Hi, I seem to be having the same problem in Mint 10 I had in Ubuntu 11 the system thinks my modem is a USB hard drive.
usertwo@mobileone ~ $ lsusb
Bus 003 Device 003: ID 0dda:0001 Integrated Circuit Solution, Inc. Multi-Card Reader 6in1
Bus 003 Device 002: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 002: ID 05c6:1000 Qualcomm, Inc. Mass Storage Device
The modem is listed Bus 002 Device 002: ID 05c6:1000 Qualcomm, Inc. Mass Storage Device
I have installed the most up-to-date USB Modeswitch that I can find and this has not solved the problem.
The fix you provided last time (for the Qualcomm, Inc model Globesurfer i CON 7.2S) is also not working as when I try using it the fix is not installed.
I’ve added it to a custom configPack.tar .gz, as used in the newer version of usb-modeswitch-data … So download the custom version:
cd ~
wget http://dl.dropbox.com/u/11876059/configPack.tar.gz
Now rename your old configPack.tar.gz to backup-configPack.tar.gz:
sudo mv -v /usr/share/usb_modeswitch/configPack.tar.gz /usr/share/usb_modeswitch/backup-configPack.tar.gz
Now copy the new configPack.tar .gz to /usr/share/usb_modeswitch:
sudo cp -v ~/configPack.tar.gz /usr/share/usb_modeswitch/configPack.tar.gz
Now you may have to reboot, or you may only have to unplug the dongle, wait a few seconds, then replug it… I’m not sure.<<
This is what happens if I try this fix -
usertwo@mobileone ~ $ sudo mv -v /usr/share/usb_modeswitch/configPack.tar.gz /usr/share/usb_modeswitch/backup-configPack.tar.gz
[sudo] password for usertwo:
mv: cannot stat /usr/share/usb_modeswitch/configPack.tar.gz': No such file or directory usertwo@mobileone ~ $ sudo cp -v ~/configPack.tar.gz /usr/share/usb_modeswitch/configPack.tar.gz
/home/usertwo/configPack.tar.gz’ → /usr/share/usb_modeswitch/configPack.tar.gz' cp: cannot create regular file
/usr/share/usb_modeswitch/configPack.tar.gz’: No such file or directory
What do you think.
If you open /usr/share/usb_modeswitch in nautilus:
nautilus /usr/share/usb_modeswitch
are there a bunch of files in there with names like
0421:060c
etc.
Hi,
I get an error can not find…
How did you install usb-modeswitch ?
If through Synaptic… fire up synaptic, search for usb-modeswitch-data
First check it is installed.
then right click it, and select Properties, then the Installed Files (tab), and post the list of installed files.
It is shown as installed.
/etc
/etc/usb_modeswitch.d
/etc/usb_modeswitch.d/0421:060c
/etc/usb_modeswitch.d/0421:0610
/etc/usb_modeswitch.d/0471:1210
/etc/usb_modeswitch.d/0471:1237
/etc/usb_modeswitch.d/0482:024d
/etc/usb_modeswitch.d/04e8:689a
/etc/usb_modeswitch.d/04e8:f000
/etc/usb_modeswitch.d/057c:84ff
/etc/usb_modeswitch.d/05c6:1000:sVe=Option
/etc/usb_modeswitch.d/05c6:1000:uMa=AnyDATA
/etc/usb_modeswitch.d/05c6:1000:uMa=Option
/etc/usb_modeswitch.d/05c6:1000:uMa=SAMSUNG
/etc/usb_modeswitch.d/05c6:1000:uMa=Vertex
/etc/usb_modeswitch.d/05c6:2001
/etc/usb_modeswitch.d/05c6:f000
/etc/usb_modeswitch.d/072f:100d
/etc/usb_modeswitch.d/0930:0d46
/etc/usb_modeswitch.d/0ace:2011
/etc/usb_modeswitch.d/0ace:20ff
/etc/usb_modeswitch.d/0af0:6711
/etc/usb_modeswitch.d/0af0:6731
/etc/usb_modeswitch.d/0af0:6751
/etc/usb_modeswitch.d/0af0:6771
/etc/usb_modeswitch.d/0af0:6791
/etc/usb_modeswitch.d/0af0:6811
/etc/usb_modeswitch.d/0af0:6911
/etc/usb_modeswitch.d/0af0:6951
/etc/usb_modeswitch.d/0af0:6971
/etc/usb_modeswitch.d/0af0:7011
/etc/usb_modeswitch.d/0af0:7031
/etc/usb_modeswitch.d/0af0:7051
/etc/usb_modeswitch.d/0af0:7071
/etc/usb_modeswitch.d/0af0:7111
/etc/usb_modeswitch.d/0af0:7211
/etc/usb_modeswitch.d/0af0:7251
/etc/usb_modeswitch.d/0af0:7271
/etc/usb_modeswitch.d/0af0:7301
/etc/usb_modeswitch.d/0af0:7311
/etc/usb_modeswitch.d/0af0:7361
/etc/usb_modeswitch.d/0af0:7381
/etc/usb_modeswitch.d/0af0:7401
/etc/usb_modeswitch.d/0af0:7501
/etc/usb_modeswitch.d/0af0:7601
/etc/usb_modeswitch.d/0af0:7701
/etc/usb_modeswitch.d/0af0:7801
/etc/usb_modeswitch.d/0af0:7901
/etc/usb_modeswitch.d/0af0:8200
/etc/usb_modeswitch.d/0af0:8201
/etc/usb_modeswitch.d/0af0:8300
/etc/usb_modeswitch.d/0af0:8302
/etc/usb_modeswitch.d/0af0:8304
/etc/usb_modeswitch.d/0af0:8400
/etc/usb_modeswitch.d/0af0:c031
/etc/usb_modeswitch.d/0af0:c100
/etc/usb_modeswitch.d/0af0:d013
/etc/usb_modeswitch.d/0af0:d031
/etc/usb_modeswitch.d/0af0:d033
/etc/usb_modeswitch.d/0af0:d035
/etc/usb_modeswitch.d/0af0:d055
/etc/usb_modeswitch.d/0af0:d057
/etc/usb_modeswitch.d/0af0:d058
/etc/usb_modeswitch.d/0af0:d155
/etc/usb_modeswitch.d/0af0:d157
/etc/usb_modeswitch.d/0af0:d255
/etc/usb_modeswitch.d/0af0:d257
/etc/usb_modeswitch.d/0af0:d357
/etc/usb_modeswitch.d/0b3c:c700
/etc/usb_modeswitch.d/0b3c:f000
/etc/usb_modeswitch.d/0cf3:20ff
/etc/usb_modeswitch.d/0fce:d0cf
/etc/usb_modeswitch.d/0fce:d0e1
/etc/usb_modeswitch.d/0fce:d103
/etc/usb_modeswitch.d/1004:1000
/etc/usb_modeswitch.d/1004:607f
/etc/usb_modeswitch.d/1004:613a
/etc/usb_modeswitch.d/1004:613f
/etc/usb_modeswitch.d/1033:0035
/etc/usb_modeswitch.d/106c:3b03
/etc/usb_modeswitch.d/106c:3b06
/etc/usb_modeswitch.d/1076:7f40
/etc/usb_modeswitch.d/1199:0fff
/etc/usb_modeswitch.d/1266:1000
/etc/usb_modeswitch.d/12d1:1001
/etc/usb_modeswitch.d/12d1:1003
/etc/usb_modeswitch.d/12d1:101e
/etc/usb_modeswitch.d/12d1:1031
/etc/usb_modeswitch.d/12d1:1414
/etc/usb_modeswitch.d/12d1:1446
/etc/usb_modeswitch.d/12d1:14ad
/etc/usb_modeswitch.d/12d1:14c1
/etc/usb_modeswitch.d/12d1:1520
/etc/usb_modeswitch.d/12d1:1521
/etc/usb_modeswitch.d/12d1:1523
/etc/usb_modeswitch.d/12d1:1557
/etc/usb_modeswitch.d/1410:5010
/etc/usb_modeswitch.d/1410:5020
/etc/usb_modeswitch.d/1410:5030
/etc/usb_modeswitch.d/1410:5031
/etc/usb_modeswitch.d/1410:5041
/etc/usb_modeswitch.d/148f:2578
/etc/usb_modeswitch.d/16d8:6803
/etc/usb_modeswitch.d/16d8:6803:?
/etc/usb_modeswitch.d/16d8:700a
/etc/usb_modeswitch.d/16d8:f000
/etc/usb_modeswitch.d/198f:bccd
/etc/usb_modeswitch.d/19d2:0003
/etc/usb_modeswitch.d/19d2:0026
/etc/usb_modeswitch.d/19d2:0040
/etc/usb_modeswitch.d/19d2:0053
/etc/usb_modeswitch.d/19d2:0083
/etc/usb_modeswitch.d/19d2:0101
/etc/usb_modeswitch.d/19d2:0103
/etc/usb_modeswitch.d/19d2:0115
/etc/usb_modeswitch.d/19d2:1001
/etc/usb_modeswitch.d/19d2:1007
/etc/usb_modeswitch.d/19d2:1009
/etc/usb_modeswitch.d/19d2:1013
/etc/usb_modeswitch.d/19d2:2000
/etc/usb_modeswitch.d/19d2:fff5
/etc/usb_modeswitch.d/19d2:fff6
/etc/usb_modeswitch.d/1a8d:1000
/etc/usb_modeswitch.d/1a8d:1000:uPr=5G
/etc/usb_modeswitch.d/1ab7:5700
/etc/usb_modeswitch.d/1b7d:0700
/etc/usb_modeswitch.d/1bbb:f000
/etc/usb_modeswitch.d/1c9e:1001
/etc/usb_modeswitch.d/1c9e:9200
/etc/usb_modeswitch.d/1c9e:9e00
/etc/usb_modeswitch.d/1c9e:f000
/etc/usb_modeswitch.d/1dd6:1000
/etc/usb_modeswitch.d/1e0e:f000
/etc/usb_modeswitch.d/1ee8:0009
/etc/usb_modeswitch.d/1ee8:0013
/etc/usb_modeswitch.d/1f28:0021
/etc/usb_modeswitch.d/1fac:0130
/lib
/lib/udev
/lib/udev/rules.d
/lib/udev/rules.d/40-usb_modeswitch.rules
/usr
/usr/share
/usr/share/bug
/usr/share/bug/usb-modeswitch-data
/usr/share/bug/usb-modeswitch-data/presubj
/usr/share/doc
/usr/share/doc/usb-modeswitch-data
/usr/share/doc/usb-modeswitch-data/NEWS.Debian.gz
/usr/share/doc/usb-modeswitch-data/README
/usr/share/doc/usb-modeswitch-data/changelog.Debian.gz
/usr/share/doc/usb-modeswitch-data/copyright
OK, find the configPack.tar.gz you downloaded, and unpack the 05c6:1000:sVe=GT file from it, and put that file in the /etc/usb_modeswitch.d directory.
If you need instructions, just ask
Instructions… just in case
cd ~
sudo tar -xvzf configPack.tar.gz --directory /etc/usb_modeswitch.d 05c6:1000:sVe=GT
Unplug the dongle, wait a few seconds, then replug it.
(may require a logoff/logon, or reboot, but I doubt it)
For future readers… this fix is for the Qualcomm Inc, model Globesurfer i CON 7.2S 3G USB dongle.
Original topic (and fix for Ubuntu 11.04) can be seen here:
http://linuxforums.org.uk/ubuntu/problem-internet-connection-with-3g-dongel-runing-11-4-classic/
Working fine now, like to have 3G available on my computers if the cable broad band fails. It was off Sat - Sun for 15 hours.
Thanks yet again.
