[SOLVED] Platform Device Creation Failed
I have just tried to reboot my laptop (Kubuntu 16.04) and it failed to boot OK, I got the following warning;
I had not long ago had the same problem (less than a week) and after a quick google, found no solution, so I had to resort to re-installing the system. I don’t want to have to do that this time. I tried Boot Repair Disk but it reported it could not continue due to having a UEFI partition or something similar.
http://i.imgur.com/PGH5rwF.png
What happens if you hit Ctrl+D to continue … do you end up at a text console ?
If so, what happens if you log in in text mode, then run:
sudo service lightdm restart
I ended up reinstalling the OS.
I’ve encountered the same problem again, this time I don’t want to reinstall the OS as it seems it’s a recurring problem.
I tried what you said Mark but it failed, I entered
With & without sudo
I booted into recovery mode (root) and CTRL+D goes back to the recovery menu.
I get the warning;
failed to restart lightdm.service:Unit lightdm.service not found
The second screenshot mentions UEFI, when I tried to use my recovery disc, I was informed it couldn’t do it due to something to do with UEFI.
http://i.imgur.com/ZOaD8sl.jpg
http://i.imgur.com/6WSCb8e.jpg
I have a multiboot USB with an upto date copy of boot repair and when I run it I get a warning ‘BIOS-Boot detected. You may want to retry after deactivating the [Separate /boot/efi partition:] option.
Do you want to continue?’
The problem is, I don’t know how to deactivate it!
Check your PC’s BIOS and see if there is a setting to turn off the Trusted Platform Module (TPM).
Sorted it.
I had a look at the partitions with Gparted Live and the EFI one had ‘—’ for used & free instead of an actual amount, so I reformatterd it and reset it and then rebooted and it fixed it.
The secureboot is switched on/off when legacy is used/not used, so it was off as legacy was not selected.
I now no longer get a warning similar to that of the first 2 lines in the screenshot(s)
Nice, glad you figured it out :slight_smile:
