My Dell laptop which has Peppermint 8 and the simple scan program does not work. When I plug in my Packard Bell Diamond 1200 its light is on and the simple scan box comes up but it says there is no scanner attached.
Anyone know what to do please? I really need to use my scanner, many thanks.
With the scanner plugged into the PC and switched on, do you get any output from these commands:-
sane-find-scanner
scanimage -L
sudo sane-find-scanner
sudo scanimage -L
lsusb
Thanks Mark:
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 008:001: Access denied (insufficient permissions)
could not open USB device 0x1c4f/0x0003 at 007:009: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 007:001: Access denied (insufficient permissions)
found USB scanner (vendor=0x05d8, product=0x4002, chip=GT-6801) at libusb:006:002
could not open USB device 0x1d6b/0x0001 at 006:001: Access denied (insufficient permissions)
could not open USB device 0x05ca/0x180a at 001:003: Access denied (insufficient permissions)
could not open USB device 0x0bda/0x0158 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 005:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 003:001: Access denied (insufficient permissions)
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
You may want to run this program as root to find all devices. Once you
found the scanner devices, be sure to adjust access permissions as
necessary.
barnabas@barnabas-Inspiron-1545 ~ $ scanimage -L
device `gt68xx:libusb:006:002’ is a Mustek BearPaw 1200 CU flatbed scanner
barnabas@barnabas-Inspiron-1545 ~ $ sudo sane-find-scanner
[sudo] password for barnabas:
barnabas@barnabas-Inspiron-1545 ~ $ sudo scanimage -L
barnabas@barnabas-Inspiron-1545 ~ $ lsusb
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 009: ID 1c4f:0003 SiGma Micro HID controller
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 05d8:4002 Ultima Electronics Corp. Artec Ultima 2000 (GT6801 based)/Lifetec LT9385/ScanMagic 1200 UB Plus Scanner
Bus 001 Device 003: ID 05ca:180a Ricoh Co., Ltd
Bus 001 Device 002: ID 0bda:0158 Realtek Semiconductor Corp. USB 2.0 multicard reader
Try installing xsane:
sudo apt-get install xsane
now start it from:-
menu > Graphics > XSane Image scanning program
Did that find your scanner ?
(obviously the scanner needss to be plugged in and switched on)
I did that and xsane uploaded to the laptop. But when I plugged in the scanner the box came up and said “failed to open device invalid argument.” Now, I know there is nothing wrong with the scanner cos it works perfectly on the Mint netbook. I used it this afternoon! Just would be nice if I need to scan I can just plug it into this Peppermint Dell, and not have to go and boot up another computer! Why it won’t work on the Dell is very odd. The scanner doesn’t have an on/off switch so when I plug it into the Mint netbook its light is on right away and it is ready for action!
PS the netbook is also a Dell- an inspiron mini.
Oh and it can’t be a USB port problem because the Dell recognises my Maxtor HD , my mobile phone and charges my e cig up via the ports!
OK, as this is an Artec Ultima 2000 flatbed … follow these instructions:-
Open a terminal and run
gksudo xed /etc/sane.d/gt68xx.conf
find the 3 lines that read:-
# Artec Ultima 2000:
#override "artec-ultima-2000"
#firmware "ePlus2k.usb"
and uncomment the last 2 of those lines, so they now read:-
SAVE the file, and close gedit.
Back in the terminal, run these commands in sequence:
sudo mkdir /usr/share/sane/gt68xx
cd /usr/share/sane/gt68xx
sudo wget http://www.dropbox.com/s/5j3amp86uviolok/Artec-Ultima-2000-firmware.tar.gz
(I extracted that firmware directly from the Artec windows driver, and uploaded it to my dropbox)
sudo tar xvf Artec-Ultima-2000-firmware.tar.gz
sudo chown root:root ePlus2k.usb gt680xfw.usb
sudo chmod a+r ePlus2k.usb gt680xfw.usb
Now unplug your scanner … wait 10 seconds … replug your scanner … test your scanner.
Thank you very much Mark- I will do this later or tomorrow.
