Hi everyone and today I decided to install peppermint os on my old netbook (dell inspiron mini 10) since windows xp was being slow. All was well except that my wifi was not working. So according to marks instructions on an old thread http://linuxforums.org.uk/index.php?topic=9939.0 I decided to try sudo lshw -C network on terminal. Here are the results *-network
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:24:e8:94:37:32
capacity: 100Mbit/s
width: 64 bits
capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full ip=192.168.1.17 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:40 ioport:2000(size=256) memory:d8410000-d8410fff memory:d8400000-d840ffff memory:d8420000-d843ffff
*-network
product: BCM4312 802.11b/g LP-PHY
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 01
width: 64 bits
configuration: driver=b43-pci-bridge latency=0
resources: irq:17 memory:d8000000-d8003fff
If anyone has a solution to this issue I would really appreciate it. Thank you for your time and have a wonderful day.
IGNORE THIS POSTING … SEE MY NEXT ONE
Connect to your router with an ethernet cable.
Open a terminal (Ctr;+Alt+T), and run:
sudo apt-get install b43 firmware-b43-installer
sudo modprobe b43
did your wireless spring to life ?
No When I input-ed the first option I got E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Ignore the above anyway … just spotted the LP-PHY
First make sure the Software Manager, Synaptic package manager, and the Software Updater are all CLOSED … and that you’re connected to your router with an ethernet cable.
THEN open a terminal and run:
sudo modprobe -r b43
sudo apt-get install b43 firmware-b43-lpphy-installer
sudo modprobe b43
No this time I got sudo modprobe -r b43
[sudo] password for
Reading package lists… Done
Building dependency tree
E: Unable to locate package b43
E: Unable to locate package firmware-b43-lpphy-installer
mamu@mamu-Inspiron-1010 ~ $ sudo modprobe b43
Are you connected to your router with an ethernet cable ?
Yes I am typing to you from chromium on the same laptop.
Run:
then try those commands again.
No I got sudo modprobe -r b43
~ $ sudo apt-get install b43 firmware-b43-lpphy-installer
if you fire up the Synpatic package manager … then go to settings > repositories > peppermint software (tab)
are the 4 top boxes ticked ?
back in 7 mins
Yes they are ticked.
what’s the contents of
gedit /etc/apt/sources.list
and is this a hard drive install of Peppermint 4, or a liveCD ?
Sorry, my mistake …
sudo apt-get install b43-fwcutter firmware-b43-lpphy-installer
sudo modprobe b43
I already installed peppermint to hardrive using an usb. The sources list says #deb cdrom:[Peppermint 4 Four - Release i386 (20130502)]/ raring main multiverse restricted universe
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu raring main restricted
deb-src Index of /ubuntu raring main restricted
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu raring-updates main restricted
deb-src Index of /ubuntu raring-updates main restricted
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu raring universe
deb-src Index of /ubuntu raring universe
deb Index of /ubuntu raring-updates universe
deb-src Index of /ubuntu raring-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu raring multiverse
deb-src Index of /ubuntu raring multiverse
deb Index of /ubuntu raring-updates multiverse
deb-src Index of /ubuntu raring-updates multiverse
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu raring-backports main restricted universe multiverse
deb-src Index of /ubuntu raring-backports main restricted universe multiverse
deb Index of /ubuntu raring-security main restricted
deb-src Index of /ubuntu raring-security main restricted
deb Index of /ubuntu raring-security universe
deb-src Index of /ubuntu raring-security universe
deb Index of /ubuntu raring-security multiverse
deb-src Index of /ubuntu raring-security multiverse
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu raring partner
deb-src Index of /ubuntu raring partner
Uncomment the following two lines to add software from Ubuntu’s
‘extras’ repository.
This software is not part of Ubuntu, but is offered by third-party
developers who want to ship their latest software.
see my last posting
No the wifi does not seem to be working.
What’s the output from:
rfkill list
sudo iwlist scanning
This time I got 0: compal-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: compal-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
~ $ sudo iwlist scanning
OK, let’s try the wl driver … fire up synaptic package manager, and go to
Settings > Repositories > Other software tab
but a tick in the 2 boxes
Canonical Partners
Independent
Click the “Close” button … and close synaptic.
Open a terminal and run:
sudo apt-get install linux-headers-generic build-essential dkms
sudo apt-get install bcmwl-kernel-source
sudo modprobe -r b43 ssb wl
sudo modprobe wl
Did wireless spring to life ?
