Problem with Libre Office Base Impress and Draw
Hi All,
I want to do a mail merge of some docs. and find when I go to the Office Suite the Base, Impress and Draw buttons are there but they don’t work. It seems as if they are not installed. Do I need to install them from somewhere ?
take care
Don W
EDIT I have used apt get to install Base and it looks ok.
Impress and Draw I will leave for another day
You can get the full LO suite with
sudo apt-get install libreoffice
in an Ubuntu based distro.
Thanks Mark, I will try that
