What happens if you hit “Tab” when you get to “boot:” … does it display any options ?
or when you get to “boot:”
live
and hit enter ?
Did you let Startup Disk Creator format the USB stick before creating ? … if not, you might want to try that in case the Unetbooting bootloaderr was left behind.
a) Did you let Startup Disk Creator do the formatting?
b) Have you checked the MD5 checksum of the ISO image ?
c) Are you sure this system can boot from LiveUSB sticks … how old is the system … have you ever successfully booted a different LiveUSB on this system ?
d) is the new USB stick the same make/model as the old one ?
Checked everything. Checksum, different usb sticks. Different distro’s. Nothing works. I vaguely remember this problem from the past and found that the only way to get a usb distro to boot was to…use the MS Windows Pendrive program! Surely not. I know it has to be me. i just do not know where I am going wrong.
You could try this solution:
Open your USB flash, open file /syslinux/syslinux.cfg,
find the word ui and remove it along with it's following space.
Save and Done
Now try to boot with it.
