SOLVED Side panel on Nautilus
I have been using Ubuntu for two years now for myself, but we have just built a new machine to take to a friend in France.
On my machine there is the panel down the left side listing the various locations; Home, Network etc., but on the new machine this is missing. I cannot find anywhere in the settings to make it appear so I would much appreciate a push in the right direction.
Thank you.
Does it not appear if you shove your mouse pointer against the left hand side of the screen ?
You might want to look at this:
if you have an optimus setup.
or try running:
dconf reset -f /org/compiz/
what’s the output from:
sudo lshw -C display
Or try installing My Unity. I can’t remember who advised me to try it. I think it was Emegra. Sorry can’t check if it is in software as I am using PM4 now…gave up on Ubuntu. I seem to remember that it gave you control on what the sidebar did.
Here is a link to Wiki http://www.wikihow.com/Install-My-Unity-Configuration-Tool-on-Ubuntu
Thank you for your replies and I am sorry for the delay.
These are the replies:
doug@Win8Ubuntu:~$ dconf reset -f /org/compiz/
The program ‘dconf’ can be found in the following packages:
  • dconf
  • dconf-tools
    Try: sudo apt-get install
    doug@Win8Ubuntu:~$ sudo lshw -C display
    [sudo] password for doug:
    *-display
    product: RS780L [Radeon 3000]
    vendor: Hynix Semiconductor (Hyundai Electronics)
    physical id: 5
    bus info: pci@0000:01:05.0
    version: 00
    width: 32 bits
    capabilities: pm msi vga_controller bus_master cap_list rom
    configuration: driver=radeon latency=0
    resources: irq:18 memory:d0000000-dfffffff ioport:d000(size=256) memory:feaf0000-feafffff memory:fe900000-fe9fffff
I am about to look at My Unity
Bother, can’t see an edit button.
Nudging the left edge does not bring up the list.
To edit a post … use the “Modify” button :wink:
Let us know if My Unity helps.
Well that works, I thank you. As I write this I am listening to Albinoni on Rhythmbox so that works too. We are taking this computer to France tomorrow.
I must say that Linux is an absolute doddle compared to Windows 8 unless you want to natter on Facebook or play games.
What’s the problem with Facebook ? … that should work.
I’m guessing he means Facebook chat - does it not work with Ubuntu’s Firefox? I don’t use FB chat myself…
No, what I mean is that Windows, as it appears to me, is only good for Facebook, Twitter, etc., etc. and all other froth.
Ahh … now that makes sense :slight_smile:
