[SOLVED] Banshee crashed
You’ll probably laugh your heads off at this one…
I let our Alsation in and he rushed past the PC, wagging his tail and hit the power button which caused the PC to reboot but it didn’t do a propper reboot (it kind of shut itself down but didn’t come back properly) so I had to press it again to make it reboot properly.
When it rebooted, I tried running Banshee but it came up with ‘Fatal Error’
[spoiler]An unhandled exception was thrown: Sqlite error 11: database disk image is malformed (SQL: SELECT COUNT(*) FROM CoreTracks)
at Hyena.Data.Sqlite.Connection.CheckError (Int32 errorCode, System.String sql) [0x00000] in :0
at Hyena.Data.Sqlite.Statement.CheckError (Int32 code) [0x00000] in :0
at Hyena.Data.Sqlite.QueryReader.Read () [0x00000] in :0
at Hyena.Data.Sqlite.Statement.Query[Object] () [0x00000] in :0
at Hyena.Data.Sqlite.Connection.Query[Object] (System.String sql) [0x00000] in :0
at Hyena.Data.Sqlite.HyenaSqliteCommand.Execute (Hyena.Data.Sqlite.HyenaSqliteConnection hconnection, Hyena.Data.Sqlite.Connection connection) [0x00000] in :0
Exception has been thrown by the target of an invocation.
at System.Reflection.MonoCMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object parameters, System.Globalization.CultureInfo culture) [0x00000] in :0
at System.Reflection.MonoCMethod.Invoke (BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object parameters, System.Globalization.CultureInfo culture) [0x00000] in :0
at System.Reflection.ConstructorInfo.Invoke (System.Object parameters) [0x00000] in :0
at System.Activator.CreateInstance (System.Type type, Boolean nonPublic) [0x00000] in :0
at System.Activator.CreateInstance (System.Type type) [0x00000] in :0
at Banshee.ServiceStack.ServiceManager.RegisterService (System.Type type) [0x00000] in :0
at Banshee.Gui.GtkBaseClient.Startup () [0x00000] in :0
at Hyena.Gui.CleanRoomStartup.Startup (Hyena.Gui.StartupInvocationHandler startup) [0x00000] in :0
.NET Version: 4.0.30319.1
OS Version: Unix 3.0.0.23
Assembly Version Information:
System.Configuration (4.0.0.0)
gconf-sharp (2.24.0.0)
Banshee.Gnome (2.4.0.0)
Banshee.NowPlaying (2.4.0.0)
System.Xml (4.0.0.0)
Banshee.Core (2.4.0.0)
Hyena.Data.Sqlite (2.4.0.0)
gdk-sharp (2.12.0.0)
Mono.Addins (0.6.0.0)
atk-sharp (2.12.0.0)
Hyena.Gui (2.4.0.0)
Mono.Posix (4.0.0.0)
gtk-sharp (2.12.0.0)
Banshee.ThickClient (2.4.0.0)
Nereid (2.4.0.0)
DBus.Proxies (0.0.0.0)
dbus-sharp-glib (1.0.0.0)
System.Core (4.0.0.0)
Hyena (2.4.0.0)
dbus-sharp (1.0.0.0)
glib-sharp (2.12.0.0)
System (4.0.0.0)
Banshee.Services (2.4.0.0)
Banshee (2.4.0.0)
mscorlib (4.0.0.0)
Platform Information: Linux 3.0.0-23-generic x86_64 x86_64 GNU/Linux
Disribution Information:
[/etc/lsb-release]
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=11.10
DISTRIB_CODENAME=oneiric
DISTRIB_DESCRIPTION=“Ubuntu 11.10”
[/etc/debian_version]
wheezy/sid
[/spoiler]
Did a bit of searching and saw ‘debug’ and how to use it and here is the result;
peter@Petes-ubuntu-pc:~$ banshee --debug
** Running Mono with --debug **
[1 Debug 22:34:31.365] Bus.Session.RequestName (‘org.bansheeproject.Banshee’) replied with PrimaryOwner
[1 Info 22:34:31.385] Running Banshee 2.4.1: [Ubuntu 11.10 (linux-gnu, x86_64) @ 2012-07-05 20:42:53 UTC]
[1 Debug 22:34:31.414] Initializing GTK
[1 Debug 22:34:32.559] Post-Initializing GTK
[1 Debug 22:34:32.571] Configuration client extension loaded (Banshee.GnomeBackend.GConfConfigurationClient)
[1 Debug 22:34:32.574] Using default gconf-base-key
[1 Debug 22:34:32.660] Core service started (DBusServiceManager, 0.001411)
[1 Debug 22:34:32.663] Registering remote object /org/bansheeproject/Banshee/DBusCommandService (Banshee.ServiceStack.DBusCommandService) on org.bansheeproject.Banshee
[1 Debug 22:34:32.670] Core service started (DBusCommandService, 0.008613)
[4 Debug 22:34:32.699] Exception executing command: SELECT COUNT() FROM CoreTracks
[4 Warn 22:34:32.703] Caught an exception - Hyena.Data.Sqlite.SqliteException: Sqlite error 11: database disk image is malformed (SQL: SELECT COUNT(
) FROM CoreTracks) (in `Hyena.Data.Sqlite’)
[1 Error 22:34:32.704] Error initializing required service Banshee.Database.BansheeDbConnection
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> Hyena.Data.Sqlite.SqliteException: Sqlite error 11: database disk image is malformed (SQL: SELECT COUNT(*) FROM CoreTracks)
See this wiki:
https://wiki.edubuntu.org/DebuggingBanshee
Look at Database Corrupted if your logfile has texts like: “Sqlite error 11: database disk image is malformed”
You might need to install sqlite3:
sudo apt-get install sqlite3
Just tried that and it says it’s already installed…
Will take a look at the link you posted.
peter@Petes-ubuntu-pc:~$ sudo apt-get install sqlite3
[sudo] password for peter:
Reading package lists… Done
Building dependency tree
sqlite3 is already the newest version.
sqlite3 set to manually installed.
libzemberek-tr-java tsocks socat libsexy2 libzemberek-java
Solved how?
Check the bottom of the page…
It turned out to be the library database
