W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
W: You may want to run apt-get update to correct these problems
E: Unable to locate package vlc-plugin-libde265
Anyone had the same problem or have you managed to install the codec without problems, could you please help me.
I have looked and I have HEVC codec installed (h265). I thought I didn’t as the thumbs were not showing any little picture, making me think that it was broken.
It was only seeing ‘h265’ in the drop-down menu that I realised I did have it.
Not sure if I’ll know the answer anyway pooky, I don’t do any video ripping/conversion/editing these days … but maybe someone else will know if you clarify the question a little
It’s sorted.
The problem was, I was downloading video which had HEVC h265 codec and was not displaying a thumbnail, which I thought was broken.
I investigated the problem and found that it was the codec I needed, which you helped me install. I then still thought it was broken/not installed properly as the thumbnail was of a broken film image.
It wasn’t until I saw the result in the post with the picture of the settings for Handbrake showing h265 that I realised that it WAS installed, yet there is still no picture showing for the thumbnail, still just a broken film image.
It’s quite possible that whatever displays the thumbnails doesn’t understand h265 … I don’t know that much about dolphin and its plugins
(you are a KDE user right ?)
Duh! of course you are it says so in your sig … learn to be more observant Mark
