It appears that “BT wifi” is unprotectd (public) so it will connect without encryption.
See if it connects to Plusnet if you temporaily disable protection.
If that works then see if wpa_supplicant is installed.
Nope
Disabled protection and it still wont connect :-\
cant say we are not trying…
When you say it won’t connect … what exactly fo you mean ? … and can you walk me through what it is you’re doing to try connect, and what it’s asking you for ?
(obviously don’t post your password/key)
First (in your router) change your wireless channel to channel 8 … there a multiple networks on channel1 (and 6 and 11).
Then see if your router is set to wireless “N” ONLY ? … if it is, try changing it to “G” or any setting that includes “G” (54Mbps)
Heres my router stats Tried loads of cjans inc auto but didnt help. Putring cursor over wireless link says "connecting to wireless" then just drops to "no connection" ?
Wireless Access Point - PlusnetWireless9BBB7F
Configuration
Interface Enabled: Yes
Power Reduction Enabled: No
Physical Address: 58:98:35:9b:bb:7f
Network Name (SSID): PlusnetWireless9BBB7F
Interface Type: 802.11b/g/n
Actual Speed [Mbps]: 130
Band: 2.4GHz
Channel Selection: Manual
Region: Europe
Channel: 10
Allow multicast from Broadband Network: Yes
WMM: Enabled
Security
Broadcast Network Name: Yes
Allow New Devices: New stations are allowed (automatically)
Security Mode: WPA-PSK
WPA-PSK Preshared Key:
WPA-PSK Encryption: AES
WPA-PSK Version: WPA2
the interface is all types G/N/etc
Are you using NetworkManager, or WiCD ?
Try deleting ALL wireless connection profiles, and recreating one for your network.
You might also want to see if disabling WMM helps.
Im using network manager
Ive discovered it wil connect on WEP encrytion on both Ralink and Router but not WPA/WPA2?
what’s the output from:
dpkg -l | grep wpa
dpkg -l | grep wpa
ii wpasupplicant 1.0-3ubuntu1 i386 client support for WPA and WPA2 (IEEE 802.11i)
Hmm … I’m baffled then, I definitely set
HAS_WPA_SUPPLICANT=y
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y
in the drivers I uploaded.
You did download the drivers from my dropbox, and not directly from Ralink ?
Yep I only used the one you kindly provided from dropbox.
I also discovered how to open the driver and yes both the "y"s are there…stranger than strange…
have you tried disabling WMM in the router ? … though quite how that would affect encryption I don’t know ???
this is the config.mk file:
Support ATE function
HAS_ATE=n
Support QA ATE function
HAS_QA_SUPPORT=n
HAS_RSSI_FEEDBACK=n
Support XLINK mode
HAS_XLINK=n
HAS_NINTENDO=n
Support LLTD function
HAS_LLTD=n
Support WDS function
HAS_WDS=n
Support AP-Client function
HAS_APCLI=n
Support Wpa_Supplicant
i.e. wpa_supplicant -Dralink
Support Native WpaSupplicant for Network Maganger
i.e. wpa_supplicant -Dwext
what if user want to use wpa_supplicant to serve P2P function/feature,
in case, it must use Ralink Propriectary wpa_supplicant to do.
and this compile flag will report P2P Related Event to Ralink wpa_supplicant.
#Support Net interface block while Tx-Sw queue full
HAS_BLOCK_NET_IF=n
#Support IGMP-Snooping function.
HAS_IGMP_SNOOP_SUPPORT=n
#Support DFS function
HAS_DFS_SUPPORT=n
#Support Carrier-Sense function
HAS_CS_SUPPORT=n
Support user specific transmit rate of Multicast packet.
HAS_MCAST_RATE_SPECIFIC_SUPPORT=n
Support for Multiple Cards
HAS_MC_SUPPORT=n
#Support for PCI-MSI
HAS_MSI_SUPPORT=n
#Support for IEEE802.11e DLS
HAS_QOS_DLS_SUPPORT=n
#Support for EXT_CHANNEL
HAS_EXT_BUILD_CHANNEL_LIST=n
#Support for IDS
HAS_IDS_SUPPORT=n
#Support for Net-SNMP
HAS_SNMP_SUPPORT=n
#Support features of 802.11n Draft3
HAS_DOT11N_DRAFT3_SUPPORT=y
#Support features of Single SKU.
HAS_SINGLE_SKU_SUPPORT=n
HAS_DOT11_N_SUPPORT=y
#Support for 2860/2880 co-exist
HAS_RT2880_RT2860_COEXIST=n
HAS_KTHREAD_SUPPORT=n
#Support for WiFi Display
HAS_WFD_SUPPORT=n
#Support for Auto channel select enhance
HAS_AUTO_CH_SELECT_ENHANCE=n
#Support statistics count
HAS_STATS_COUNT=y
#Support TSSI Antenna Variation
HAS_TSSI_ANTENNA_VARIATION=n
#Support USB_BULK_BUF_ALIGMENT
HAS_USB_BULK_BUF_ALIGMENT=n
#Support for USB_SUPPORT_SELECTIVE_SUSPEND
HAS_USB_SUPPORT_SELECTIVE_SUSPEND=n
#Support USB load firmware by multibyte
HAS_USB_FIRMWARE_MULTIBYTE_WRITE=n
#Support ANDROID_SUPPORT
HAS_ANDROID_SUPPORT=n
#HAS_IFUP_IN_PROBE_SUPPORT
HAS_IFUP_IN_PROBE_SUPPORT=n
#Support TXRX SW Antenna Diversity
HAS_TXRX_SW_ANTDIV_SUPPORT=n
#Client support WDS function
HAS_CLIENT_WDS_SUPPORT=n
#Support for Bridge Fast Path & Bridge Fast Path function open to other module
HAS_BGFP_SUPPORT=n
HAS_BGFP_OPEN_SUPPORT=n
Support HOSTAPD function
HAS_HOSTAPD_SUPPORT=n
#Support GreenAP function
HAS_GREENAP_SUPPORT=n
#Support MAC80211 LINUX-only function
#Please make sure the version for CFG80211.ko and MAC80211.ko is same as the one
#our driver references to.
HAS_CFG80211_SUPPORT=n
#Support RFKILL hardware block/unblock LINUX-only function
HAS_RFKILL_HW_SUPPORT=n
HAS_APCLI_WPA_SUPPLICANT=n
HAS_RTMP_FLASH_SUPPORT=n
ifeq ($(OSABL),YES)
HAS_OSABL_FUNC_SUPPORT=y
HAS_OSABL_OS_PCI_SUPPORT=y
HAS_OSABL_OS_USB_SUPPORT=y
HAS_OSABL_OS_RBUS_SUPPORT=n
HAS_OSABL_OS_AP_SUPPORT=y
HAS_OSABL_OS_STA_SUPPORT=y
endif
HAS_LED_CONTROL_SUPPORT=y
#Support WIDI feature
#Must enable HAS_WSC at the same time.
HAS_STREAM_MODE_SUPPORT=n
HAS_NEW_RATE_ADAPT_SUPPORT=n
#RT5572 RT5592
HAS_TSO_SUPPORT=n
HAS_SWITCH_CHANNEL_OFFLOAD=n
HAS_RESOURCE_PRE_ALLOC=n
HAS_RESOURCE_BOOT_ALLOC=n
HAS_NEW_MBSSID_MODE=y
HAS_MULTI_CHANNEL=n
CC := $(CROSS_COMPILE)gcc
LD := $(CROSS_COMPILE)ld
WFLAGS := -DAGGREGATION_SUPPORT -DPIGGYBACK_SUPPORT -DWMM_SUPPORT -DLINUX -Wall -Wstrict-prototypes -Wno-trigraphs
WFLAGS += -DSYSTEM_LOG_SUPPORT -DRT28xx_MODE=$(RT28xx_MODE) -DCHIPSET=$(MODULE)
#-DRESOURCE_PRE_ALLOC
ifeq ($(HAS_RESOURCE_PRE_ALLOC),y)
WFLAGS += -DRESOURCE_PRE_ALLOC
endif
ifeq ($(HAS_RESOURCE_BOOT_ALLOC),y)
WFLAGS += -DRESOURCE_BOOT_ALLOC -I$(LINUX_SRC)/include/linux/usb -I$(LINUX_SRC)/drivers/usb/core
endif
#APsoc Specific
WFLAGS += -DCONFIG_RA_NAT_NONE
#end of /* APsoc Specific */
ifeq ($(HAS_KTHREAD_SUPPORT),y)
WFLAGS += -DKTHREAD_SUPPORT
endif
ifeq ($(HAS_RTMP_FLASH_SUPPORT),y)
WFLAGS += -DRTMP_FLASH_SUPPORT
endif
ifeq ($(HAS_STREAM_MODE_SUPPORT),y)
WFLAGS += -DSTREAM_MODE_SUPPORT
endif
ifeq ($(HAS_SINGLE_SKU_SUPPORT),y)
WFLAGS += -DSINGLE_SKU
endif
config for STA mode
ifeq ($(RT28xx_MODE),STA)
WFLAGS += -DCONFIG_STA_SUPPORT -DDBG
ifeq ($(HAS_XLINK),y)
WFLAGS += -DXLINK_SUPPORT
endif
ifeq ($(HAS_WPA_SUPPLICANT),y)
WFLAGS += -DWPA_SUPPLICANT_SUPPORT
ifeq ($(HAS_NATIVE_WPA_SUPPLICANT_SUPPORT),y)
WFLAGS += -DNATIVE_WPA_SUPPLICANT_SUPPORT
endif
endif
ifeq ($(HAS_ATE),y)
WFLAGS += -DRALINK_ATE
WFLAGS += -DCONFIG_RT2880_ATE_CMD_NEW
WFLAGS += -I$(RT28xx_DIR)/ate/include
ifeq ($(HAS_QA_SUPPORT),y)
WFLAGS += -DRALINK_QA
endif
endif
ifeq ($(HAS_SNMP_SUPPORT),y)
WFLAGS += -DSNMP_SUPPORT
endif
ifeq ($(HAS_USB_BULK_BUF_ALIGMENT),y)
WFLAGS += -DUSB_BULK_BUF_ALIGMENT -DALIGMENT_BULKAGGRE_SIZE=14 -DBUF_ALIGMENT_RINGSIZE=3
endif
ifeq ($(HAS_QOS_DLS_SUPPORT),y)
WFLAGS += -DQOS_DLS_SUPPORT
endif
ifeq ($(HAS_DOT11_N_SUPPORT),y)
WFLAGS += -DDOT11_N_SUPPORT
ifeq ($(HAS_DOT11N_DRAFT3_SUPPORT),y)
WFLAGS += -DDOT11N_DRAFT3
endif
ifeq ($(HAS_NEW_RATE_ADAPT_SUPPORT),y)
WFLAGS += -DNEW_RATE_ADAPT_SUPPORT
endif
endif
ifeq ($(HAS_WFD_SUPPORT),y)
HAS_P2P_SUPPORT=y
HAS_P2P_SPECIFIC_WIRELESS_EVENT=y
WFLAGS += -DWFD_SUPPORT
endif
ifeq ($(HAS_CS_SUPPORT),y)
WFLAGS += -DCARRIER_DETECTION_SUPPORT
endif
ifeq ($(HAS_STATS_COUNT),y)
WFLAGS += -DSTATS_COUNT_SUPPORT
endif
ifeq ($(HAS_TSSI_ANTENNA_VARIATION),y)
WFLAGS += -DTSSI_ANTENNA_VARIATION
endif
ifeq ($(HAS_ANDROID_SUPPORT),y)
WFLAGS += -DANDROID_SUPPORT
endif
ifeq ($(HAS_IFUP_IN_PROBE_SUPPORT),y)
WFLAGS += -DIFUP_IN_PROBE
endif
ifeq ($(HAS_USB_SUPPORT_SELECTIVE_SUSPEND),y)
WFLAGS += -DUSB_SUPPORT_SELECTIVE_SUSPEND
endif
ifeq ($(HAS_USB_FIRMWARE_MULTIBYTE_WRITE),y)
WFLAGS += -DUSB_FIRMWARE_MULTIBYTE_WRITE -DMULTIWRITE_BYTES=4
endif
ifeq ($(HAS_CFG80211_SUPPORT),y)
WFLAGS += -DRT_CFG80211_SUPPORT -DEXT_BUILD_CHANNEL_LIST
ifeq ($(HAS_RFKILL_HW_SUPPORT),y)
WFLAGS += -DRFKILL_HW_SUPPORT
endif
endif
ifeq ($(OSABL),YES)
WFLAGS += -DOS_ABL_SUPPORT
ifeq ($(HAS_OSABL_FUNC_SUPPORT),y)
WFLAGS += -DOS_ABL_FUNC_SUPPORT
endif
ifeq ($(HAS_OSABL_OS_PCI_SUPPORT),y)
WFLAGS += -DOS_ABL_OS_PCI_SUPPORT
endif
ifeq ($(HAS_OSABL_OS_USB_SUPPORT),y)
WFLAGS += -DOS_ABL_OS_USB_SUPPORT
endif
ifeq ($(HAS_OSABL_OS_RBUS_SUPPORT),y)
WFLAGS += -DOS_ABL_OS_RBUS_SUPPORT
endif
ifeq ($(HAS_OSABL_OS_AP_SUPPORT),y)
WFLAGS += -DOS_ABL_OS_AP_SUPPORT
endif
ifeq ($(HAS_OSABL_OS_STA_SUPPORT),y)
WFLAGS += -DOS_ABL_OS_STA_SUPPORT
endif
endif
ifeq ($(HAS_TXRX_SW_ANTDIV_SUPPORT),y)
WFLAGS += -DTXRX_SW_ANTDIV_SUPPORT
endif
ifeq ($(HAS_WIDI_SUPPORT),y)
WFLAGS += -DWIDI_SUPPORT
ifeq ($(HAS_INTEL_L2SD_TOGGLE_SCAN_SUPPORT),y)
WFLAGS += -DINTEL_L2SD_TOGGLE_SCAN_SUPPORT
endif
ifeq ($(HAS_P2P_SUPPORT),y)
ifeq ($(HAS_INTEL_WFD_SUPPORT),y)
WFLAGS += -DINTEL_WFD_SUPPORT
endif
ifeq ($(HAS_WFA_WFD_SUPPORT),y)
WFLAGS += -DWFA_WFD_SUPPORT
endif
endif
endif
ifeq ($(HAS_WOW_IFDOWN_SUPPORT),y)
WFLAGS += -DWOW_IFDOWN_SUPPORT
endif
endif
endif of ifeq ($(RT28xx_MODE),STA)
Common compiler flag
ifeq ($(HAS_EXT_BUILD_CHANNEL_LIST),y)
WFLAGS += -DEXT_BUILD_CHANNEL_LIST
endif
ifeq ($(HAS_IDS_SUPPORT),y)
WFLAGS += -DIDS_SUPPORT
endif
ifeq ($(OSABL),YES)
WFLAGS += -DEXPORT_SYMTAB
endif
ifeq ($(HAS_CLIENT_WDS_SUPPORT),y)
WFLAGS += -DCLIENT_WDS
endif
ifeq ($(HAS_BGFP_SUPPORT),y)
WFLAGS += -DBG_FT_SUPPORT
endif
ifeq ($(HAS_BGFP_OPEN_SUPPORT),y)
WFLAGS += -DBG_FT_OPEN_SUPPORT
endif
ifeq ($(HAS_LED_CONTROL_SUPPORT),y)
WFLAGS += -DLED_CONTROL_SUPPORT
endif
ifeq ($(HAS_SWITCH_CHANNEL_OFFLOAD), y)
WFLAGS += -DCONFIG_SWITCH_CHANNEL_OFFLOAD
endif
ifeq ($(HAS_MULTI_CHANNEL),y)
WFLAGS += -DCONFIG_SWITCH_CHANNEL_OFFLOAD -DCONFIG_MULTI_CHANNEL
endif
ChipSet specific definitions.
