So I have just installed Peppermint on my laptop, work wonderfully.
I therefore decided it was worthy enough for my Desktop. Trouble is the wireless is acting incredibly odd. It will hit the maximum of 45kbps download and takes about an hour to download software…I have been waiting for netbeans now for about an hour and a half. I assumed there may be a limitation with Peppermint. So I tried my laptop with the same distro, down to the disk used to install it. It was fine.
Now admittedly I have not had much experience with Wireless and Linux as my laptop has always been very compatible. My desktop has a new Wireless card (TP-LINK TL-WN951N) which works fine with my dreaded windows 7 install. From what I have worked out it is using the ath9k driver currently.
lspci responds with Network controller: Atheros Communications Inc. AR5008 Wireless Network adapter.
This is the standard driver that is built into the kernel.
The device connects to the network absolutely fine, but speeds are incredibly low…
So if anyone has a solution then please let me know, as all my Google searches have ended up fruitless
