Red Triangle w/ Exclamation Mark Next To Wifi Symbol Ubunto 12.10
I’m having a similar issue as in the fellow with a newer version of Ubuntu was having in this threadhttp://linuxforums.org.uk/index.php?topic=11545.0. I tried the solution people gave in that thread (sudo apt-get update) and the symbol went away briefly. It came back. When I do run the update command in terminal I see many failed lines (see below) but not sure what in my software sources I should change. Help is appreciated.
Err http://archive.ubuntu.com quantal/main Sources
  404  Not Found [IP: 91.189.91.15 80]
Err http://archive.ubuntu.com quantal/restricted Sources
Err http://archive.ubuntu.com quantal/universe Sources
Err http://archive.ubuntu.com quantal/multiverse Sources
Err http://archive.ubuntu.com quantal/main i386 Packages
Err http://archive.ubuntu.com quantal/restricted i386 Packages
Err http://archive.ubuntu.com quantal/universe i386 Packages
Err http://archive.ubuntu.com quantal/multiverse i386 Packages
Err http://archive.ubuntu.com quantal-updates/main Sources
Err http://archive.ubuntu.com quantal-updates/restricted Sources
Err http://archive.ubuntu.com quantal-updates/universe Sources
Err http://archive.ubuntu.com quantal-updates/multiverse Sources
Err http://archive.ubuntu.com quantal-updates/main i386 Packages
Err http://archive.ubuntu.com quantal-updates/restricted i386 Packages
Err http://archive.ubuntu.com quantal-updates/universe i386 Packages
Err http://archive.ubuntu.com quantal-updates/multiverse i386 Packages
Err http://archive.ubuntu.com quantal-security/main Sources
Err http://archive.ubuntu.com quantal-security/restricted Sources
Err http://archive.ubuntu.com quantal-security/universe Sources
Err http://archive.ubuntu.com quantal-security/multiverse Sources
Err http://archive.ubuntu.com quantal-security/main i386 Packages
Err http://archive.ubuntu.com quantal-security/restricted i386 Packages
Err http://archive.ubuntu.com quantal-security/universe i386 Packages
Err http://archive.ubuntu.com quantal-security/multiverse i386 Packages
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/main/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/restricted/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/universe/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/multiverse/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/main/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/restricted/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/universe/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/multiverse/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-updates/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/main/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/restricted/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/universe/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/multiverse/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-backports/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/main/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/restricted/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/universe/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/multiverse/source/Sources  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/quantal-security/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
https://wiki.ubuntu.com/Releases
as you can see support for 12.10 (quantal) ended on May 16th 2014 … the repositories have now been taken offline.
I’m afraid you now have no option but to move to another version.
That would explain it! Thanks!!
