (no more strange behaviour as per the video I posted) So I suppose I’ll just have to wait to see if I get offered any further updates automatically
I definitely like the simplicity of your sources list, I take it when you use that site/utility you select the sources you want and it will generate a sources.list text file that you replace with the original ?
Many thanks for your help once again
Egzaktly :slight_smile:
Or I suppose you could just copy mine, which is the same as yours anyway just laid out better … or not bother now it’s working, in the best “why mess” tradition :slight_smile:
