Peppermint 5 won't boot
Hi Guys,
Decided to install Peppermint 5 in place of Pep 4 on my ageing Dell Inspiron 1640 laptop. The installation seemed to go ok and the screen came up for restart after installation, I did the restart but the touchpad locked up, screen went black, lots of writing including something about Kernel panic. Managed to shut down but now it just gets to the peppermint starting up screen and goes no further.
Your advice as always would be much appreciated.
Thanks in advance,
Degsy
Tried again using recovery mode, the second option on the Boot Menu and after much screen writing etc the system booted successfully!
Not sure if this is helpful/useful but here it is
derek@derek-MM061 ~ $ sudo fdisk -l
[sudo] password for derek:
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x00098838
/dev/sda1 * 2048 499711 248832 83 Linux
/dev/sda2 501758 234440703 116969473 5 Extended
/dev/sda5 501760 234440703 116969472 83 Linux
Disk /dev/mapper/sda5_crypt: 119.8 GB, 119774642176 bytes
255 heads, 63 sectors/track, 14561 cylinders, total 233934848 sectors
Disk identifier: 0x00000000
Disk /dev/mapper/sda5_crypt doesn’t contain a valid partition table
Disk /dev/mapper/peppermint–vg-root: 118.2 GB, 118170320896 bytes
255 heads, 63 sectors/track, 14366 cylinders, total 230801408 sectors
Disk /dev/mapper/peppermint–vg-root doesn’t contain a valid partition table
Disk /dev/mapper/peppermint–vg-swap_1: 1602 MB, 1602224128 bytes
255 heads, 63 sectors/track, 194 cylinders, total 3129344 sectors
Disk /dev/mapper/peppermint–vg-swap_1 doesn’t contain a valid partition table
What do you suggest next?
Degsy
Make sure you’re connected to your router by an ethernet cable … now boot into recovery mode, log in …then run:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
once finished, run:
sudo shutdown -P now
will it boot normally now ?
Thank you Mark, will do that later today and let you know what happens.
Degsy
Carried out your suggestion but unfortunately the boot up stops at the " peppermint. Starting up" screen.
Would the easy answer be to boot to the live cd and re-install Peppermint 5?
Thanks for your help,
Degsy
Did you install from the Live session desktop … or from the screen that offers you “Try Peppermint” and “Install Peppermint”
If you’re going to reinstall … select “Try Peppermint” … then once at the desktop use the “Install Peppermint” icon that’ll be on the desktop.
Reason - If the Live session boots … so should the installed version.
Well again I did as you suggested and booted to live CD then selected Install (which is what I did first time), the install as carried out and then on re starting after the install the system just stops at the Peppermint Starting up screen with just a very small bit of red along the indicator line. There was no Kernel Panic this time but still wont boot up. Did as last time and went to Recovery Mode and this boots OK, which is where I am now typing this reply.
If you have any further suggestions they would be most welcome, sorry about this, I just dont understand what is going wrong.
Thanks in advance,
Degsy
The Recovery Mode essentially uses the nomodeset by default, so this is pointing to a graphics problem.
As Mark suggested in your other thread:
Boot with the Recovery Mode, once you are on the desktop:
Go to Software & Updates > Additional Drivers (tab), and that should offer you the proprietary driver(s) for your graphics card.
Hi Sezo,
The Software and Updates, Additional Drivers Tab shoes "No additional drivers available "
Any other suggestions?
Thanks,
Degsy
Difficult to say without knowing what graphics your laptop has.
Can you post the output from (boot to Recovery Mode):
sudo lshw -C display
Hi Sezo,
As requested:
derek@derek-MM061 ~ $ sudo lshw -C display
*-display:0 UNCLAIMED
product: Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 03
width: 32 bits
capabilities: msi pm vga_controller bus_master cap_list
configuration: latency=0
resources: memory:eff00000-eff7ffff ioport:eff8(size=8) memory:d0000000-dfffffff memory:efec0000-efefffff
*-display:1 UNCLAIMED
description: Display controller
product: Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
physical id: 2.1
bus info: pci@0000:00:02.1
version: 03
width: 32 bits
capabilities: pm bus_master cap_list
resources: memory:eff80000-efffffff
Many thanks,
Degsy
I am not too up on graphics drivers but you could try to install (or reinstall) the xserver-xorg-video-intel drivers
To see if it is installed do the following:
aptitude search xserver-xorg-video-intel
You will see the xserver-xorg-video-intel with an “i” in front of it.
The “i” means installed. If it were not installed there would be a “p” in front of it.
sudo apt-get install --reinstall xserver-xorg-video-intel libgl1-mesa-glx libgl1-mesa-dri xserver-xorg-core
sudo dpkg-reconfigure xserver-xorg
Then reboot and see if that makes any difference.
Hi Sezo,
Thank you for your response, here is what happened:derek@derek-MM061 ~ $ aptitude search xserver-xorg-video-intel
i A xserver-xorg-video-intel - X.Org X server – Intel i8xx, i9xx display
p xserver-xorg-video-intel:i386 - X.Org X server – Intel i8xx, i9xx display
p xserver-xorg-video-intel-dbg - X.Org X server – Intel i8xx, i9xx display
p xserver-xorg-video-intel-dbg:i3 - X.Org X server – Intel i8xx, i9xx display
p xserver-xorg-video-intel-lts-qu - Transitional package for xserver-xorg-vide
p xserver-xorg-video-intel-lts-ra - Transitional package for xserver-xorg-vide
p xserver-xorg-video-intel-lts-sa - Transitional package for xserver-xorg-vide
derek@derek-MM061 ~ $ sudo apt-get install --reinstall xserver-xorg-video-intel libgll-mesa-glx libgll-mesa-dri xserver-xorg-core
Reading package lists… Done
Building dependency tree
E: Unable to locate package libgll-mesa-glx
E: Unable to locate package libgll-mesa-dri
Any further help would be much appreciated.
Thanks,
Degsy
OK, try without those two packages:
sudo apt-get install --reinstall xserver-xorg-video-intel xserver-xorg-core
Then
And reboot
I am afraid it is still the same, just sits stuck on the “peppermint. Starting up” screen.
Degsy
It looks like the drivers are not loaded for your card:
Try this old hack:
sudo gedit /etc/default/grub
and make it look like this:
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i915.modeset=0”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash i915.modeset=1”
Save the file. Run:
sudo update-grub
Then reboot
Hi Sezo,
Thanks very much for your help, in the meantime I decided to try installing Ubuntu 14.04 which I was going to install on my desktop to replace 12.04, and it has installed and booted with no problem at all, and this is what I am using at the moment to post this response.
I will now probably try and install Peppermint 5 on the desktop and see if that works ok as well.
Hope that you dont mind my change of route, I really do appreciate all the effort that you have put in.
Many thanks,
Degsy
No problem at all, glad you sorted it.
Just out of interest, what does
show now with Ubuntu.
Hi Sezo,
here is the output you asked for from Ubuntu 14.04
derek@derek-MM061:~$ sudo lshw -C display
*-display:0
physical id: 2
version: 03
width: 32 bits
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:16 memory:eff00000-eff7ffff ioport:eff8(size=8) memory:d0000000-dfffffff memory:efec0000-efefffff
physical id: 2.1
version: 03
width: 32 bits
Does this make any sense to you?
Degsy
So the difference is (beside display:0 claimed this time):
Sorry Degsy … Sky in their ultimate wisdom decided I wasn’t worthy of internet for a day and a half >:(
Kinda odd that Ubuntu 14.04 would load the i915 driver yet Peppermint 5 wouldn’t … could the installation media have been corrupt ?
