Hi guys
Over the past fews days I’ve been banging my head against a brick wall trying to find a way to back up my home folders (2 user accounts) to a second internal HDD and schedule it to run automatically through the night.
I want the backup to be a straightforward copy so I could restore any individual file or folder without restoring the whole backup.
I’ve tried various applications such as Backintime Gadmin rsync and one or two others but by far the the best for what I want seems to be Luckybackup it’s simple to use and understand and backs up the folders I want the way I want it done providing i do it manually. the problem is i cant get to work automatically with the scheduler, the scheduler is very simple to set up but when the set time come up nothing happens and no errors reported, Luckybackup comes with a very good handbook and followed the instructions letter for letter but it just wont work
I have cron installed but I don’t know if the daemon is running or if there is anything else I need to get this to work
Any help or advice would be much appreciated
EDIT
This is almost a carbon copy of what I’ve done and it works ok it’s just I can’t get to run a a cron job
http://jsmylinux.no-ip.org/backups/luckybackup-overview/home-folder-backup/
I’ve followed these instructions to the letter and it just doesn’t do anything
http://jsmylinux.no-ip.org/backups/luckybackup-overview/automatic-scheduled-backups/
