I have 2 portable HDs. They have a name when I plug them in. My bro gave them to me- had them awhile. My bro named one Spock as it originally had Star Trek vids on it. How can I change its name? I went into disk utility but couldn’t see how to do it.
Hi Melissa
There’s probably a simple command you can run in the terminal to do this but I wouldn’t know the syntax but it can be done easily in gparted
first with one of the drives plugged in can you post the output of
sudo fdisk -l
Thanks Graeme.
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ sudo fdisk -l
[sudo] password for melissa:
Disk /dev/sda: 40.0 GB, 40020664320 bytes
255 heads, 63 sectors/track, 4865 cylinders, total 78165360 sectors
Disk identifier: 0x0002c481
/dev/sda1 * 2048 76724223 38361088 83 Linux
/dev/sda2 76726270 78163967 718849 5 Extended
/dev/sda5 76726272 78163967 718848 82 Linux swap / Solaris
Disk /dev/sdb: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Disk identifier: 0x0944c949
/dev/sdb1 2 625142447 312571223 7 HPFS/NTFS/exFAT
It’s this one’s name I want to change.
Ok first of all you’ll need to install gparted
sudo apt-get install gparted
once installed open gparted by going to Menu>Systems Tools> gparted
When gparted opens up click the small down arrow on the top right and post back the options please
I expect there to be 2 options similar to /dev/sda (40gb) & /dev/sdb (320gb) but I want to be sure before we go further
You could try (as it is a NTFS formatted drive) to use the ntfslabel command
First unmount it:
sudo umount /dev/sdb1
then check current name (label):
sudo ntfslabel /dev/sdb1
If it is the right one then change it (change my_drive to whatever name you want it to be):
sudo ntfslabel /dev/sdb1 my_drive
to see the full affects of the change you have to umount, remove, put back, mount again.
SeZo You iz da man
Thank you
But I was nearly there
Please follow SeZo’s instructions
Good luck
Thank you guys. I did what SeZo said and it changed it to my drive a a name. I have tried several times to name it “Dark_Shadows” (which is the TV series on the drive) but it won’t let me:
elissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ sudo umount /dev/sdb1
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ sudo ntfslabel /dev/sdb1
my_drive
melissa@melissa-HP-Compaq-nx6325-RH628ES-ABU ~ $ sudo ntfslabel /dev/sdb1 Dark_ Shadows
Usage: ntfslabel [options] device [label]
-n, --no-action Do not write to disk
-f, --force Use less caution
–new-serial Set a new serial number
–new-half-serial Set a partial new serial number
-q, --quiet Less output
-v, --verbose More output
-V, --version Display version information
-h, --help Display this help
Developers’ email address: ntfs-3g-devel@lists.sf.net
News, support and information: http://tuxera.com
You have a space in the label title (after the underscore) in the command:-
try:
sudo ntfslabel /dev/sdb1 Dark_Shadows
or maybe:
sudo ntfslabel /dev/sdb1 "Dark Shadows"
Thanks a lot Mark. That worked. My computers are driving me bonkers tonight. I am sat on the couch with my laptop on its usual table and the Mint netbook on a tray on my knee. You will soon see another post as to why…
