OK Folks,
Another one for ya, new machine (2-3 weeks) and random freezes, hard restart being the only option to reboot, machine can be on all night playing just internet radio as I often do (fall asleep to it) then I can open up a few tabs with a youtube/flash video or two and wallop, locks up. I can be playing a bit of alien arena of a night time when i venture there and same thing, 5 mins, 15 mins, 30 mins in, it all just locks up and I’m forced to restart. . . . and this is a new base unit so it’s not through it being old kit. It’s not like I’m doing an awful lot at the time and not anything that should be too intensive for this new base unit!
Not sure what you might need info wise so I’ll just post some below and let me know if you need more. . . . Thanks
I always thought there were some sort of crash logs for this but I’ve no idea where to start looking if there are?
inxi -G
Graphics: Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
X.Org: 1.14.3 drivers: intel (unloaded: fbdev,vesa) Resolution: 1440x900@60.0hz
GLX Renderer: Mesa DRI Intel Haswell Desktop GLX Version: 3.0 Mesa 9.2.1
inxi -b
System: Host: dave Kernel: 3.11.0-12-generic x86_64 (64 bit) Desktop: Gnome Distro: Linux Mint 16 Petra
Machine: System: ASUS product: All Series
Mobo: ASUSTeK model: H81M-C version: Rev X.0x Bios: American Megatrends version: 0216 date: 07/17/2013
CPU: Dual core Intel Pentium CPU G3420 (-MCP-) clocked at 800.00 MHz
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
Drives: HDD Total Size: 2160.5GB (25.3% used)
Info: Processes: 153 Uptime: 26 min Memory: 672.6/7670.4MB Client: Shell inxi: 1.8.4
inxi -C
CPU: Dual core Intel Pentium CPU G3420 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz
dave@dave ~ $
dave@dave ~ $ inxi -s
Sensors: System Temperatures: cpu: 29.8C mobo: 29.0C
Fan Speeds (in rpm): cpu: N/A
dave@dave ~ $
Edit: I found about 7 crash logs in var/log they’re pretty long in tar.gz files should I post one to pastebin ? Will it help?
I do know there used to be a bug in the 12.04 kernel that would cause random freezes with the HD4000 graphics adapter … but I thought this was resolved in later kernels.
Which kernel are you running … what’s the output from:
uname -a
Has it always done this … or has it only recently started freezing ?
Is it hard-locking such that you can’t get to another tty (e.g. Ctrl-Alt-F2)?
Depending on what caused the lock, it may crash before it can write to a log file :-\
Maybe a memtest?
Hi again , sorry for the delay replying been outside servicing the ride on mower ready for spring (he says hopefully)
dave@dave ~ $ uname -a
Linux dave 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
dave@dave ~ $
Memtest . . . . can do but it’s a brand new base unit, it’s done it on and off since I started getting a few tweaks done, just desktop themes etc, only then did i settle and start installing anything big-ish like alien arena, I brought in some maps from my XP install from AA and at first thought it may have had something to do with those but i’m lead it’s totally fine to do. It’ll stay on all day and night fine, then do something else like AA or a few tabs and some video/cams going and it stops, can’t get out of it via the keyboard or mouse they’re out of the equation.
OK, run:
sudo apt-get upgrade
sudo apt-get dist-upgrade
then REBOOT and post the output from:
uname -a
so we can see if it pulled in a kernel update.
Just because it’s new doesn’t mean the memory isn’t flaky
But it could be other things too.
For the record before I reboot . . .
dave@dave ~ $ sudo apt-get update
[sudo] password for dave:
Ign http://archive.canonical.com saucy InRelease
Hit http://archive.canonical.com saucy Release.gpg
Hit http://archive.canonical.com saucy/partner amd64 Packages
Hit http://archive.canonical.com saucy/partner i386 Packages
Ign http://speglar.simnet.is petra InRelease
Ign http://archive.ubuntu.com saucy InRelease
Hit http://speglar.simnet.is petra Release.gpg
Ign http://security.ubuntu.com saucy-security InRelease
Ign http://archive.canonical.com saucy/partner Translation-en_GB
Get:1 http://security.ubuntu.com saucy-security Release.gpg [933 B]
Ign http://archive.ubuntu.com saucy-updates InRelease
Ign http://extra.linuxmint.com petra InRelease
Hit http://speglar.simnet.is petra/main amd64 Packages
Get:2 http://security.ubuntu.com saucy-security Release [49.6 kB]
Hit http://archive.ubuntu.com saucy Release.gpg
Hit http://speglar.simnet.is petra/upstream amd64 Packages
Hit http://speglar.simnet.is petra/import amd64 Packages
Get:3 http://extra.linuxmint.com petra Release.gpg [198 B]
Get:4 http://archive.ubuntu.com saucy-updates Release.gpg [933 B]
Hit http://speglar.simnet.is petra/backport amd64 Packages
Hit http://speglar.simnet.is petra/main i386 Packages
Get:5 http://extra.linuxmint.com petra Release [3,090 B]
Hit http://speglar.simnet.is petra/upstream i386 Packages
Get:6 http://security.ubuntu.com saucy-security/main amd64 Packages [97.2 kB]
Get:7 http://archive.ubuntu.com saucy-updates Release [49.6 kB]
Hit http://speglar.simnet.is petra/import i386 Packages
Hit http://speglar.simnet.is petra/backport i386 Packages
Get:8 http://extra.linuxmint.com petra/main amd64 Packages [655 B]
Get:9 http://security.ubuntu.com saucy-security/restricted amd64 Packages [14 B]
Get:10 http://extra.linuxmint.com petra/main i386 Packages [655 B]
Hit http://archive.ubuntu.com saucy/main amd64 Packages
Get:11 http://security.ubuntu.com saucy-security/universe amd64 Packages [34.8 kB]
Hit http://archive.ubuntu.com saucy/restricted amd64 Packages
Get:12 http://security.ubuntu.com saucy-security/multiverse amd64 Packages [1,149 B]
Hit http://archive.ubuntu.com saucy/universe amd64 Packages
Get:13 http://security.ubuntu.com saucy-security/main i386 Packages [96.9 kB]
Hit http://archive.ubuntu.com saucy/multiverse amd64 Packages
Hit http://archive.ubuntu.com saucy/main i386 Packages
Get:14 http://security.ubuntu.com saucy-security/restricted i386 Packages [14 B]
Hit http://archive.ubuntu.com saucy/restricted i386 Packages
Get:15 http://security.ubuntu.com saucy-security/universe i386 Packages [35.1 kB]
Hit http://archive.ubuntu.com saucy/universe i386 Packages
Hit http://archive.ubuntu.com saucy/multiverse i386 Packages
Hit http://archive.ubuntu.com saucy/main Translation-en_GB
Get:16 http://security.ubuntu.com saucy-security/multiverse i386 Packages [1,388 B]
Hit http://archive.ubuntu.com saucy/multiverse Translation-en_GB
Hit http://security.ubuntu.com saucy-security/main Translation-en
Hit http://security.ubuntu.com saucy-security/multiverse Translation-en
Hit http://archive.ubuntu.com saucy/restricted Translation-en_GB
Hit http://archive.ubuntu.com saucy/universe Translation-en_GB
Hit http://security.ubuntu.com saucy-security/restricted Translation-en
Ign http://extra.linuxmint.com petra/main Translation-en_GB
Get:17 http://archive.ubuntu.com saucy-updates/main amd64 Packages [214 kB]
Hit http://security.ubuntu.com saucy-security/universe Translation-en
Ign http://speglar.simnet.is petra/backport Translation-en_GB
Get:18 http://archive.ubuntu.com saucy-updates/restricted amd64 Packages [14 B]
Ign http://speglar.simnet.is petra/import Translation-en_GB
Get:19 http://archive.ubuntu.com saucy-updates/universe amd64 Packages [157 kB]
Ign http://speglar.simnet.is petra/main Translation-en_GB
Get:20 http://archive.ubuntu.com saucy-updates/multiverse amd64 Packages [1,572 B]
Ign http://speglar.simnet.is petra/upstream Translation-en_GB
Get:21 http://archive.ubuntu.com saucy-updates/main i386 Packages [212 kB]
Get:22 http://archive.ubuntu.com saucy-updates/restricted i386 Packages [14 B]
Ign http://security.ubuntu.com saucy-security/main Translation-en_GB
Get:23 http://archive.ubuntu.com saucy-updates/universe i386 Packages [157 kB]
Ign http://security.ubuntu.com saucy-security/multiverse Translation-en_GB
Ign http://security.ubuntu.com saucy-security/restricted Translation-en_GB
Get:24 http://archive.ubuntu.com saucy-updates/multiverse i386 Packages [1,763 B]
Ign http://security.ubuntu.com saucy-security/universe Translation-en_GB
Hit http://archive.ubuntu.com saucy-updates/main Translation-en_GB
Hit http://archive.ubuntu.com saucy-updates/multiverse Translation-en_GB
Hit http://archive.ubuntu.com saucy-updates/restricted Translation-en_GB
Hit http://archive.ubuntu.com saucy-updates/universe Translation-en_GB
Fetched 1,116 kB in 5s (218 kB/s)
Reading package lists... Done
dave@dave ~ $ sudo apt-get upgrade
Building dependency tree
The following packages will be upgraded:
gir1.2-dbusmenu-glib-0.4 icedtea-7-plugin icedtea-netx icedtea-netx-common
icedtea-plugin libdbusmenu-glib4 libdbusmenu-gtk3-4 libdbusmenu-gtk4
libservlet3.0-java linux-firmware linux-libc-dev xserver-xorg-core
xserver-xorg-glamoregl xserver-xorg-video-intel
14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 31.1 MB of archives.
After this operation, 1,374 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://archive.ubuntu.com/ubuntu/ saucy-updates/main gir1.2-dbusmenu-glib-0.4 amd64 12.10.3+13.10.20131104-0ubuntu1 [7,062 B]
Get:2 http://archive.ubuntu.com/ubuntu/ saucy-updates/main libdbusmenu-glib4 amd64 12.10.3+13.10.20131104-0ubuntu1 [48.1 kB]
Get:3 http://archive.ubuntu.com/ubuntu/ saucy-updates/main libdbusmenu-gtk3-4 amd64 12.10.3+13.10.20131104-0ubuntu1 [32.2 kB]
Get:4 http://archive.ubuntu.com/ubuntu/ saucy-updates/main libdbusmenu-gtk4 amd64 12.10.3+13.10.20131104-0ubuntu1 [32.2 kB]
Get:5 http://archive.ubuntu.com/ubuntu/ saucy-updates/main libservlet3.0-java all 7.0.42-1ubuntu0.1 [297 kB]
Get:6 http://archive.ubuntu.com/ubuntu/ saucy-updates/main linux-firmware all 1.116.2 [26.5 MB]
Get:7 http://archive.ubuntu.com/ubuntu/ saucy-updates/main linux-libc-dev amd64 3.11.0-18.32 [962 kB]
Get:8 http://archive.ubuntu.com/ubuntu/ saucy-updates/main xserver-xorg-core amd64 2:1.14.5-1ubuntu2~saucy1 [1,570 kB]
Get:9 http://archive.ubuntu.com/ubuntu/ saucy-updates/main xserver-xorg-glamoregl amd64 0.5.1-0ubuntu4.2 [7,906 B]
Get:10 http://archive.ubuntu.com/ubuntu/ saucy-updates/main xserver-xorg-video-intel amd64 2:2.99.904-0ubuntu2.1 [736 kB]
Get:11 http://archive.ubuntu.com/ubuntu/ saucy-updates/main icedtea-netx-common all 1.4-3ubuntu2.1 [847 kB]
Get:12 http://archive.ubuntu.com/ubuntu/ saucy-updates/main icedtea-7-plugin amd64 1.4-3ubuntu2.1 [85.6 kB]
Get:13 http://archive.ubuntu.com/ubuntu/ saucy-updates/main icedtea-netx amd64 1.4-3ubuntu2.1 [17.0 kB]
Get:14 http://archive.ubuntu.com/ubuntu/ saucy-updates/main icedtea-plugin all 1.4-3ubuntu2.1 [3,246 B]
Fetched 31.1 MB in 10s (3,025 kB/s)
(Reading database ... 155445 files and directories currently installed.)
Preparing to replace gir1.2-dbusmenu-glib-0.4 12.10.3+13.10.20130913-0ubuntu2 (using .../gir1.2-dbusmenu-glib-0.4_12.10.3+13.10.20131104-0ubuntu1_amd64.deb) ...
Unpacking replacement gir1.2-dbusmenu-glib-0.4 ...
Preparing to replace libdbusmenu-glib4:amd64 12.10.3+13.10.20130913-0ubuntu2 (using .../libdbusmenu-glib4_12.10.3+13.10.20131104-0ubuntu1_amd64.deb) ...
Unpacking replacement libdbusmenu-glib4:amd64 ...
Preparing to replace libdbusmenu-gtk3-4:amd64 12.10.3+13.10.20130913-0ubuntu2 (using .../libdbusmenu-gtk3-4_12.10.3+13.10.20131104-0ubuntu1_amd64.deb) ...
Unpacking replacement libdbusmenu-gtk3-4:amd64 ...
Preparing to replace libdbusmenu-gtk4:amd64 12.10.3+13.10.20130913-0ubuntu2 (using .../libdbusmenu-gtk4_12.10.3+13.10.20131104-0ubuntu1_amd64.deb) ...
Unpacking replacement libdbusmenu-gtk4:amd64 ...
Preparing to replace libservlet3.0-java 7.0.42-1 (using .../libservlet3.0-java_7.0.42-1ubuntu0.1_all.deb) ...
Unpacking replacement libservlet3.0-java ...
Preparing to replace linux-firmware 1.116 (using .../linux-firmware_1.116.2_all.deb) ...
Unpacking replacement linux-firmware ...
Preparing to replace linux-libc-dev:amd64 3.11.0-12.19 (using .../linux-libc-dev_3.11.0-18.32_amd64.deb) ...
Unpacking replacement linux-libc-dev:amd64 ...
Preparing to replace xserver-xorg-core 2:1.14.3-3ubuntu2 (using .../xserver-xorg-core_2%3a1.14.5-1ubuntu2~saucy1_amd64.deb) ...
Unpacking replacement xserver-xorg-core ...
Preparing to replace xserver-xorg-glamoregl:amd64 0.5.1-0ubuntu4 (using .../xserver-xorg-glamoregl_0.5.1-0ubuntu4.2_amd64.deb) ...
Unpacking replacement xserver-xorg-glamoregl:amd64 ...
Preparing to replace xserver-xorg-video-intel 2:2.99.904-0ubuntu2 (using .../xserver-xorg-video-intel_2%3a2.99.904-0ubuntu2.1_amd64.deb) ...
Unpacking replacement xserver-xorg-video-intel ...
Preparing to replace icedtea-netx-common 1.4-3ubuntu2 (using .../icedtea-netx-common_1.4-3ubuntu2.1_all.deb) ...
Unpacking replacement icedtea-netx-common ...
Preparing to replace icedtea-7-plugin:amd64 1.4-3ubuntu2 (using .../icedtea-7-plugin_1.4-3ubuntu2.1_amd64.deb) ...
Unpacking replacement icedtea-7-plugin:amd64 ...
Preparing to replace icedtea-netx:amd64 1.4-3ubuntu2 (using .../icedtea-netx_1.4-3ubuntu2.1_amd64.deb) ...
Unpacking replacement icedtea-netx:amd64 ...
Preparing to replace icedtea-plugin 1.4-3ubuntu2 (using .../icedtea-plugin_1.4-3ubuntu2.1_all.deb) ...
Unpacking replacement icedtea-plugin ...
Processing triggers for man-db ...
Processing triggers for desktop-file-utils ...
Processing triggers for gnome-menus ...
Processing triggers for mime-support ...
Processing triggers for hicolor-icon-theme ...
Setting up libdbusmenu-glib4:amd64 (12.10.3+13.10.20131104-0ubuntu1) ...
Setting up gir1.2-dbusmenu-glib-0.4 (12.10.3+13.10.20131104-0ubuntu1) ...
Setting up libdbusmenu-gtk3-4:amd64 (12.10.3+13.10.20131104-0ubuntu1) ...
Setting up libdbusmenu-gtk4:amd64 (12.10.3+13.10.20131104-0ubuntu1) ...
Setting up libservlet3.0-java (7.0.42-1ubuntu0.1) ...
Setting up linux-firmware (1.116.2) ...
Setting up linux-libc-dev:amd64 (3.11.0-18.32) ...
Setting up xserver-xorg-core (2:1.14.5-1ubuntu2~saucy1) ...
Setting up xserver-xorg-glamoregl:amd64 (0.5.1-0ubuntu4.2) ...
Setting up xserver-xorg-video-intel (2:2.99.904-0ubuntu2.1) ...
Setting up icedtea-netx-common (1.4-3ubuntu2.1) ...
Setting up icedtea-netx:amd64 (1.4-3ubuntu2.1) ...
Setting up icedtea-7-plugin:amd64 (1.4-3ubuntu2.1) ...
Setting up icedtea-plugin (1.4-3ubuntu2.1) ...
Processing triggers for libc-bin ...
dave@dave ~ $ sudo apt-get dist-upgrade
Calculating upgrade... Done
dave@dave ~ $
Post boot . . .
dave@dave ~ $
Damn it I was hoping there was a later kernel in the repo’s
How do you fancy trying the 3.12 kernel, and seeing if that makes a difference ? … let me know if you wanna and I’ll post instructions.
If you think that could be the thing to do I’ll have a crack . . . . . . I don’t know if there’s any other relevant things to do or try as well? Are there crash logs for this sort of thing and would they help? If LM16’s the latest how come it’s not got that kernel already? just wondering…
Also I don’t have any proprietary drivers in this system, I don’t know if that could/should make a difference but I’ve nearly always had nVidia cards and this one’s the first time I’ve been back on intel for a good while so I guess I’m clutching at straws 'cos I don’t know what Intels supports like with Linux…
I doubt if there’ll be anything useful in the logs … a system lockup rarely leaves time for anything to get written to the logs … but if you feel like looking through them feel free, I would have thought Mint would have a log file viewer installed by default.
if not, they’re located at
/var/log
Mint 16 may be the latest version but it’s still roughly 5 months old … new kernels are released 3 monthly … and in any case a distro will tend to stick to the same kernel series over its life … though Ubuntu 13.10 will have 3.11 for it’s entire life, it may receive updates within the 3.11 series but is unlikey to ever move to the 3.12 or above series.
Instruction to install the later kernel to follow…
Aaahhhh I see, didn’t know that, you learn something new every day
I’ll check later then for your instructions, better not do it later I could be the worse for wear after the pub quiz lol
Again, for the record so you know I’ve done it correctly I’ll post the output before rebooting, I noticed a couple of errors and other warning messages, not sure how relevant they are though just thought I’d mention seeing them . . . .
dave@dave ~ $ cd ~/Desktop/kernel-3.12rc7
dave@dave ~/Desktop/kernel-3.12rc7 $ sudo dpkg -i *.deb
Selecting previously unselected package linux-headers-3.12.0-031200rc7.
(Reading database ... 155447 files and directories currently installed.)
Unpacking linux-headers-3.12.0-031200rc7 (from linux-headers-3.12.0-031200rc7_3.12.0-031200rc7.201310271935_all.deb) ...
Selecting previously unselected package linux-headers-3.12.0-031200rc7-generic.
Unpacking linux-headers-3.12.0-031200rc7-generic (from linux-headers-3.12.0-031200rc7-generic_3.12.0-031200rc7.201310271935_amd64.deb) ...
Selecting previously unselected package linux-image-3.12.0-031200rc7-generic.
Unpacking linux-image-3.12.0-031200rc7-generic (from linux-image-3.12.0-031200rc7-generic_3.12.0-031200rc7.201310271935_amd64.deb) ...
Done.
Setting up linux-headers-3.12.0-031200rc7 (3.12.0-031200rc7.201310271935) ...
Setting up linux-headers-3.12.0-031200rc7-generic (3.12.0-031200rc7.201310271935) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
Error! Bad return status for module build on kernel: 3.12.0-031200rc7-generic (x86_64)
Consult /var/lib/dkms/virtualbox-guest/4.2.16/build/make.log for more information.
Setting up linux-image-3.12.0-031200rc7-generic (3.12.0-031200rc7.201310271935) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
update-initramfs: Generating /boot/initrd.img-3.12.0-031200rc7-generic
Warning: No support for locale: en_GB.utf8
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.12.0-031200rc7-generic /boot/vmlinuz-3.12.0-031200rc7-generic
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-3.12.0-031200rc7-generic
Found initrd image: /boot/initrd.img-3.12.0-031200rc7-generic
Found linux image: /boot/vmlinuz-3.11.0-12-generic
Found initrd image: /boot/initrd.img-3.11.0-12-generic
Found memtest86+ image: /memtest86+.bin
No volume groups found
done
Post reboot:
Linux dave 3.12.0-031200rc7-generic #201310271935 SMP Sun Oct 27 23:37:06 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
dave@dave ~ $
What now? try this for a while and see if it’s any different?
What now? try this for a while and see if it's any different?
EGG-ZAKLY
If this fixes things, we’ll probably have to fix virtualbox (guest additions) … but NOT YET, it makes no sense to fix it unless we’re sure we’re sticking with this kernel.
Sounds like a plan to me then, I’ll give it some later and report back, thank you
Update. . . . . so far so good, an hour plus into a game of alien arena and no freeze yet lol :-*
Just thought I’d let you know. . . . . I’ll continue ‘testing’ the machine and my brain and patience, I’m throwing in a networked printer question too for good measure, just to keep you busy
Cheers
Dave
