Problem since installing Dual Boot (SOLVED)
Found a live DVD and booted to it, the output you requested is as follows:
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x0001c80a
/dev/sda1 * 2048 172790376 86394164+ 83 Linux
/dev/sda2 172791806 234440703 30824449 5 Extended
/dev/sda5 231317504 234440703 1561600 82 Linux swap / Solaris
/dev/sda6 172791808 231317503 29262848 83 Linux
Partition table entries are not in disk order
ubuntu@ubuntu:~$
OK, boot to the LiveDVD, don’t do anything that might mount any partitions, just open a terminal and run:
sudo fsck /dev/sda1
sudo fsck /dev/sda6
then see if it’ll boot
if not, you’re going to have to check the log files for the unbootable distro
in particular the
/var/log/lightdm/lightdm.log
/var/log/Xorg.0.log
logs
Be sure to be getting them from the partition containing the unbootable distro, and NOT the live session.
and find some way to host them online somewhere, then provide a link
This sounds more like that it is a lightdm issue.
What happens if you try this from the login screen:
press CTR+ALT+F1
you will get to the terminal then login to your normal user
once logged in enter
startx
Does that starts your normal session?
Hi Mark & SeZo,
Thanks for you help,
First, tried your suggestion Mark, no joy at all, both did mention being “clean” when I ran the commands but no boot.
I would not have the first idea where to start with checking the log files.
Secondly, tried your suggestion SeZo and a lot of writing flashed up the screen but nothing happened after that, thanks again guys.
Finally said on screen xinit giving up,
Xinit unable to connect to X server, resource temporarily unavailable
Waiting for X server to shut down (EE) server terminated successfully (o) closing log file
Xinit server error
Degsy
try this from the text console
sudo mv -v /tmp /tmp-old
sudo mkdir /tmp
sudo chmod 777 /tmp
sudo service lightdm restart
anything ?
Tried your suggestion, this is as far as it got
mv: cannot move ‘/tmp’ to ‘/tmp-old’: Device or resource busy,
Then returned me to the usual prompt.
Degsy
Okay, that’s even more making me think it’s something in Ubuntu’s /tmp directory.
I take it you can still boot Peppermint ?
if so, can you boot to Peppermint and post the output from:
mount
From Peppermint 6:
degsy@degsy-MM061 ~ $ mount
/dev/sda6 on / type ext4 (rw,errors=remount-ro)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/pstore type pstore (rw)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=degsy)
Thanks again for your help,
Degsy
OK, from within Peppermint run:
sudo mount /dev/sda1 /mnt
sudo mv -v /mnt/tmp /mnt/tmp-old
sudo mkdir /mnt/tmp
sudo chmod 777 /mnt/tmp
now try rebooting into Ubuntu
if it still loops at the login screen, are there any clues (error messages) given if you drop to a text console, then run:
Carried out your instructions from within Peppermint, all commands went through no problem, logged back into Ubuntu but got the looping log in screen again, tried the lightdm suggestion but no clues came up, just responded with "stop/waiting then went back to the looping log in screen.
Thanks,
Degsy
OK, boot peppermint and run:
cd /mnt/var/log
sudo tar cvf ~/Desktop/degsy-logs.tar.gz dmesg kern.log syslog Xorg.0.log lightdm/lightdm.log lightdm/x-0.log lightdm/x-0-greeter.log
sudo chown $USER:$USER ~/Desktop/degsy-logs.tar.gz
you’ll then find a file on the Peppermint desktop … can you host that online somewhere and post a link
Link is as follows:
https://www.dropbox.com/s/jrcrm6m2hx6pcju/degsy-logs.tar.gz?dl=0
Please note for sake of accuracy all commands copied and pasted into the Terminal
Hope this helps,
Regards,
Degsy
in Peppermint, run
then post the contents of
gedit /mnt/home/derek/.xsession-errors
and the output from:
df -h
HI Mark,
As requested:
degsy@degsy-MM061 ~ $ sudo mount /dev/sda1 /mnt
[sudo] password for degsy:
degsy@degsy-MM061 ~ $ gedit /mnt/home/derek/.xsession-errors
degsy@degsy-MM061 ~ $ df -h
Filesystem Size Used Avail Use% Mounted on
udev 742M 4.0K 742M 1% /dev
tmpfs 151M 1.3M 150M 1% /run
/dev/sda6 28G 4.1G 22G 16% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
none 5.0M 0 5.0M 0% /run/lock
none 752M 20M 732M 3% /run/shm
none 100M 12K 100M 1% /run/user
/dev/sda1 81G 29G 49G 37% /mnt
The gedit returned a blank file with just a blinking cursor in the top left corner.
Degsy
in peppermint run:
then post the output from:
ls /mnt/home
ls -a /mnt/home/derek
AS requested:
degsy@degsy-MM061 ~ $ ls /mnt/home
degsy derek
degsy@degsy-MM061 ~ $ ls -a /mnt/home/derek
. Documents Music
… Downloads .openshot
.adobe .dropbox Pictures
All Genealogical Data Dropbox .pki
.arista .dropbox-dist .PlayOnLinux
.avidemux .fonts PlayOnLinux’s virtual drives
.bash_history .gconf .profile
.bash_logout .gksu.lock Public
.bashrc .gnome2 .ssh
.cache .gnome2_private Templates
.cinnamon .gnupg .themes
.compiz .gphoto .thunderbird
.config .gstreamer-0.10 Videos
.conky .hplip .winff
Conky-HTC-Updated-Enfield.zip .ICEauthority .Xauthority
.dbus .local .Xauthority-old
derek-MM061 .macromedia .xinputrc
Desktop .mozilla .xsession-errors
.dmrc .mplayer .xsession-errors.old
Degsy
Does
still open a blank file ?
Yes, Mark, still opens a blank file, sorry.
Degsy
Would it be a good idea to replace lightdm with gdm and see if that behaves the same?
Having two users affected (brand new and old) would point to a lightdm problem.
First let’s give reinstalling lightdm a shot … then if necessary we’ll give gdm or possibly Mints mdm a go :slight_smile:
(IIRC gdm brings in a lot more dependencies than mdm)
In Peppermint run these commands in sequence
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
apt-get install --reinstall lightdm
then hit Ctrl+D to exit the chroot environment
Then reboot and see if you can log into Ubuntu.
