SAMBA networking issue on Peppermint Two (Resolved)
I am moving my 3rd computer from Windows to Linux All went very well except networking (internet, printers all working fine).
I installed SAMBA as it is not installed by default but when I try to start SAMBA in System Tools after entering my password nothing happens. I am unable to share folders on this computer or see other computers Linux or Windows on the local network.
Any help apreceated.
First check if the samba daemon (smbd) is running:
ps ax | grep smbd
If it IS running, you should get an output similar to -
1053 ? Ss 0:00 /usr/sbin/smbd -D 1055 ? S 0:00 /usr/sbin/smbd -D 1057 pts/0 S+ 0:00 grep --colour=auto smbd
If it ISN’T running, you should get an output similar to -
1034 pts/0 S+ 0:00 grep --colour=auto smbd
If it ISN’t running, enter:
sudo service smbd start
and see if you get any errors.
Check again that it is NOW running.
also, can you post the contents of your /etc/smb.conf :
sudo leafpad /etc/smb.conf
and the contents of sudo leafpad /etc/nsswitch.conf
This is what I get when I try to start the service.
usertwo@userone ~ $ sudo service smbd start
[sudo] password for usertwo:
smbd start/running, process 1872
usertwo@userone ~ $
When I check smbd is not running.
Sample configuration file for the Samba suite for Debian GNU/Linux.
This is the main Samba configuration file. You should read the
smb.conf(5) manual page in order to understand the options listed
here. Samba has a huge number of configurable options most of which
are not shown in this example
Some options that are often worth tuning have been included as
commented-out examples in this file.
- When such options are commented with “;”, the proposed setting
differs from the default Samba behaviour
- When commented with “#”, the proposed setting is the default
behaviour of Samba but the option is considered important
enough to be mentioned here
NOTE: Whenever you modify this file you should run the command
“testparm” to check that you have not made any basic syntactic
errors.
A well-established practice is to name the original file
“smb.conf.maste r” and create the “real” config file with
testparm -s smb.conf.maste r >smb.conf
This minimizes the size of the really used smb.conf file
which, according to the Samba Team, impacts performance
However, use this with caution if your smb.conf file contains nested
“include” statements. See Debian bug #483187 for a case
where using a master file is not a good idea.
#======================= Global Settings =======================
[global]
Browsing/Identification
Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = 000D0B6DA3C4
netbios name = peppermint
server string is the equivalent of the NT Description field
server string = %h server
Windows Internet Name Serving Support Section:
WINS Support - Tells the NMBD component of Samba to enable its WINS Server
wins support = no
WINS Server - Tells the NMBD components of Samba to be a WINS Client
Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
What naming service and in what order should we use to resolve host names
to IP addresses
; name resolve order = lmhosts host wins bcast
Networking
The specific set of interfaces / networks to bind to
This can be either the interface name or an IP address/netmask;
interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
Only bind to the named interfaces and/or networks; you must use the
‘interfaces’ option above to use this.
It is recommended that you enable this feature if your Samba machine is
not protected by a firewall or is a firewall itself. However, this
option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
Debugging/Accounting
This tells Samba to use a separate log file for each machine
that connects
log file = /var/log/samba/log.%m
Cap the size of the individual log files (in KiB).
max log size = 1000
If you want Samba to only log through syslog then set the following
parameter to ‘yes’.
syslog only = no
We want Samba to log a minimum amount of information to syslog. Everything
should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
through syslog you should set the following parameter to something higher.
syslog = 0
Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
“security = user” is always a good idea. This will require a Unix account
in this server for every user accessing the server. See
/usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
in the samba-doc package for details.
security = user
You may wish to use password encryption. See the section on
‘encrypt passwords’ in the smb.conf(5) manpage before enabling.
encrypt passwords = true
If you are using encrypted passwords, Samba will need to know what
password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
This boolean parameter controls whether Samba attempts to sync the Unix
password with the SMB password when the encrypted SMB password in the
passdb is changed.
unix password sync = yes
For Unix password sync to work on a Debian GNU/Linux system, the following
parameters must be set (thanks to Ian Kahan <kahan@informatik.tu-muenchen.de for
sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = Enter\snew\s\spassword:* %n\n Retype\snew\s\spassword:* %n\n password\supdated\ssuccessfully .
This boolean controls whether PAM will be used for password changes
when requested by an SMB client instead of the program listed in
‘passwd program’. The default is ‘no’.
pam password change = yes
This option controls how unsuccessful authentication attempts are mapped
to anonymous connections
map to guest = bad user
########## Domains ###########
Is this machine able to authenticate users. Both PDC and BDC
must have this setting enabled. If you are the BDC you must
change the ‘domain master’ setting to no
; domain logons = yes
The following setting only takes effect if ‘domain logons’ is set
It specifies the location of the user’s profile directory
from the client point of view)
The following required a [profiles] share to be setup on the
samba server (see below)
; logon path = \%N\profiles%U
Another common choice is storing the profile in the user’s home directory
(this is Samba’s default)
logon path = \%N%U\profile
It specifies the location of a user’s home directory (from the client
point of view)
; logon drive = H:
logon home = \%N%U
It specifies the script to run during logon. The script must be stored
in the [netlogon] share
NOTE: Must be store in ‘DOS’ file format convention
; logon script = logon.cmd
This allows Unix users to be created on the domain controller via the SAMR
RPC pipe. The example command creates a user account with a disabled Unix
password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos “” %u
This allows machine accounts to be created on the domain controller via the
SAMR RPC pipe.
The following assumes a “machines” group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c “%u machine account” -d /var/lib/samba -s /bin/false %u
This allows Unix groups to be created on the domain controller via the SAMR
RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
########## Printing ##########
If you want to automatically load your printer list rather
than setting them up individually then you’ll need this
load printers = yes
lpr(ng) printing. You may wish to override the location of the
printcap file
; printing = bsd
; printcap name = /etc/printcap
CUPS printing. See also the cupsaddsmb( manpage in the
cupsys-client package.
; printing = cups
; printcap name = cups
############ Misc ############
Using the following line enables you to customise your configuration
on a per machine basis. The %m gets replaced with the netbios name
of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
Most people will find that this option gives better performance.
See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
for details
You may want to add the following on a Linux system:
SO_RCVBUF=8192 SO_SNDBUF=8192
socket options = TCP_NODELAY
The following parameter is useful only if you have the linpopup package
installed. The samba maintainer and the linpopup maintainer are
working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c ‘/usr/bin/linpopup “%f” “%m” %s; rm %s’ &
Domain Master specifies Samba to be the Domain Master Browser. If this
machine will be configured as a BDC (a secondary logon server), you
must set this to ‘no’; otherwise, the default behavior is recommended.
domain master = auto
Some defaults for winbind (make sure you’re not using the ranges
for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
The following was the default behaviour in sarge,
but samba upstream reverted the default because it might induce
performance issues in large organizations.
See Debian bug #368251 for some of the consequences of not
having this setting and smb.conf(5) for details.
; winbind enum groups = yes
; winbind enum users = yes
Setup usershare options to enable non-root users to share folders
with the net usershare command.
Maximum number of usershare. 0 (default) means that usershare is disabled.
; usershare max shares = 100
Allow users who’ve been granted usershare privileges to create
public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
Un-comment the following (and tweak the other settings below to suit)
to enable the default home directory shares. This will share each
user’s home director as \server\username
;[homes]
; comment = Home Directories
; browseable = no
By default, the home directories are exported read-only. Change the
next parameter to ‘no’ if you want to be able to write to them.
; read only = yes
File creation mask is set to 0700 for security reasons. If you want to
create files with group=rw permissions, set next parameter to 0775.
; create mask = 0700
Directory creation mask is set to 0700 for security reasons. If you want to
create dirs. with group=rw permissions, set next parameter to 0775.
; directory mask = 0700
By default, \server\username shares can be connected to by anyone
with access to the samba server. Un-comment the following parameter
to make sure that only “username” can connect to \server\username
The following parameter makes sure that only “username” can connect
This might need tweaking when using external authentication schemes
; valid users = %S
Un-comment the following and create the netlogon directory for Domain Logons
(you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
; share modes = no
Un-comment the following and create the profiles directory to store
users profiles (see the “logon path” option above)
The path below should be writable by all users so that their
profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
wins support = no
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
Windows clients look for this share name as a source of downloadable
printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
Uncomment to allow remote administration of Windows print drivers.
You may need to replace ‘lpadmin’ with the name of the group your
admin users are members of.
Please note that you also need to set appropriate Unix permissions
to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
A sample share for sharing your CD-ROM with others.
;[cdrom]
; comment = Samba server’s CD-ROM
; read only = yes
; locking = no
; path = /cdrom
; guest ok = yes
The next two parameters show how to auto-mount a CD-ROM when the
cdrom share is accesed. For this to work /etc/fstab must contain
an entry like this:
/dev/scd0 /cdrom iso9660 defaults,noauto,ro,user 0 0
The CD-ROM gets unmounted automatically after the connection to the
If you don’t want to use auto-mounting/unmounting make sure the CD
is mounted on /cdrom
; preexec = /bin/mount /cdrom
; postexec = /bin/umount /cdrom
[peppermint]
path = /home/allusers
available = yes
browsable = yes
public = yes
writable = no
[Music]
path = /home/allusers/Music
available = yes
browsable = yes
public = yes
writable = no
/etc/nsswitch.conf
Example configuration of GNU Name Service Switch functionality.
If you have the glibc-doc-reference' and info’ packages installed, try:
`info libc “Name Service Switch”’ for information about this file.
passwd: compat
group: compat
shadow: compat
hosts: files mdns4_minimal [NOTFOUND=return] dns mdns4
networks: files
protocols: db files
services: db files
ethers: db files
rpc: db files
netgroup: nis
  1. are you a menber of the sambashare group ?
  2. you’ll need to change this line in /etc/smb.conf
to something like
netbios name = peppermint1
as you can’t have the same netbios name on 2 computers on the same network.
  1. what is the output from:
ps ax | grep smbd
  1. you haven’t given the 2 PC’s the same hostname have you ?
Run this on both machines and check the contents are different:
gedit /etc/hostname
Hi, changed the line you recomended.
Outputs-
smbd start/running, process 1704
usertwo@userone ~ $
usertwo@userone ~ $ ps ax | grep smbd
1753 pts/1 S+ 0:00 grep --colour=auto smbd
usertwo@userone ~ $
Host name is userone
There is another computer on the network with the same Host name how do I change this…
To change hostname, see this posting:
http://linuxforums.org.uk/general-help-advice/computer-name-and-home-network/msg27792/#msg27792
Are you a member of the sambashare group ? … see 3) here:
http://linuxforums.org.uk/general-help-advice/networking-with-windows-pss/msg44831/#msg44831
Hi, have changed the computer name OK.
I ran a test parm and got the following Error message.
Error state Directory/var/lib/samba dose not exist
I am not a member of the samba group
As it is a clean install I could start again by doing a reinstall.
Make sure you ARE a member of the sambashare group… see here:
then log off and on again, or reboot… or run:
sudo service smbd restart
Does the /var/lib/samba directory actually exist ? … what is the output from:
ls -l /var/lib/samba
What is the output from:
ps ax | grep nmbd
A bit drastic at this point, but your call :wink:
Hi output you requested…
usertwo@Mobiletwo ~ $ ls -l /var/lib/samba
ls: cannot access /var/lib/samba: No such file or director
usertwo@Mobiletwo ~ $ ps ax | grep nmbd
2200 pts/1 S+ 0:00 grep --colour=auto nmbd
I will join the group and give it a bit longer before doing a reinstall.
Once you are a member of the samabashare group, and have rebooted … if the /var/lib/samba directory still doesn’t exist, try reinstalling samba:
sudo apt-get install --reinstall samba
Then check you are still a member of sambashare, and that the /var/lib/samba directory exists.
Everything now working OK thanks again for your help.
Told you a full OS reinstall was a bit premature :wink:
BTW, what fixed it ? … was it the sambashare group, or did you have to reinstall samba ? … this info may help future readers of this topic.
I was all ready a member of sambashare group. Its was the reinstall that fixed the problem.
Reinstall of what ? … the whole OS, or just samba ?
Just samba as you suggested.
Thank god for that… I was beginning to think my comment about reinstalling the OS being “a bit premature”, may have been a bit premature :wink:
