Re: PP3 - Firefox Navigation toolbar - doesn't block up when clicked [SOLVED]
I have searched the Forum for this.
In Windows (sorry I swore), when I click in the Firefox Navigation toolbar, the contents block up and I can start typing a new address immediately (or paste one in)
With my PP3 Firefox, the toolbar contents do not block up and I have to block them up myself
I wondered if there an about:config frigg for this?
If you mean you click in the URL bar and it automatically selects everything that’s already there … YES
browser.urlbar.clickSelectAll
Set it to “true”
By default
browser.urlbar.doubleClickSelectAll
is set to true … so you have to double click the URL bar to select everything.
Brilliant!
Works a treat
Thanks yet again Mark
No problem :slight_smile:
Can you do me a favour … use [SOLVED] rather than [SORTED] … most people when searching for a solution say in Google will search for the term “SOLVED”.
TIA :slight_smile:
Sorry
  • showing my age :wink:
no problem … all sorted now … erm :o
Fixed … but that’s less important than the FIRST posting in a topic :wink:
The forum front page reflects the title of the FIRST posting :slight_smile:
