Smart Card Reader not seen by my system. (Resolved)
I use mint 17.2 64bit mate.
I have a new smart card reader which should allow me to access a wide range of services.
Having installed the driver from this location http://eid.belgium.be/en/using_your_eid/installing_the_eid_software/linux
The card reader is not mounted when plugged into the USB port.
Any help welcome…
What’s the output from:
dpkg -l | grep libbeid
dpkg -l | grep eid-viewer
Can you install pcsc_scan:
sudo apt-get install pcsc_scan
and post the output from:
ps aux | grep [p]cscd
pcsc_scan
Here is the output-
userone@Office2 ~ $ dpkg -l | grep libbeid
userone@Office2 ~ $ dpkg -l | grep eid-viewer
userone@Office2 ~ $
userone@Office2 ~ $ sudo apt-get install pcsc_scan
[sudo] password for userone:
Reading package lists… Done
Building dependency tree
E: Unable to locate package pcsc_scan
userone@Office2 ~ $
userone@Office2 ~ $ ps aux | grep [p]cscd
root 1937 0.0 0.0 181680 4876 ? Sl 09:33 0:00 /usr/sbin/pcscd
userone@Office2 ~ $ pcsc_scan
PC/SC device scanner
V 1.4.22 (c) 2001-2011, Ludovic Rousseau ludovic.rousseau@free.fr
Compiled with PC/SC lite version: 1.8.10
Using reader plug’n play mechanism
Scanning present readers…
0: Generic Smart Card Reader Interface [Smart Card Reader Interface] (20070818000000000) 00 00
Fri Oct 23 09:50:15 2015
Reader 0: Generic Smart Card Reader Interface [Smart Card Reader Interface] (20070818000000000) 00 00
Card state: Card removed,
OK, run these commands in sequence:
cd ~/Desktop
wget http://eid.belgium.be/sites/default/files/downloads/eid-archive_2015.4_all.deb
sudo dpkg -i eid-archive_2015.4_all.deb
sudo apt-get install eid-viewer libbeidpkcs11-0 eid-mw
now see if there’s a card reader at:-
menu > Accessories > eID Viewer
If there is, you can now delete the eid-archive_2015.4_all.deb file from your desktop.
Is not in Accessories
Everything went OK until-
userone@Office2 ~/Desktop $ sudo apt-get install eid-viewer libbeidpkcs11-0 eid-mw
E: Unable to locate package eid-viewer
What happens if you run:
sudo dpkg-reconfigure eid-archive
There’s no definition for “Rafaela” in their repo, so it won’t work for Mint 17.2, only Mint 17.0 (Qiana)
We can manually download the packages and install them but I need to confirm Mint has gdebi installed … run:
sudo apt-get install gdebi
did it either say it’s already installed or actually install it ?
userone@Office2 ~ $ sudo apt-get install gdebi
gdebi is already the newest version.
libsoprano4 shared-desktop-ontologies soprano-daemon
0 to upgrade, 0 to newly install, 0 to remove and 24 not to upgrade.
userone@Office2 ~ $
OK download these 4 files, and double click them to install them (in the order below)
http://files.eid.belgium.be/debian/pool/main/e/eid-mw/libbeidpkcs11-bin_4.1.9v4.1.9-0trusty1_amd64.deb
http://files.eid.belgium.be/debian/pool/main/e/eid-mw/libbeidpkcs11-0_4.1.9v4.1.9-0trusty1_amd64.deb
http://files.eid.belgium.be/debian/pool/main/e/eid-mw/eid-mw_4.1.9v4.1.9-0trusty1_amd64.deb
http://files.eid.belgium.be/debian/pool/main/e/eid-viewer/eid-viewer_4.1.9v4.1.9.1.g095fcbc-0trusty1_all.deb
That’s cracked the problem and it is working OK.
Thanks for your help.
You’re most welcome … remember because you had to manually install the files they won’t receive automagic updates
It might be worth keeping an eye out here:
and if you ever notice a folder appear called rafaela … go back here:
and download/install the new eid-archive (.DEB) … you’ll then get automagic updates.
