Ralink Wireless USB adapter Linux Mint 15
ALL wireless is crackable as far as piggybacking your internet goes … depends how paranoid you are about your neighbours, if you’re VERY worried, don’t use wireless at all :wink:
So you’re saying you can create the wireless connection without it spitting the password back at you ?
Have you tried deleting ALL wireless profiles, and creating a fresh connection ?
If I were you I’d try a different wireless adapter.
These tiny little things:
Edimax EW-7811Un 150Mbps Wireless IEEE802.11b/g/n nano USB Adapter
work “out of the box” with Peppermint 4 (so should do the same with Ubuntu 13.04/Mint 15) … and my Sky router is using WPA2 / AES
(I’m also able to use it to connect to a friends Technicolour router … can’t say for sure if he’s using WPA2 though)
ok thanks me ol maties
Next time i update this thread I will be on Peppermint…wish me luck!
I was being specific about that Edimax wireless adapter and Peppermint 4 … not YOUR wireless adapter, which I’d expect to have the same problems under Peppermint 4 as Mint 15 as they’re both based on Ubuntu 13.04
(unless of course it was a Mint specific issue … which I doubt)
With YOUR wireless adapter, you MAY have more luck compiling the ralink drivers in Peppermint 3/Mint 13/Ubuntu 12.04 LTS
and oddly, any of those 3 will have longer support than Peppermint 4/Mint 15/Ubuntu 13.04 … as they’re all based on the last Ubuntu “long term support” release.
But good luck whichever route you take :slight_smile:
If you decide to try Peppermint 3 rather than Peppermint 4 … don’t use the download links on the Peppermintos.com website, for some reason they’ve put up the original, not the later respin that fixed some bugs … use ONE of these links instead:-
Peppermint 3 32bit
MD5 = 05157d6dbd4ab7953870e9ee308a70a5
http://peppermintos.info/dl1/Peppermint-3-20121105-i386.iso
http://peppermintos.info/dl2/Peppermint-3-20121105-i386.iso
http://peppermintos.info/dl3/Peppermint-3-20121105-i386.iso
http://peppermintos.info/dl4/Peppermint-3-20121105-i386.iso
Peppermint 3 64bit
MD5 = a5014d15929532f7dbe38e8f86ae56bc
http://peppermintos.info/idl1/Peppermint-3-20121105-amd64.iso
http://peppermintos.info/idl2/Peppermint-3-20121105-amd64.iso
http://peppermintos.info/idl3/Peppermint-3-20121105-amd64.iso
http://peppermintos.info/idl4/Peppermint-3-20121105-amd64.iso
Ok Thanks
Will get the USB adapter recommended. I am now using Peppermint 4 and its slick! Watch this space!
Peppermint 4 is a keeper. Very good all round. V Fast and smooth and with only 1GB mem.
Glad you like it :slight_smile:
I’d like to say that I found your solution worked for me too - I used the dropbox driver and followed your instructions and got my ralink wifi working.
I was a bit iffy about using some modified driver, but I’m making a leap of faith that you’re a good guy, so now I can use my rt2870.
It was a big help, thanks :smiley:
But how did you do it - why don’t the ralink drivers i get on disk or download from their website make or install properly, but yours does ?
I also, BTW, am finding that installing debian firmware-ralink package will get my rt5370 working, but not rt2870 - even though the rt2870 is listed as one it should run.
Anyone know why ?
To tell the truth I can’t remember what I edited in those drivers, but it would only have been one or more of the following:-
a) edited the config file to support WPA supplicant through networkmanager
and/or
b) added the vendor:device ID strings for a particular wireless device … so the correct drivers are loaded when that device is detected
and/or
b) changed a few calls so the drivers compile correctly against recent kernels. (the ones on the ralink site used some old calls that are no longer used in recent kernels)
I guess you’ll just have to trust me :wink:
(or compare mine against the originals)
OK thanks I at least get an idea of what that stuff means now.
But why doesn’t the deb package for ralink drivers work for all of them ?
I’ve got a few ralink usb’s now and only the rt5370 seems to work right out of the box. I’ve got three and never had a problem.
The 2870, although listed as part of the firmware-ralink package always seems to need your tweak.
I’m a noob at this so I wonder if it’s something simple like un-blacklisting the rt2870, or using modprobe ?
Has the kernel development left the rt2870 behind ?
I went here for the package - Debian -- Error
I guess I could have added the repo instead.
Ah, I see a whole thread on the 2870 so I will read that before asking more . Thanks.
Sorry lostgnuuser, I got a bit busy trying to recover a Windows PC for someone :cry:
If you’re still having problems with an rt2870 based adapter, please start a new topic and we’ll take a looksee at it :slight_smile:
(will have to be tomorrow though)
Just a quick thanks, as your instructions were very easy to follow and worked like a charm! Appreciate people such as yourself who share their knowledge with others!
Best regards,
Greg
Hi Greg … you’re most welcome, thanks for the feedback :slight_smile:
