(SOLVED) Flashplugin-installer
Re installed Mint 4 recently. I keep getting this message.
Failure to download extra data files
[b]The following packages requested additional data downloads after package installation, but the data could not be downloaded or could not be processed.
flashplugin-installer
The download will be attempted again later, or you can try the download again now. Running this command requires an active Internet connection.
[/b]
If run the command:
[b]flashplugin-installer: downloading http://archive.canonical.com/pool/partner/a/adobe-flashplugin/adobe-flashplugin_11.2.202.310.orig.tar.gz[/b]
it just sits there doing nothing. When I re boot the same notice comes up again.
Any thoughts?
First thing to try -
sudo apt-get remove --purge flashplugin-installer
sudo apt-get install flashplugin-installer
That seems to have done it. Thanks
Всегда пожалуйста :slight_smile:
