Thinking of ditching my 3G dongle and having Sky Broadband installed.
Will a Sky router work on Linux…?
Jocklad
Jocklad
Hi Jocklad
Will a Sky router work on Linux.....
Can’t see any reason why not as far as I’m aware routers are not OS dependent, routers should work with any OS
Thanks Graeme.
Was thinking about wireless drivers ect.
Jocklad
I’m on sky broadband and only run linux, works for me
That’s not really anything to do with the router you only connect to the router not install it
If you post the output of
lshw -c network
we can see if you have any wireless adaptors installed and we can take it from there
Thanks Cortezz.
Will get installation ordered.
Jocklad
[quote author=Emegra link=topic=11398.msg90920#msg90920 date=1389196719]
If you post the out put of
lshw -c network
Think we are ok to go here.
Was just Sky was not sure about.
Thanks Guys.
Jocklad
I too am on Sky broadband.
But realistically ANY broadband should work with Linux.
The router uses 802.11(x) standard for wireless communication … so as long as the wireless card you choose works with Linux it should communicate with the router.
Thanks Mark. ;D
What sort of speed do you get with Sky??
http://www.thinkbroadband.com/speedtest/button/138991990695354735647.png
That’s obviously over copper
Ok, this is BT … it’s slowed down a lot in the last year … >:(
http://www.thinkbroadband.com/speedtest/button/138997485379050049184.png
My download speed at home (on sky) only ever really gets to 1.3Mbps. I want optics … But they don’t do it for my area so I can’t unfortunately
