(resolved)Inkscape fonts
Hi
I’m looking for help regarding installing fonts in Inkscape. I would like an Art Deco font or one that is similar to ‘Park Lane’ in Windows.
Any ideas?
Thanks
If you mean this font:
or one of these:
Download it … unpack it … and put the extracted font in the hidden .fonts directory in your Home directory (~/.fonts)
(If the ~/.fonts directory doesn’t already exist, create it)
Then update the font cache with:
fc-cache -fv
now restart Inkscape, and the font should be available :slight_smile:
The above instructions will only make the font available to the current user … if you want it system wide (available to ALL users), put the extracted font in:-
/usr/share/fonts
and run
sudo fc-cache -fv
instead
There’s nothing stopping you copying your windows fonts to one of those directories, then updating the font cache :wink:
Or if you want a few hundred fonts installing in one go … run:
sudo apt-get install fonts-cantarell lmodern ttf-aenigma ttf-georgewilliams ttf-bitstream-vera ttf-sjfonts ttf-tuffy tv-fonts
Still want more:
sudo apt-get install ubuntustudio-font-meta
BE AWARE, that mata-package will pull in a LOT of stuff … including some bits for programs and languages you might not need/want
original source:
Thanks for your advice
I will try your suggestions.
I dont have a .fonts folder just a .fontsconfig
Ubuntu 12.04
mkdir ~/.fonts
You do now :wink:
Thanks for your help they work a treat. :slight_smile:
You’re welcome :slight_smile:
