last night my Grand-daughters PC refused to boot, the problem was the graphics card which was an nVidia, so I’ve removed the card and reverted back to the onboard card which an SiS I know SiS cards can be a problem in Linux but it’s actually working fine except when I try to open XBMC a error message pops up saying XBMC needs 3D acceleration which presumably the onboard card doesn’t have, so my question is is there any way to enable 3D acceleration with this card or make XBMC run without 3D acceleration
chloe@Linux3 ~ $ lshw -c display
*-display UNCLAIMED
product: 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter
vendor: Silicon Integrated Systems [SiS] physical id: 0
bus info: pci@0000:01:00.0
version: 03
width: 32 bits
clock: 66MHz
capabilities: vga_controller cap_list
configuration: latency=0
resources: memory:d8000000-dfffffff memory:febe0000-febfffff ioport:e800(size=128)
chloe@Linux3 ~ $
ok i installed the SiS driver as per your link and created the xorg.conf file and the world never shifted on it’s axis in fact nothing noticable really happened at all so it looks like i’m in the market for another pci express graphics card
I’m pretty certain it’s pci-e, I have at least half a dozen AGP cards lying around and this one is different, anyway I’ve uploaded an image of 2 video cards the card on the left (Asus) is the card that fits into the motherboard which I’m assuming is pci-e and the other is an AGP
did you check if it got loaded without an xorg.conf fie ?
I checked in as much as rebooting without the xorg.conf file and it made no noticable difference then I created the xorg,conf and rebooted again but still no difference
However this morning I was a local boot sale and there’s a guy there every week who sells second hand PC’s and parts and he let me rake through a box of cards that he had and I got 3 PCIe cards to try one is a ATI Radeon but I don’t know what the other 2 are hopefully at least one of them is an nVidea because in my experience ATI is a problem, anyway I’ll try them out and let you know
2 of the cards are ATI, I cant figure out the make of the other as the PC wont boot with it inserted so whatever it is it’s a complete non starter
Both ATI cards appear to work ok untill I try to open XBMC where it just freezes on the start screen, I’ve checked Additional Drivers for both cards and none are offered
If there is I can’t find it, there is a .XBMC folder in the Home directory and I’ve searched through but no xbmc.conf file that I can see, there’s also an XBMC folder located in /usr/share but no xbmc.conf file there either
If there was one where would it most likely be and what’s the best way to find it ?
EDIT
There is a bunch of xbmc crash log filer in the home directory maybe that will help
I don’t know if it’s any use to me but I downloaded it and it’s a .run file which attempts to open in gedit but wont there’s no clues anywhere what I do with this file
I don't think you're not going to get this card to work with new versions of xbmc/kodi .. you're not going to get 3d acceleration working.
Yeah you’re right I’ve just wasted the past 3 hours of my life trying to prove you wrong by following a Spatry tutorial on how to install proprietary ATI drivers, never again
I was actually looking at that very card you posted the link for a couple of days ago so I’m glad you posted it as it confirms it’s the right card for me
I could have told you the proprietary ATI drivers are unlikely to help you … if the drivers you linked to earlier are the only ATI drivers that support your card
a) the newer AMD drivers probably won’t support it as the cards are probably considered “legacy” … otherwise the fglrx driver would likely be being offered to you by “Additional Drivers”
b) the drivers you lkinked to will not work with modern versions of Xorg
Yep, AMD really did a number on ATI customers
Considering the higher end ATI cards (4850/4870/4890) can STILL outperform new cards despite being 6-7 years old (well, not in the power stakes!), yet AMD decided to drop support like a brick >:(
Good enough for me to never buy AMD again.
Edit: OP - you should be able to get 3D acceleration working on the open-source xorg drivers if the cards are recent enough (should perform well enough for XBMC). Which ATI cards are these?
