I just got the missus a Dell Optiplex 755 PC which is much faster than her old PC so she’s happy with that but I have a problem which is the screen resolution is too low the best setting offered in Monitor Settings is 1024x768 is there any way to get a higher resolution because I dont think it’s possible to replace the graphics card on this machine, I.ve also checked in “Additional Drivers” and nothing is being offered
pat@Linux2 ~ $ lshw -c display
*-display:0
product: 82Q35 Express Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 32 bits
capabilities: vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:44 memory:fea00000-fea7ffff ioport:ec90(size=8) memory:d0000000-dfffffff memory:feb00000-febfffff
*-display:1 UNCLAIMED
description: Display controller
physical id: 2.1
bus info: pci@0000:00:02.1
version: 02
width: 32 bits
capabilities: bus_master cap_list
configuration: latency=0
resources: memory:fea80000-feafffff
pat@Linux2 ~ $
pat@Linux2 ~ $ xrandr
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 32767 x 32767
VGA1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.0*
800x600 60.3 56.2
848x480 60.0
640x480 59.9
DVI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
pat@Linux2 ~ $
I share another PC with this monitor which has a resolution of 1680x1050 and that’s good so that would be ok
chloe@Linux3 ~ $ sudo apt-get install read-edid
[sudo] password for chloe:
Reading package lists... Done
Building dependency tree
libwxbase2.8-0 libwxgtk2.8-0 libwxsqlite3-2.8-0 linux-headers-3.13.0-29
linux-headers-3.13.0-29-generic linux-image-3.13.0-29-generic
linux-image-extra-3.13.0-29-generic
Use 'apt-get autoremove' to remove them.
libx86-1
libx86-1 read-edid
0 to upgrade, 2 to newly install, 0 to remove and 0 not to upgrade.
Need to get 99.4 kB of archives.
After this operation, 340 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://gb.archive.ubuntu.com/ubuntu/ trusty/main libx86-1 i386 1.1+ds1-10 [81.7 kB]
Get:2 http://gb.archive.ubuntu.com/ubuntu/ trusty/universe read-edid i386 3.0.1-2 [17.6 kB]
Fetched 99.4 kB in 0s (482 kB/s)
Selecting previously unselected package libx86-1:i386.
(Reading database ... 223933 files and directories currently installed.)
Preparing to unpack .../libx86-1_1.1+ds1-10_i386.deb ...
Unpacking libx86-1:i386 (1.1+ds1-10) ...
Selecting previously unselected package read-edid.
Preparing to unpack .../read-edid_3.0.1-2_i386.deb ...
Unpacking read-edid (3.0.1-2) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up libx86-1:i386 (1.1+ds1-10) ...
Setting up read-edid (3.0.1-2) ...
Processing triggers for libc-bin (2.19-0ubuntu6.3) ...
chloe@Linux3 ~ $ get-edid > emegra-edid
This is read-edid version 3.0.1. Prepare for some fun.
Attempting to use i2c interface
Looks like no busses have an EDID. Sorry!
Attempting to use the classical VBE interface
mmap /dev/zero: Operation not permitted
error initialising realmode interface
do you have full superuser (root) permissions?
I'm sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern <pyrophobicman@gmail.com>.
chloe@Linux3 ~ $ parse-edid < emegra-edid
Partial Read... Try again
chloe@Linux3 ~ $
The screen resolution of 1680x1050 on other PC sharing the monitor may not be accurate
I’ll try to explain
the 2 PC’s share the same monitor through a KVM box (Pats PC & Chloes PC) both running Peppermint 5
Chloes PC packed up so I got another PC (Dell Optiplex)
the plan was to give Pat the Dell and give Chloe Pats old PC, so I took the Hard drive from Chloes PC and put it in Pats old PC which at first seemed to work ok
However I’ve realised there’s a problem because Chloes first PC had a nvidia graphics card and the PC i’ve put her hard drive in has a ATI card and I think it’s causing some confusion because if the monitor settings are set at 1680x1050 Cairo Dock, Chromium or XBMC wont load but they will load if I drop the resolution to the next level down (1400x1050) although XBMC only partially loads
I hope this isn’t as difficult to understand as it was to explain
Have you tried to plug the monitor in directly (bypassing the KVM switch)?
The reason I ask because my missus has an identical PC and the resolution is somewhat higher than yours booted to Debian 7 LiveCD (XFCE) .
So it is not the graphics adaptor limitation (using the i915 driver)
user@debian:~$ sudo lshw -c display
*-display:0
physical id: 2
version: 02
width: 32 bits
capabilities: msi pm vga_controller bus_master cap_list rom
resources: irq:45 memory:fea00000-fea7ffff ioport:ec90(size=8) memory:d0000000-dfffffff memory:feb00000-febfffff -display:1 UNCLAIMED
physical id: 2.1
version: 02
width: 32 bits
capabilities: pm bus_master cap_list
user@debian:~$ xrandr
Screen 0: minimum 320 x 200, current 1280 x 1024, maximum 4096 x 4096
VGA1 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 376mm x 301mm
1280x1024 60.0 + 75.0
1152x864 75.0
1024x768 75.1 60.0
800x600 75.0 60.3
640x480 75.0 60.0
720x400 70.1
The monitor is an ageing Dell 19".
Win 7 also uses the same max. resolution
I did as you suggested and bypassed the KVM box and it’s made no difference the best I can get is still 1024x768, the monitor is certainly capable of higher resolution as the other PC connected to it is running at 1600x1050
I’m not sure if this significant but the graphics card doesn’t have a VGA socket so I have a DVI to VGA adaptor connected
pat@Linux2 ~ $ sudo get-edid > my-edid.bin
[sudo] password for pat:
Performing real mode VBE call
Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
Function supported
Call successful
VBE version 300
VBE string at 0xc01d8 "ATI ATOMBIOS"
VBE/DDC service about to be called
Report DDC capabilities
Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
Function supported
Call successful
Monitor and video card combination does not support DDC1 transfers
Monitor and video card combination supports DDC2 transfers
0 seconds per 128 byte EDID block transfer
Screen is not blanked during DDC transfer
Reading next EDID block
Read EDID
Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
Function supported
Call successful
Looks like VBE was successful. Have a good day.
pat@Linux2 ~ $ parse-edid < my-edid.bin
Checksum Correct
Section "Monitor"
Identifier "LCD-MONITOR"
ModelName "LCD-MONITOR"
VendorName "LCD"
# Monitor Manufactured week 44 of 2007
# EDID version 1.3
# Analog Display
DisplaySize 430 270
Gamma 2.20
Option "DPMS" "true"
Horizsync 31-82
VertRefresh 56-76
# Maximum pixel clock is 160MHz
#Not giving standard mode: 1152x864, 75Hz
#Not giving standard mode: 1280x1024, 60Hz
#Not giving standard mode: 1280x960, 60Hz
#Not giving standard mode: 1280x960, 75Hz
#Not giving standard mode: 1280x720, 75Hz
#Not giving standard mode: 1440x900, 60Hz
#Not giving standard mode: 1680x1050, 60Hz
#Not giving standard mode: 1400x1050, 60Hz
Modeline "Mode 0" 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
EndSection
pat@Linux2 ~ $
