[SOLVED] PC World 'filxed' my wifes laptop, now wireless adapter not found
My wifes laptop recently went in to get the screen fixed and it came back not working.
The repair report: 'What we’ve done… We have repaired the parts listed below. TO HELP PREVENT ISSUES IN THE FUTURE WE HAVE ALSO RESET THE INCORRECT SETTINGS TO DEFAULT. Cleaned your heatsink & fan and tightened some loose screws. We then ran some system checks to ensure your issue has been fully resolved.
nice that they don’t tell me exactly WHAT settings they have reset.
Because of their tinkering with things they had no need to tinker with as all they needed to do was replace the laptop lid & screen, I am now unable to connect wirelessly to the internet.
The laptop is an ASUS Notebook X541B running Kubuntu 16.04
  1. It could be that they have just physically turned wifi off. Make sure that it is physically turned on.
  2. What is the output of: lspci | grep Network
What’s the output from
lsusb
lspci -vnn | grep -i net
sudo rfkill list
iwlist scan
as well as checking wireless isn’t disable by a hardware switch (or key combo), check it hasn’t been disabled in the BIOS.
BTW, if these guys changed some “incorrect” settings, do they understand Linux ? … I wouldn’t have expected PC World techs to.
(or are you dual booting? … if not, it MAY suggest they changed some stuff in the BIOS)
PC World? Loose screws? Whatever next?
If it’s not something daft like wifi switched off or a matter of signing in to your network then personally I would take it back to PC crapworld and tell them to fix it, they had no right pissing about with the way you had it set up they were only asked to fix screen.
“We have repaired the parts listed below. TO HELP PREVENT ISSUES IN THE FUTURE " were you charged for this or was it in with the price?it stinks of them bumping up the price of repair. Would you allow a garage to replace tyres on a car if fixing the windscreen"TO HELP PREVENT ISSUES IN THE FUTURE” of course you wouldnt.
One of my pet hates are shops that think they are always right and trying to hide behind T&c’s thinking that it overules Consumer rights act 2015 which was was sales of goods act.
Sorry rant over.grrrrrrr
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 04f2:b52b Chicony Electronics Co., Ltd
Bus 001 Device 005: ID 13d3:3423 IMC Networks
Bus 001 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 07)
Subsystem: ASUSTeK Computer Inc. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [1043:205f]
03:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
Subsystem: AzureWave QCA9565 / AR9565 Wireless Network Adapter [1a3b:213a]
sudo rfkill list
0: asus-wlan: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: asus-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
iwlist scan
wlp3s0 Failed to read scan data : Network is down
enp2s0 Interface doesn’t support scanning.
This is the result of me allowing wireless back on
iwlist scan
wlp3s0 Scan completed :
Cell 01 - Address: C0:3E:0F:79:F9:F9
Channel:1
Quality=62/70 Signal level=-48 dBm
Encryption key:on
ESSID:“SKYA6E85”
24 Mb/s; 36 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000001910431c9fd
Extra: Last beacon: 3396ms ago
IE: Unknown: 0008534B594136453835
IE: Unknown: 030101
IE: Unknown: 0706444520010D14
IE: Unknown: 200100
IE: Unknown: 23021100
IE: Unknown: 2A0100
IE: Unknown: 2F0100
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
IE: Unknown: 32040C121860
IE: Unknown: 0B0503001E0000
IE: Unknown: 2D1ABC181BFFFF000000000000000000000000000000000000000000
IE: Unknown: 3D1601080400000000000000000000000000000000000000
IE: Unknown: 7F080400080000000040
IE: Unknown: DD800050F204104A0001101044000102103B00010310470010854B3C384A590979A2DC596A70F63E631021000842726F6164636F6D1023000842726F6164636F6D1024000631323334353610420004313233341054000800060050F20400011011000A42726F6164636F6D415010080002200C103C0001011049000600372A000120
IE: Unknown: DD090010180203000C0000
IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
IE: Unknown: 46057200010000
Cell 02 - Address: EC:8E:B5:F4:1D:07
Channel:6
Quality=35/70 Signal level=-75 dBm
Encryption key:on
ESSID:“DIRECT-06-HP ENVY 4520 series”
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=000005d987e999e7
IE: Unknown: 001D4449524543542D30362D485020454E5659203435323020736572696573
IE: Unknown: 01088C129824B048606C
IE: Unknown: 030106
IE: Unknown: 200100
IE: Unknown: 2A0100
IE: Unknown: 2F0100
Group Cipher : CCMP
IE: Unknown: 2D1A20001AFF00000000000000000000000000000000000000000000
IE: Unknown: 3D1606080000000000000000000000000000000000000000
IE: Unknown: DD090010180200000C0000
IE: Unknown: DD180050F202010188000364000027A4000041435E0061322F00
IE: Unknown: DDC10050F204104A000110104400010210570001011041000100103B000103104700101C852A4DB8001F08ABCDEC8EB5F41D0610210002485010230011454E565920343532302073657269657300102400053435323300104200105448363747334B3048533036363000001054000800030050F20400051011001D4449524543542D30362D485020454E56592034353230207365726965731008000200001049000600372A00012010490017000137100600101C852A4DB8001F08ABCDEC8EB5F41D06
IE: Unknown: DD5F080009000400000007010201000311454E5659203435323020736572696573000405343532330005105448363747334B30485330363630000006101C852A4DB8001F08ABCDEC8EB5F41D060704C0A80103080200D4090200080A0400000001
Cell 03 - Address: C4:05:28:FB:BE:78
Channel:6
Quality=56/70 Signal level=-54 dBm
Encryption key:on
ESSID:“TALKTALK-FBBE70”
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
18 Mb/s; 36 Mb/s; 54 Mb/s
Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
Mode:Master
Extra:tsf=0000001882ceeb76
IE: Unknown: 000F54414C4B54414C4B2D464242453730
IE: Unknown: 010882848B961224486C
IE: Unknown: 030106
IE: Unknown: 2A0100
IE: Unknown: 32040C183060
IE: Unknown: 2D1A8E1103FFFF0000010000000000000000000000000C0000000000
IE: Unknown: 3D1606050600000000000000000000000000000000000000
IE: Unknown: 3E0100
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : TKIP CCMP
Group Cipher : TKIP
IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
IE: Unknown: 0B05010014127A
IE: Unknown: DD08000C430400000000
IE: Unknown: 0706474220010D10
IE: Unknown: DD9D0050F204104A0001101044000102103B000103104700102880288028801880A880C40528FBBE781021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020082103C000101
Cell 04 - Address: 08:3E:5D:F1:8B:78
Channel:11
Quality=30/70 Signal level=-80 dBm
Encryption key:on
ESSID:“PLUSNET-5FGR”
Mode:Master
Extra:tsf=000000dbd6789663
IE: Unknown: 000C504C55534E45542D35464752
IE: Unknown: 03010B
IE: Unknown: 0706474220010D14
IE: Unknown: 2A0100
Group Cipher : CCMP
IE: Unknown: 32043048606C
IE: Unknown: 2D1AAC011BFFFF000000000000000000008000000000000000000000
IE: Unknown: 3D160B000500000000000000000000000000000000000000
IE: Unknown: 7F080100000000000040
IE: Unknown: DD8D0050F204104A000110104400010210570001001041000100103B0001031047001081F49746B7675FD59D03F0F3BC77102210210002425410230005487562203510240009425420487562203541104200122B3038313434312B4E5137313430373138381054000800060050F20400011011000F506C75736E657420487562204F6E65100800020084103C000101
Cell 05 - Address: F0:C8:50:B0:95:50
Channel:1
Quality=31/70 Signal level=-79 dBm
Encryption key:on
ESSID:“TALKTALKB0954A”
Mode:Master
Extra:tsf=0000009f91941c2c
IE: Unknown: 000E54414C4B54414C4B423039353441
IE: Unknown: 030101
IE: Unknown: 2A0100
IE: Unknown: 2D1A8E191FFFFF000000000000000000000000000000001804810000
IE: Unknown: 3D1601000000000000000000000000000000000000000000
IE: Unknown: 4A0E14000A00B400C800140005001900
IE: Unknown: 7F0101
IE: WPA Version 1
Group Cipher : TKIP
Group Cipher : TKIP
IE: Unknown: DD1E00904C338E191FFFFF000000000000000000000000000000001804810000
IE: Unknown: DD1A00904C3401000000000000000000000000000000000000000000
IE: Unknown: DD0600E04C020160
IE: Unknown: DDA60050F204104A0001101044000102103B0001031047001063041253101920061228F0C850B095501021001B5265616C74656B2053656D69636F6E647563746F7220436F72702E1023000752544C387878781024000D45562D323031302D30392D32301042000F3132333435363738393031323334371054000800060050F2040001101100114144534C204D6F64656D2F526F757465721008000206801049000600372A000120
Cell 06 - Address: 92:72:82:96:EB:4D
Channel:11
Quality=29/70 Signal level=-81 dBm
Encryption key:off
ESSID:“BTWifi-with-FON”
Mode:Master
Extra:tsf=0000001080ba9096
Extra: Last beacon: 26404ms ago
IE: Unknown: 000F4254576966692D776974682D464F4E
IE: Unknown: 03010B
IE: Unknown: 2A0100
IE: Unknown: 3D160B080000000000000000000000000000000000000000
When it goes off, does running
sudo rfkill unblock all
bring wireless back ?
A precursor to that command ^^^ is
sudo rfkill list
No, but it stops trying to constantly connect and report no wireless connection.
Do you have more than one wireless network configured in network manager ?
No, the others you see are what the laptop is picking up from other houses, mine is the first one, SKYA6E85
I realise that, I just wondered if you also had 2 (or more) wireless profiles configured in networkmanager.
You might want to change your routers channel to say channel 3, 4, 8 or 9 because someone else close to you is also using channel 1
and check if that makes a difference.
Is 16.04 particularly problematic? Would an upgrade to 18.04 be better?
https://grenangen.se/node/86
Since getting the laptop back there’s been quite a few updates and the wireless problem seems to have fixed itself!!!
Great news :slight_smile:
Yep, great news, but sadly, the lptop has just packed in, it won’t power up with the mains power connected. So it looks like another trip to the dreadded PC World…
Or a second hand Dell ‘E’ Series :wink:
It was the power cable, more precisely, the bit that plugs into the laptiop, it’s not a very good fit, slightly loose.
So you don’t need a new PC ? … that’s great news :slight_smile:
