Setting up a SSH config
With reference to the discussion with @Keith on hardware keys, a very basic setup for ssh involves installing (on Ubuntu as a point of reference) openssh-client and openssh-server packages. Once installed (especially on the server) immediately edit;
/etc/ssh/sshd_config
Search for “assword” and make sure you have;
PasswordAuthentication no
If you changed anything, do service ssh restart. This will prevent anyone from logging into that system just using a username and password. Next, go to your client machine and do;
ssh-keygen
To get going, accepting the defaults should work for you. Next, on the server system, go to the user account you will be logging in to and;
sudo su - user
mkdir .ssh
cd .ssh
touch authorized_keys2
chmod 600 authorized_keys2
edit authorized_keys2
Then paste in the contents of the public key from your client machine, i.e. the contents of;
~/.ssh/id_rsa.pub
At this point, save authorized_keys2 and you should (!) be good to go, on your client machine;
ssh user@ip_address
Where user is the name of the user you set up on the server, and ip_address is the name or IP address of the server. The client machine should now have a working shell session on the server machine. If you don’t want to use the ip_address, all you need do is add an entry in /etc/hosts;
1.2.3.4  server_name
(where 1.2.3.4 is your real IP address, and server_name is the name you want to reference the server as)
If you get stuck add -v to your ssh command and it should give some pretty verbose feedback about what it’s doing. On the server, you can look in /var/log/auth.log and it should also give some indication of why it’s failing.
I may have skipped something or something isn’t clear, if you try this and it breaks, let me know and I’ll attempt to improve it.
ssh
Many thanks for that.
It may be a while before I’m able to try it, but I’ll report on progress.
