Do any of you use slock? It’s probably the simplest screen lock out there. There are no graphics just a blank screen. You have to type your password blind to unlock.
Anyway, it was recently updated and now instead of a plain black screen while typing your password it changes to blue. I’ve had a quick scour of the web but I can’t seem to find anything relating to changing the colour.
If anybody out there is having the same issue or knows how to return it to a black screen I’d be interested to know. I know it sounds petty but hey!
Looking through the source it appears that it has been changed in March when they applied Eckehard Bern’s dualcolor patch.
If you are prepared to recompile then it would be trivial to change it back:
You would need to modify config.mk to use the same colour (black) for both DCOLOR1 & DCOLOR2 without changing the code:
