Resetting password for webmin users?
I’ve been locked out of webmin on my laptop & my tablet because I can’t remember the password for my webmin account.
I’ve tried running:
/usr/share/webmin/changepass.pl /etc/webmin [my username] [new password]
and also:
bash /usr/share/webmin/changepass.pl /etc/webmin [my username] [new password]
But these don’t seem to be working…
Help?
Have you tried just your normal username + password?
Yep, was positive it was the same as the one that’s on the server. I just need to reset it, and I know I can because there’s a changepass script in the webmin folder… I just can’t get it to work for me.
OK, From memory I think the default install (unless you changed it) it uses root as username and your root password as the password.
Alternatively just re-install, it will tell you then
