With this talk of computer two and computer one, and removing Peppermint to install Windows when Windows is already on one of the PC’s … I’m seriously confused :o
Let just talk about the PC you want to change eh.
Tell me what’s already installed, and what you want to achieve.
Peppermint is the only OS on the computer
I have the Windows XP CD and the key.
The machine is a desktop
I don’t know about recovery partition or recovery disc.
a) insert the XP CD, and boot from it … at some point it will ask you where you want to install it and display the partition layout, now reaad what’s on the screen carefully, you’ll see options like hit D to delete …you need to delete ALL the current partitions (extended partition last), then create a single partitoin that fills the entire disk, and when asked, tell it do format it as NTFS full format) …then it will carry on with the install.
b) boot to your Peppermint LiveCD, then start Gparted, and use it to delete ALL 3 partitions (extended sda2 partition last) … then either create a single NTFS partition in Gparted, or shut down, boot the Windows CD and use that to create a single NTFS partition during the install.
(this method MUST be done from a LiveCD/USB, Gparted cannot delete mounted partitions, so it cannot be done whilst booted to the hard drive)
Once the 3 Linux partitions have been deleted, Peppermint/Linux is GONE, and this really becomes a Windows installation question … but I’ll still help if you become stuck … Wouldn’t want people to say I’m biased (even though I freely admit I AM)
BTW, you do realise you’re going to need to find Windows drivers for all your hardware ? … XP won’t install them itself like Linux … though it should install enough to get you up and running, you’ll then have to download things like your graphics card, printer, wireless adapter, and any other required drivers and install them yourself … so if you normally connect by wireless, it may be a good idea to get those first and have them ready on a CD or USB stick.
Unless I am mistaken you are only wanting to install XP for using AutoCad?
Could you not try to install XP in a VM like VirtualBox or like?
http://www.wikihow.com/Install-Windows-XP-on-Ubuntu-with-VirtualBox
Without trying I do not know how well AutoCad would perform.
I do use AutoCad on daily basis and this is something I should do too (soon)
If you are running AutoCad then you DO have lots of ram in the first place. But the requirements are not that huge.
in my experience 2GB is just fine. It is Windows that eats up all your ram.
Hi Guys,
I have removed PeppermintOS2 and re installed XP and Autocad and everything runs well.
However the monitor on this machine is too small to run Autocad comfortably.
I do not intend to swap monitors, so I will set this machine back to PeppermintOS when Ver.3 arrives.
Hmm … slightly tougher/riskier … and as previously mentioned, really a windows question.
Use a LiveCD or LiveUSB and gparted to delete ALL the Linux partitions … then resize the Windows partition to fill the space vacated by the Linux partitions.
then reinstall the Windows bootloader, by booting the XP CD, accessing the the “Recovery Console”, then running fixmbr and fixboot
BE AWARE … ANY partition manipulation procedure carries a small risk of data corruption … so backup anything you cannot afford to loose FIRST … you have been warned
If windows is still there (and it probably is), it’s probably just a bootloader issue … have you tried booting to the XP CDROM, then when propted hitting F6 (or whatever it is) to access the “Recovery Console”, then running:
fixmbr
and fixboot
It’s never a doorstop unless it’s a hardware fault … worst case scenario, wipe the hard drive, and reinstall Windows from scratch … but that’s “worst case”, it’s probably still fixable without going to those lengths.
I have PeppermintOS 2 on the other computer and it works great.
I was just trying to put XP on this computer to run Autocad.
take care
Don W
PS When I start this computer it goes into a continual loop.
It arrives at a screen that offers a startup choice of
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last known good configuration
Start Windows normally
If I pick any of the first 3 it opens another screen that loads Windows drivers, then says Press Escape to cancel loading a347bus.sys.
I have tried every configuration that is offered but the machine just loops back from the bios setup screen to the loading screen.
This loop means I have to pull the plug to stop the machine >:(