ifneq ($(findstring 2860,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRTMP_PCI_SUPPORT -DRT2860 -DRT28xx -DA_BAND_SUPPORT
CHIPSET_DAT = 2860
endif
ifneq ($(findstring 3090,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRT30xx -DRT3090 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2860
endif
ifneq ($(findstring 2870,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRTMP_USB_SUPPORT -DRT2870 -DRT28xx -DRTMP_TIMER_TASK_SUPPORT -DA_BAND_SUPPORT
CHIPSET_DAT = 2870
endif
ifneq ($(findstring 2070,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRT30xx -DRT3070 -DRT2070 -DRTMP_USB_SUPPORT -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT
CHIPSET_DAT = 2870
endif
ifneq ($(findstring 3070,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRT30xx -DRT3070 -DRTMP_USB_SUPPORT -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2870
ifneq ($(findstring $(RT28xx_MODE),AP),)
ifeq ($(HAS_CS_SUPPORT), y)
WFLAGS += -DCARRIER_DETECTION_FIRMWARE_SUPPORT
endif
endif
endif
ifneq ($(findstring 2880,$(CHIPSET)),)
WFLAGS += -DRT2880 -DRT28xx -DRTMP_MAC_PCI -DCONFIG_RALINK_RT2880_MP -DRTMP_RBUS_SUPPORT -DMERGE_ARCH_TEAM -DA_BAND_SUPPORT -DCONFIG_SWMCU_SUPPORT
ifeq ($(HAS_WIFI_LED_SHARE), y)
WFLAGS += -DCONFIG_WIFI_LED_SHARE
endif
endif
ifneq ($(findstring 3572,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRTMP_USB_SUPPORT -DRT2870 -DRT28xx -DRT30xx -DRT35xx -DRT3572 -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DA_BAND_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2870
endif
endif
endif
ifneq ($(findstring 3573,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_USB -DRTMP_USB_SUPPORT -DRT30xx -DRT35xx -DRT3593 -DRT3573
-DA_BAND_SUPPORT -DDOT11N_SS3_SUPPORT
-DVCORECAL_SUPPORT
ifeq ($(HAS_NEW_MBSSID_MODE),y)
WFLAGS += -DNEW_MBSSID_MODE
endif
#WFLAGS += -DNEW_RATE_ADAPT_SUPPORT
CHIPSET_DAT = 2870
ifneq ($(findstring $(RT28xx_MODE),STA APSTA),)
WFLAGS += -DRTMP_FREQ_CALIBRATION_SUPPORT
endif
WFLAGS += -DSPECIFIC_BCN_BUF_SUPPORT
endif
endif
endif
endif
ifneq ($(findstring 3062,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRT2860 -DRT28xx -DRT30xx -DRT35xx -DRT3062 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2860
endif
ifneq ($(findstring 3562,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRT2860 -DRT28xx -DRT30xx -DRT35xx -DRT3562 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DA_BAND_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2860
endif
ifneq ($(findstring 3593,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DDOT11N_SS3_SUPPORT -DRT3593 -DRT28xx -DRT30xx -DRT35xx -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DA_BAND_SUPPORT -DVCORECAL_SUPPORT
endif
CHIPSET_DAT = 2860
endif
endif
endif
ifneq ($(findstring 3390,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRT30xx -DRT33xx -DRT3090 -DRT3390 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DRTMP_INTERNAL_TX_ALC -DVCORECAL_SUPPORT
CHIPSET_DAT = 2860
endif
ifneq ($(findstring 3370,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRT30xx -DRT33xx -DRT3070 -DRT3370 -DRTMP_USB_SUPPORT -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DRTMP_INTERNAL_TX_ALC -DVCORECAL_SUPPORT
CHIPSET_DAT = 2870
endif
endif
endif
ifneq ($(findstring 5390,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_PCI -DRT30xx -DRT33xx -DRT3090 -DRT3390 -DRT5390 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DRTMP_FREQ_CALIBRATION_SUPPORT -DRTMP_INTERNAL_TX_ALC -DVCORECAL_SUPPORT -DIQ_CAL_SUPPORT -DRTMP_TEMPERATURE_COMPENSATION
endif
CHIPSET_DAT = 2860
endif
endif
ifneq ($(findstring 5370,$(CHIPSET)),)
WFLAGS +=-DRTMP_MAC_USB -DRT30xx -DRT33xx -DRT3070 -DRT3370 -DRT5370 -DRTMP_USB_SUPPORT -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DRTMP_INTERNAL_TX_ALC -DRTMP_FREQ_CALIBRATION_SUPPORT -DVCORECAL_SUPPORT -DIQ_CAL_SUPPORT -DRTMP_TEMPERATURE_COMPENSATION
endif
CHIPSET_DAT = 2870
endif
endif
endif
endif
ifneq ($(findstring 3052,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_PCI -DRTMP_RBUS_SUPPORT -DRT3052 -DRT305x -DRTMP_RF_RW_SUPPORT -DCONFIG_SWMCU_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2870
endif
endif
ifneq ($(findstring 3352,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_PCI -DRTMP_RBUS_SUPPORT -DRT3352 -DRT305x -DRTMP_RF_RW_SUPPORT -DVCORECAL_SUPPORT -DCONFIG_SWMCU_SUPPORT -DRTMP_INTERNAL_TX_ALC
endif
CHIPSET_DAT = 2860
endif
endif
endif
ifneq ($(findstring 5350,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_PCI -DRTMP_RBUS_SUPPORT -DRT5350 -DRT305x -DRT3050 -DRT3350 -DRTMP_RF_RW_SUPPORT -DVCORECAL_SUPPORT -DCONFIG_SWMCU_SUPPORT -DRTMP_INTERNAL_TX_ALC -DRTMP_FREQ_CALIBRATION_SUPPORT -DIQ_CAL_SUPPORT
endif
CHIPSET_DAT = 2860
endif
endif
endif
ifneq ($(findstring 5592,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_PCI -DRTMP_PCI_SUPPORT -DRT30xx -DRT5592
-DA_BAND_SUPPORT -DIQ_CAL_SUPPORT -DRX_DMA_SCATTER -DVCORECAL_SUPPORT
endif
CHIPSET_DAT = 2860
ifeq ($(HAS_TSO_SUPPORT), y)
WFLAGS += -DCONFIG_TSO_SUPPORT
endif
endif
endif
endif
ifneq ($(findstring 5572,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_USB -DRTMP_USB_SUPPORT -DRT30xx -DRT5572 -DRT5592
-DRTMP_TIMER_TASK_SUPPORT -DA_BAND_SUPPORT -DIQ_CAL_SUPPORT -DVCORECAL_SUPPORT
CHIPSET_DAT = 2870
endif
endif
endif
endif
#WFLAGS += -DSPECIFIC_BCN_BUF_SUPPORT
endif
endif
ifneq ($(findstring 3290,$(CHIPSET)),)
WFLAGS += -DRTMP_MAC_PCI -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DRTMP_FREQ_CALIBRATION_SUPPORT -DRTMP_INTERNAL_TX_ALC -DRT30xx -DRT3290 -DVCORECAL_SUPPORT
CHIPSET_DAT = 2860
WFLAGS += -DRTMP_FREQ_CALIBRATION_SUPPORT -DPCIE_PS_SUPPORT
endif
endif
endif
ifeq ($(CHIPSET),USB)
#3572
WFLAGS +=-DRTMP_MAC_USB -DRTMP_USB_SUPPORT -DRT2870 -DRT28xx -DRT30xx -DRT35xx -DRTMP_TIMER_TASK_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DA_BAND_SUPPORT -DSPECIFIC_VCORECAL_SUPPORT
#3370
WFLAGS += -DRT33xx -DRT3070 -DRT3370 -DRTMP_TIMER_TASK_SUPPORT -DRTMP_INTERNAL_TX_ALC
CHIPSET_DAT = 2870
endif
ifeq ($(CHIPSET),PCI)
#3562
WFLAGS +=-DRTMP_MAC_PCI -DRT2860 -DRT28xx -DRT30xx -DRT35xx -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DRTMP_EFUSE_SUPPORT -DA_BAND_SUPPORT -DSPECIFIC_VCORECAL_SUPPORT
#3390
WFLAGS +=-DRT33xx -DRT3090 -DRT3390 -DRTMP_INTERNAL_TX_ALC
endif
ifeq ($(CHIPSET),RBUS)
WFLAGS += -DMERGE_ARCH_TEAM -DCONFIG_SWMCU_SUPPORT -DCONFIG_RA_NAT_NONE -DRTMP_RBUS_SUPPORT
#5350, 3050, 3350, 3883
WFLAGS +=-DRTMP_MAC_PCI -DRT305x -DRT5350 -DRT3050 -DRT3350 -DRT3883 -DRTMP_PCI_SUPPORT -DRTMP_RF_RW_SUPPORT -DA_BAND_SUPPORT -DVCORECAL_SUPPORT
endif
#WFLAGS += -DDBG_CTRL_SUPPORT
#WFLAGS += -DINCLUDE_DEBUG_QUEUE
#WFLAGS += -DRANGE_EXTEND -DCFO_TRACK -DPRE_ANT_SWITCH
endif
ifeq ($(PLATFORM),5VT)
#WFLAGS += -DCONFIG_5VT_ENHANCE
endif
ifeq ($(HAS_BLOCK_NET_IF),y)
WFLAGS += -DBLOCK_NET_IF
endif
ifeq ($(HAS_DFS_SUPPORT),y)
WFLAGS += -DDFS_SUPPORT
endif
ifeq ($(HAS_MC_SUPPORT),y)
WFLAGS += -DMULTIPLE_CARD_SUPPORT
endif
ifeq ($(HAS_LLTD),y)
WFLAGS += -DLLTD_SUPPORT
endif
ifeq ($(PLATFORM),RMI)
WFLAGS += -DRT_BIG_ENDIAN
endif
ifeq ($(PLATFORM),UBICOM_IPX8)
WFLAGS += -DRT_BIG_ENDIAN -DUNALIGNMENT_SUPPORT -DPLATFORM_UBM_IPX8 -DNO_CONSISTENT_MEM_SUPPORT -DCACHE_LINE_32B
endif
ifeq ($(PLATFORM),BL2348)
endif
ifeq ($(PLATFORM),BL23570)
endif
ifeq ($(PLATFORM),BLUBB)
endif
ifeq ($(PLATFORM),BLPMP)
endif
ifeq ($(PLATFORM),RMI_64)
endif
ifeq ($(PLATFORM),IXP)
endif
ifeq ($(PLATFORM),IKANOS_V160)
WFLAGS += -DRT_BIG_ENDIAN -DIKANOS_VX_1X0
endif
ifeq ($(PLATFORM),IKANOS_V180)
endif
ifeq ($(PLATFORM),INF_TWINPASS)
WFLAGS += -DRT_BIG_ENDIAN -DINF_TWINPASS
endif
ifeq ($(PLATFORM),INF_DANUBE)
ifneq (,$(findstring 2.4,$(LINUX_SRC)))
Linux 2.4
WFLAGS += -DINF_DANUBE -DRT_BIG_ENDIAN
else
Linux 2.6
endif
endif
ifeq ($(PLATFORM),INF_AR9)
WFLAGS += -DRT_BIG_ENDIAN -DINF_AR9
support MAPI function for AR9.
#WFLAGS += -DAR9_MAPI_SUPPORT
endif
ifeq ($(PLATFORM),INF_VR9)
WFLAGS += -DRT_BIG_ENDIAN -DINF_AR9 -DINF_VR9
endif
ifeq ($(PLATFORM),CAVM_OCTEON)
endif
ifeq ($(PLATFORM),BRCM_6358)
WFLAGS += -DRT_BIG_ENDIAN -DBRCM_6358
endif
ifeq ($(PLATFORM),INF_AMAZON_SE)
WFLAGS += -DRT_BIG_ENDIAN -DINF_AMAZON_SE
endif
ifeq ($(PLATFORM),RALINK_3052)
WFLAGS += -DPLATFORM_RALINK_3052
endif
ifeq ($(PLATFORM),FREESCALE8377)
#EXTRA_CFLAGS := -v -I$(RT28xx_DIR)/include -I$(LINUX_SRC)/include $(WFLAGS)-O2 -Wall -Wstrict-prototypes -Wno-trigraphs
#export EXTRA_CFLAGS
EXTRA_CFLAGS := $(WFLAGS) -I$(RT28xx_DIR)/include
endif
ifeq ($(PLATFORM),ST)
#WFLAGS += -DST
WFLAGS += -DST
endif
#kernel build options for 2.4
move to Makefile outside LINUX_SRC := /opt/star/kernel/linux-2.4.27-star
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -finline-limit=100000 -march=mips2 -mabi=32 -Wa,–trap -DLINUX -nostdinc -iwithprefix include $(WFLAGS)
export CFLAGS
endif
ifeq ($(PLATFORM), RALINK_2880)
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -finline-limit=100000 -march=mips2 -mabi=32 -Wa,–trap -DLINUX -nostdinc -iwithprefix include $(WFLAGS)
export CFLAGS
endif
ifeq ($(PLATFORM),STAR)
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -Uarm -fno-common -pipe -mapcs-32 -D__LINUX_ARM_ARCH__=4 -march=armv4 -mshort-load-bytes -msoft-float -Uarm -DMODULE -DMODVERSIONS -include $(LINUX_SRC)/include/linux/modversions.h $(WFLAGS)
export CFLAGS
endif
EXTRA_CFLAGS += $(WFLAGS) -I$(RT28xx_DIR)/include
export EXTRA_CFLAGS
endif
ifeq ($(PLATFORM),SIGMA)
CFLAGS := -D__KERNEL__ -I$(RT28xx_DIR)/include -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm/gcc -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -DEM86XX_CHIP=EM86XX_CHIPID_TANGO2 -DEM86XX_REVISION=6 -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT2860_DIR)/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -mabi=32 -march=mips32r2 -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -DMODULE $(WFLAGS) -DSIGMA863X_PLATFORM
export CFLAGS
endif
ifeq ($(PLATFORM),SIGMA_8622)
CFLAGS := -D__KERNEL__ -I$(CROSS_COMPILE_INCLUDE)/include -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fno-common -pipe -fno-builtin -D__linux__ -DNO_MM -mapcs-32 -march=armv4 -mtune=arm7tdmi -msoft-float -DMODULE -mshort-load-bytes -nostdinc -iwithprefix -DMODULE $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -O3 -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mabi=apcs-gnu -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm926ej-s --param max-inline-insns-single=40000 -Uarm -Wdeclaration-after-statement -Wno-pointer-sign -DMODULE $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm/gcc -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT28xx_DIR)/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -march=lx4189 -Wa, -DMODULE $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm/gcc -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT28xx_DIR)/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -mips32r2 -Wa, -DMODULE $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -DMODULE -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fomit-frame-pointer -fno-strict-aliasing -fno-common -G 0 -mno-abicalls -fno-pic -march=4kc -mips32 -Wa,–trap -pipe -mlong-calls $(WFLAGS)
export CFLAGS
endif
CFLAGS := -I$(RT28xx_DIR)/include $(WFLAGS) -Wundef -fno-strict-aliasing -fno-common -ffreestanding -Os -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -mabi=32 -march=mips32 -Wa,-32 -Wa,-march=mips32 -Wa,-mips32 -Wa,–trap -I$(LINUX_SRC)/include/asm-mips/mach-generic
else
CFLAGS := -I$(RT28xx_DIR)/include $(WFLAGS) -Wundef -fno-strict-aliasing -fno-common -ffreestanding -Os -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -mabi=32 -march=mips32r2 -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -I$(LINUX_SRC)/include/asm-mips/mach-generic
endif
export CFLAGS
endif
CFLAGS := -I$(RT28xx_DIR)/include $(WFLAGS) -Wundef -fno-strict-aliasing -fno-common -fno-pic -ffreestanding -Os -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -mabi=32 -mlong-calls -march=mips32r2 -mtune=34kc -march=mips32r2 -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -I$(LINUX_SRC)/include/asm-mips/mach-generic
export CFLAGS
endif
CFLAGS := -I$(RT28xx_DIR)/include $(WFLAGS) -Wundef -fno-strict-aliasing -fno-common -fno-pic -ffreestanding -Os -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -mabi=32 -mlong-calls -march=mips32r2 -march=mips32r2 -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -I$(LINUX_SRC)/include/asm-mips/mach-generic
export CFLAGS
endif
CFLAGS := $(WFLAGS) -I$(RT28xx_DIR)/include -nostdinc -iwithprefix include -D__KERNEL__ -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -I $(LINUX_SRC)/include/asm/gcc -G 0 -mno-abicalls -fno-pic -pipe -finline-limit=100000 -mabi=32 -march=mips32 -Wa,-32 -Wa,-march=mips32 -Wa,-mips32 -Wa,–trap -I$(LINUX_SRC)/include/asm-mips/mach-bcm963xx -I$(LINUX_SRC)/include/asm-mips/mach-generic -Os -fomit-frame-pointer -Wdeclaration-after-statement -DMODULE -mlong-calls
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -DMODULE=1 -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -DCONFIG_IFX_ALG_QOS -DCONFIG_WAN_VLAN_SUPPORT -fomit-frame-pointer -DIFX_PPPOE_FRAME -G 0 -fno-pic -mno-abicalls -mlong-calls -pipe -finline-limit=100000 -mabi=32 -march=mips32 -Wa,-32 -Wa,-march=mips32 -Wa,-mips32 -Wa,–trap -nostdinc -iwithprefix include $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -Wall -O2 -Wundef -Wstrict-prototypes -Wno-trigraphs -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-aliasing -fno-common -fomit-frame-pointer -ffreestanding -m4-nofpu -o $(WFLAGS)
export CFLAGS
endif
ifeq ($(PLATFORM),PC)
# Linux 2.4
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -O2 -fomit-frame-pointer -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=i686 -DMODULE -DMODVERSIONS -include $(LINUX_SRC)/include/linux/modversions.h $(WFLAGS)
export CFLAGS
else
# Linux 2.6
endif
endif
ifeq ($(PLATFORM),INTELP6)
endif
#If the kernel version of RMI is newer than 2.6.27, please change “CFLAGS” to “EXTRA_FLAGS”
EXTRA_CFLAGS := -D__KERNEL__ -DMODULE=1 -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -DCONFIG_IFX_ALG_QOS -DCONFIG_WAN_VLAN_SUPPORT -fomit-frame-pointer -DIFX_PPPOE_FRAME -G 0 -fno-pic -mno-abicalls -mlong-calls -pipe -finline-limit=100000 -mabi=32 -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -march=xlr -ffreestanding -march=xlr -Wa,–trap, -nostdinc -iwithprefix include $(WFLAGS)
export EXTRA_CFLAGS
endif
EXTRA_CFLAGS := -D__KERNEL__ -DMODULE=1 -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT28xx_DIR)/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -DCONFIG_IFX_ALG_QOS -DCONFIG_WAN_VLAN_SUPPORT -fomit-frame-pointer -DIFX_PPPOE_FRAME -G 0 -fno-pic -mno-abicalls -mlong-calls -pipe -finline-limit=100000 -mabi=64 -G 0 -mno-abicalls -fno-pic -pipe -msoft-float -march=xlr -ffreestanding -march=xlr -Wa,–trap, -nostdinc -iwithprefix include $(WFLAGS)
export EXTRA_CFLAGS
endif
CFLAGS := -v -D__KERNEL__ -DMODULE -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -mbig-endian -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -Uarm -fno-common -pipe -mapcs-32 -D__LINUX_ARM_ARCH__=5 -mcpu=xscale -mtune=xscale -malignment-traps -msoft-float $(WFLAGS)
EXTRA_CFLAGS := -v $(WFLAGS) -I$(RT28xx_DIR)/include -mbig-endian
export CFLAGS
endif
ifeq ($(PLATFORM),SMDK)
endif
-mabi=64 $(WFLAGS)
export CFLAGS
endif
ifeq ($(PLATFORM),DM6446)
CFLAGS := -nostdinc -iwithprefix include -D__KERNEL__ -I$(RT28xx_DIR)/include -I$(LINUX_SRC)/include -Wall -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Os -fno-omit-frame-pointer -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mlittle-endian -mabi=apcs-gnu -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm9tdmi -msoft-float -Uarm -Wdeclaration-after-statement -c -o $(WFLAGS)
export CFLAGS
endif
CFLAGS := -D__KERNEL__ -I$(RT28xx_DIR)/include -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm/gcc -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -DEM86XX_CHIP=EM86XX_CHIPID_TANGO2 -DEM86XX_REVISION=6 -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT2860_DIR)/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -mabi=32 -march=mips32r2 -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -DMODULE $(WFLAGS) -DSIGMA863X_PLATFORM -DEXPORT_SYMTAB -DPLATFORM_BL2348
export CFLAGS
endif
EXTRA_CFLAGS := -D__KERNEL__ -I$(RT28xx_DIR)/include -I$(LINUX_SRC)/include -I$(LINUX_SRC)/include/asm/gcc -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -I$(LINUX_SRC)/include/asm-mips/mach-tango2 -DEM86XX_CHIP=EM86XX_CHIPID_TANGO2 -DEM86XX_REVISION=6 -I$(LINUX_SRC)/include/asm-mips/mach-generic -I$(RT2860_DIR)/include -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -ffreestanding -O2 -fomit-frame-pointer -G 0 -mno-abicalls -fno-pic -pipe -mabi=32 -march=74kc -Wa,-32 -Wa,-march=mips32r2 -Wa,-mips32r2 -Wa,–trap -DMODULE $(WFLAGS) -DSIGMA863X_PLATFORM -DEXPORT_SYMTAB -DPLATFORM_BL23570
export EXTRA_CFLAGS
endif
export CFLAGS
endif
export CFLAGS
endif
ifeq ($(PLATFORM),MT85XX)
# Linux 2.4
export CFLAGS
else
# Linux 2.6
EXTRA_CFLAGS += -D NO_TYPEDEF_BOOL
-D NO_TYPEDEF_UCHAR
-D NO_TYPEDEF_UINT8
-D NO_TYPEDEF_UINT16
-D NO_TYPEDEF_UINT32
-D NO_TYPEDEF_UINT64
-D NO_TYPEDEF_CHAR
-D NO_TYPEDEF_INT32
-D NO_TYPEDEF_INT64 \
endif
endif
ifeq ($(PLATFORM),NXP_TV550)
# Linux 2.4
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -O2 -fomit-frame-pointer -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=mips -DMODULE -DMODVERSIONS -include $(LINUX_SRC)/include/linux/modversions.h $(WFLAGS)
export CFLAGS
else
# Linux 2.6
endif
endif
ifeq ($(PLATFORM),MVL5)
CFLAGS := -D__KERNEL__ -I$(LINUX_SRC)/include -I$(RT28xx_DIR)/include -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -O3 -fno-omit-frame-pointer -fno-optimize-sibling-calls -fno-omit-frame-pointer -mapcs -mno-sched-prolog -mno-thumb-interwork -D__LINUX_ARM_ARCH__=5 -march=armv5te -mtune=arm926ej-s --param max-inline-insns-single=40000 -Uarm -Wdeclaration-after-statement -Wno-pointer-sign -DMODULE $(WFLAGS)
export CFLAGS
endif
ifeq ($(PLATFORM),RALINK_3352)
export CFLAGS
endif
I know … I edited it.
ok many many thanks for your help.
Looks like its just not gonna work :-[
I’ve had a similar issue round my in-laws - it wouldn’t connect to their Virgin Superhub at all (did connect using Windows 7 on the same laptop though, weird!). I set them up using a seperate router (using the Superhub purely as a cable modem), and it works now (albeit at Wireless-G speeds)
Maybe try unplugging your router for a couple of minutes?
Thanks chemicalfan
Will try that. trouble is there are so many settings on these things it takes a year to check and uncheck etc them all!
scratching my head a lot these days…
Cant figure out how to disable WPA on my router? Its a Technicolour . the readout says its on but menu doesnt seem to give option?
I wouldn’t recommend disabling WPA - WEP encryption can be broken by a smartphone in about 2 minutes, it’s really weak.
That said, I don’t have a lot of other suggestions I’m far from an expert on networking, especially wireless networking (and all the security). It’s probably fixable by debugging it, but there are a ton of settings that I just don’t understand :-[
WPA is a standard, it shouldn’t matter on the router - it might be worth logging a bug with your distro? Or at least posting on their networking forum, see if they recommend logging a bug
Edit: Forgot to mention - in my situation, it’s working nowadays, really weird. Was broken last year, but when I tried it just this weekend, I connected with no issue. I guess something’s been patched in the last year, meaning it works now. In which case, you could try out a few live CDs of different distros, see if any of them work?
