[SOLVED] Unable to rip DVD's
I have K3b, Brasero, Acid:Rip & Handbrake installed and I am unable to backup/rip/copy DVD’s.
In K3b I get "Unable to read video DVD contents: Found encrypted video DVD. Install libdvdcss to get video dvd encryption support. Yet it is installed.
When I use Handbrake and select the source, it scans the DVD but after the scan, it shows as empty!
I don’t know what to do to fix the problem!!!
So you’ve already done
sudo apt-get install libdvdread4
sudo /usr/share/doc/libdvdread4/install-css.sh
That got me a little further, I now get “K3b uses transcode to rip Video DVDs. Please make sure it is installed.”
Try:
sudo apt-get install transcode
if you still have problems, maybe try updating handbrake via their PPA
sudo add-apt-repository ppa:stebbins/handbrake-releases
sudo apt-get install handbrake-gtk handbrake-cli
Looks like it’s working. Could this problem be somehow linked to the problem in my other thread HERE?
Spoke too soon.
Here’s the debug output, in the file.
It kept coming up with “Execution of transcode failed”
I’m also getting this error sometimes…
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
I’m not going to respond to this unless you PROMISE to stop attaching files to postings in this forum unless specifically asked to do so by Admin.
This isn’t the first (or second) time I’ve had to tell you this pooky.
Put any text output IN the posting, not as an attachment … attachments take up space on Mad Penguins servers, but are not searchable by either search engines or future forum users.
Anything that needs “attaching” (archives, pics, etc.) should be hosted elsewhere and a link provided … but text should be inline (in the posting).
Your attachment has been deleted in line with forum policy.
This is to go with post #5
Part #1
[spoiler]Devices
ATAPI iHAS122 E 2L04 (/dev/sr0, CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL) [DVD-ROM, DVD-R Sequential, DVD-R Dual Layer Sequential, DVD-R Dual Layer Jump, DVD-RAM, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW] [SAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite, Layer Jump] [%7]
System
K3b Version: 2.0.2
KDE Version: 4.14.13
QT Version: 4.8.6
Kernel: 3.19.0-56-generic
Used versions
transcode: 1.1.7
transcode
transcode v1.1.7 (C) 2001-2003 Thomas Oestreich, 2003-2010 Transcode Team
[e[34;1mdvd_reader.ce[0m] DVD title 1/14: 1 chapter(s), 1 angle(s), title set 1
[e[34;1mdvd_reader.ce[0m] title playback time: 00:00:01.03 2 sec
[transcode] V: auto-probing | /dev/sr0 (OK)
[transcode] V: import format | MPEG 2 program stream in DVD PAL (module=dvd)
[transcode] A: auto-probing | /dev/sr0 (OK)
[transcode] A: import format | AC3 in DVD PAL (module=dvd)
[transcode] V: AV demux/sync | (1) sync AV at initial MPEG sequence
[transcode] V: import frame | 720x576 1.25:1 encoded @ 16:9
[transcode] V: clip frame (<-) | 720x576
[transcode] V: zoom | 1024x576 1.78:1 (Lanczos3)
[transcode] V: bits/pixel | 0.081 (low)
[transcode] V: decoding fps,frc | 25.000,3
[transcode] V: multi-pass | (mode=1) writing data (pass 1) to /tmp/kde-pooky2483/k3b_0.log
[transcode] V: video format | YUV420 (4:2:0) aka I420
[transcode] A: import format | 0x2000 AC3 [48000,16,2]
[transcode] A: export | disabled
[transcode] V: encoding fps,frc | 25.000,3
[transcode] A: language | en
[transcode] A: bytes per frame | 7680 (7680.000000)
[transcode] A: adjustment | 0@1000
[transcode] V: IA32/AMD64 accel | sse4a sse3 sse2 sse 3dnowext 3dnow mmxext mmx cmove asm
[transcode] V: video buffer | 10 @ 1024x576 [0x2]
[transcode] A: audio buffer | 10 @ 48000x2x16
[import_dvd.so] v0.4.1 (2007-07-15) (video) DVD | (audio) MPEG/AC3/PCM
[export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null
[export_ffmpeg.so] v0.3.18 (2008-11-29) (video) Lavc54.35.0 | (audio) MPEG/AC3/PCM
[import_dvd.so] tccat -T 1,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 1,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[import_dvd.so] delaying DVD access by 3 seconds
[import_dvd.so] waiting…
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a long time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000015d
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00003116
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00003273
libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x000033f5
libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00003552
libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x0004054b
libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000406a8
libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00040827
libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00040984
libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00040b03
libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00040c60
libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x0005b680
libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00069686
libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x000697e3
libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00075cc2
libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0008162e
libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0034a10b
libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0034a268
libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0035c6d9
libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0035c836
libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x0036bb9c
libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x0036bdde
libdvdread: Found 11 VTS’s
=== last message repeated 2 times. ===
[export_ffmpeg.so] Using FFMPEG codec ‘mpeg4’ (FourCC ‘DIVX’, MPEG4 compliant video).
[export_ffmpeg.so] No profile selected
[export_ffmpeg.so] Error opening configuration file ./ffmpeg.cfg: No such file or directory
[export_ffmpeg.so] Starting 1 thread(s)
[export_ffmpeg.so] Set display aspect ratio to input
[mpeg4 @ 0xbf8ea0] removing common factors from framerate
[e[34;1mdecode_mpeg2.ce[0m] libmpeg2 acceleration: 3dnow
encoding=1 frame=1 first=0 last=-1 fps=39.322 done=-1.000000 timestamp=0.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2 first=0 last=-1 fps=66.050 done=-1.000000 timestamp=0.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3 first=0 last=-1 fps=76.375 done=-1.000000 timestamp=0.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4 first=0 last=-1 fps=84.032 done=-1.000000 timestamp=0.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5 first=0 last=-1 fps=86.810 done=-1.000000 timestamp=0.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6 first=0 last=-1 fps=83.833 done=-1.000000 timestamp=0.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7 first=0 last=-1 fps=83.025 done=-1.000000 timestamp=0.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8 first=0 last=-1 fps=84.158 done=-1.000000 timestamp=0.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9 first=0 last=-1 fps=82.852 done=-1.000000 timestamp=0.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10 first=0 last=-1 fps=86.113 done=-1.000000 timestamp=0.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11 first=0 last=-1 fps=85.750 done=-1.000000 timestamp=0.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12 first=0 last=-1 fps=88.710 done=-1.000000 timestamp=0.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13 first=0 last=-1 fps=89.023 done=-1.000000 timestamp=0.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14 first=0 last=-1 fps=89.994 done=-1.000000 timestamp=0.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15 first=0 last=-1 fps=90.579 done=-1.000000 timestamp=0.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16 first=0 last=-1 fps=91.346 done=-1.000000 timestamp=0.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17 first=0 last=-1 fps=91.521 done=-1.000000 timestamp=0.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18 first=0 last=-1 fps=92.205 done=-1.000000 timestamp=0.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19 first=0 last=-1 fps=89.599 done=-1.000000 timestamp=0.760 timeleft=-1 decodebuf=1 filterbuf=9 encodebuf=10
encoding=1 frame=20 first=0 last=-1 fps=89.562 done=-1.000000 timestamp=0.800 timeleft=-1 decodebuf=3 filterbuf=7 encodebuf=10
encoding=1 frame=21 first=0 last=-1 fps=92.030 done=-1.000000 timestamp=0.840 timeleft=-1 decodebuf=5 filterbuf=7 encodebuf=8
encoding=1 frame=22 first=0 last=-1 fps=90.932 done=-1.000000 timestamp=0.880 timeleft=-1 decodebuf=7 filterbuf=6 encodebuf=7
encoding=1 frame=23 first=0 last=-1 fps=91.069 done=-1.000000 timestamp=0.920 timeleft=-1 decodebuf=9 filterbuf=5 encodebuf=6
encoding=1 frame=24 first=0 last=-1 fps=91.239 done=-1.000000 timestamp=0.960 timeleft=-1 decodebuf=11 filterbuf=4 encodebuf=5
encoding=1 frame=25 first=0 last=-1 fps=91.598 done=-1.000000 timestamp=1.000 timeleft=-1 decodebuf=13 filterbuf=3 encodebuf=4
encoding=1 frame=26 first=0 last=-1 fps=89.678 done=-1.000000 timestamp=1.040 timeleft=-1 decodebuf=15 filterbuf=2 encodebuf=3
*** Error in `/usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007f38e9539e7a ***
[e[34;1mdvd_reader.ce[0m] DVD title 2/14: 2 chapter(s), 1 angle(s), title set 2
[e[34;1mdvd_reader.ce[0m] title playback time: 00:14:14.11 855 sec
[import_dvd.so] tccat -T 2,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 2,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[mpeg4 @ 0x926ea0] removing common factors from framerate
encoding=1 frame=142 first=0 last=-1 fps=86.364 done=-1.000000 timestamp=5.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=284 first=0 last=-1 fps=80.906 done=-1.000000 timestamp=11.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=426 first=0 last=-1 fps=84.855 done=-1.000000 timestamp=17.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=568 first=0 last=-1 fps=74.458 done=-1.000000 timestamp=22.720 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=710 first=0 last=-1 fps=76.332 done=-1.000000 timestamp=28.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=852 first=0 last=-1 fps=77.016 done=-1.000000 timestamp=34.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=994 first=0 last=-1 fps=75.825 done=-1.000000 timestamp=39.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1136 first=0 last=-1 fps=73.797 done=-1.000000 timestamp=45.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1278 first=0 last=-1 fps=72.222 done=-1.000000 timestamp=51.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1420 first=0 last=-1 fps=71.059 done=-1.000000 timestamp=56.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1562 first=0 last=-1 fps=71.961 done=-1.000000 timestamp=62.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1704 first=0 last=-1 fps=73.361 done=-1.000000 timestamp=68.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1846 first=0 last=-1 fps=74.162 done=-1.000000 timestamp=73.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1988 first=0 last=-1 fps=75.219 done=-1.000000 timestamp=79.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2130 first=0 last=-1 fps=76.070 done=-1.000000 timestamp=85.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2272 first=0 last=-1 fps=77.003 done=-1.000000 timestamp=90.880 timeleft=-1 decodebuf=2 filterbuf=8 encodebuf=10
encoding=1 frame=2414 first=0 last=-1 fps=77.866 done=-1.000000 timestamp=96.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2556 first=0 last=-1 fps=78.491 done=-1.000000 timestamp=102.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2698 first=0 last=-1 fps=79.033 done=-1.000000 timestamp=107.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2840 first=0 last=-1 fps=79.701 done=-1.000000 timestamp=113.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2982 first=0 last=-1 fps=80.267 done=-1.000000 timestamp=119.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3124 first=0 last=-1 fps=80.641 done=-1.000000 timestamp=124.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3266 first=0 last=-1 fps=80.819 done=-1.000000 timestamp=130.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3408 first=0 last=-1 fps=81.114 done=-1.000000 timestamp=136.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3550 first=0 last=-1 fps=81.416 done=-1.000000 timestamp=142.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3692 first=0 last=-1 fps=81.800 done=-1.000000 timestamp=147.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3834 first=0 last=-1 fps=82.139 done=-1.000000 timestamp=153.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3976 first=0 last=-1 fps=82.489 done=-1.000000 timestamp=159.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4118 first=0 last=-1 fps=82.712 done=-1.000000 timestamp=164.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4260 first=0 last=-1 fps=83.022 done=-1.000000 timestamp=170.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4402 first=0 last=-1 fps=83.254 done=-1.000000 timestamp=176.080 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=4544 first=0 last=-1 fps=83.465 done=-1.000000 timestamp=181.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4686 first=0 last=-1 fps=83.520 done=-1.000000 timestamp=187.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4828 first=0 last=-1 fps=83.687 done=-1.000000 timestamp=193.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4970 first=0 last=-1 fps=83.806 done=-1.000000 timestamp=198.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5112 first=0 last=-1 fps=83.779 done=-1.000000 timestamp=204.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5254 first=0 last=-1 fps=83.922 done=-1.000000 timestamp=210.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5396 first=0 last=-1 fps=84.016 done=-1.000000 timestamp=215.840 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=5538 first=0 last=-1 fps=84.216 done=-1.000000 timestamp=221.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5680 first=0 last=-1 fps=84.330 done=-1.000000 timestamp=227.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5822 first=0 last=-1 fps=84.422 done=-1.000000 timestamp=232.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5964 first=0 last=-1 fps=84.563 done=-1.000000 timestamp=238.560 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=6106 first=0 last=-1 fps=84.721 done=-1.000000 timestamp=244.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6248 first=0 last=-1 fps=84.915 done=-1.000000 timestamp=249.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6390 first=0 last=-1 fps=85.060 done=-1.000000 timestamp=255.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6532 first=0 last=-1 fps=85.170 done=-1.000000 timestamp=261.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6674 first=0 last=-1 fps=85.276 done=-1.000000 timestamp=266.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6816 first=0 last=-1 fps=85.359 done=-1.000000 timestamp=272.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6958 first=0 last=-1 fps=85.384 done=-1.000000 timestamp=278.320 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=7100 first=0 last=-1 fps=85.508 done=-1.000000 timestamp=284.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=7242 first=0 last=-1 fps=85.597 done=-1.000000 timestamp=289.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7384 first=0 last=-1 fps=85.701 done=-1.000000 timestamp=295.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7526 first=0 last=-1 fps=85.768 done=-1.000000 timestamp=301.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7668 first=0 last=-1 fps=85.821 done=-1.000000 timestamp=306.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7810 first=0 last=-1 fps=85.835 done=-1.000000 timestamp=312.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7952 first=0 last=-1 fps=85.885 done=-1.000000 timestamp=318.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8094 first=0 last=-1 fps=85.885 done=-1.000000 timestamp=323.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8236 first=0 last=-1 fps=85.898 done=-1.000000 timestamp=329.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8378 first=0 last=-1 fps=85.854 done=-1.000000 timestamp=335.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8520 first=0 last=-1 fps=85.825 done=-1.000000 timestamp=340.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8662 first=0 last=-1 fps=85.879 done=-1.000000 timestamp=346.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8804 first=0 last=-1 fps=85.929 done=-1.000000 timestamp=352.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8946 first=0 last=-1 fps=86.010 done=-1.000000 timestamp=357.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9088 first=0 last=-1 fps=86.086 done=-1.000000 timestamp=363.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9230 first=0 last=-1 fps=86.122 done=-1.000000 timestamp=369.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9372 first=0 last=-1 fps=86.147 done=-1.000000 timestamp=374.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9514 first=0 last=-1 fps=86.189 done=-1.000000 timestamp=380.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9656 first=0 last=-1 fps=86.190 done=-1.000000 timestamp=386.240 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=9798 first=0 last=-1 fps=86.271 done=-1.000000 timestamp=391.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9940 first=0 last=-1 fps=86.323 done=-1.000000 timestamp=397.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10082 first=0 last=-1 fps=86.345 done=-1.000000 timestamp=403.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10224 first=0 last=-1 fps=86.383 done=-1.000000 timestamp=408.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10366 first=0 last=-1 fps=86.444 done=-1.000000 timestamp=414.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10508 first=0 last=-1 fps=86.373 done=-1.000000 timestamp=420.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10650 first=0 last=-1 fps=86.266 done=-1.000000 timestamp=426.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=10792 first=0 last=-1 fps=86.329 done=-1.000000 timestamp=431.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10934 first=0 last=-1 fps=86.371 done=-1.000000 timestamp=437.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11076 first=0 last=-1 fps=86.311 done=-1.000000 timestamp=443.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11218 first=0 last=-1 fps=86.357 done=-1.000000 timestamp=448.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11360 first=0 last=-1 fps=86.391 done=-1.000000 timestamp=454.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11502 first=0 last=-1 fps=86.451 done=-1.000000 timestamp=460.080 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=11644 first=0 last=-1 fps=86.498 done=-1.000000 timestamp=465.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11786 first=0 last=-1 fps=86.546 done=-1.000000 timestamp=471.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11928 first=0 last=-1 fps=86.606 done=-1.000000 timestamp=477.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12070 first=0 last=-1 fps=86.602 done=-1.000000 timestamp=482.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12212 first=0 last=-1 fps=86.636 done=-1.000000 timestamp=488.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12354 first=0 last=-1 fps=86.665 done=-1.000000 timestamp=494.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12496 first=0 last=-1 fps=86.749 done=-1.000000 timestamp=499.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12638 first=0 last=-1 fps=86.807 done=-1.000000 timestamp=505.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12780 first=0 last=-1 fps=86.869 done=-1.000000 timestamp=511.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12922 first=0 last=-1 fps=86.922 done=-1.000000 timestamp=516.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13064 first=0 last=-1 fps=86.990 done=-1.000000 timestamp=522.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13206 first=0 last=-1 fps=87.020 done=-1.000000 timestamp=528.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13348 first=0 last=-1 fps=87.045 done=-1.000000 timestamp=533.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13490 first=0 last=-1 fps=87.072 done=-1.000000 timestamp=539.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13632 first=0 last=-1 fps=87.148 done=-1.000000 timestamp=545.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13774 first=0 last=-1 fps=87.157 done=-1.000000 timestamp=550.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13916 first=0 last=-1 fps=87.185 done=-1.000000 timestamp=556.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14058 first=0 last=-1 fps=87.191 done=-1.000000 timestamp=562.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14200 first=0 last=-1 fps=87.168 done=-1.000000 timestamp=568.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14342 first=0 last=-1 fps=87.201 done=-1.000000 timestamp=573.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14484 first=0 last=-1 fps=87.240 done=-1.000000 timestamp=579.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14626 first=0 last=-1 fps=87.262 done=-1.000000 timestamp=585.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14768 first=0 last=-1 fps=87.207 done=-1.000000 timestamp=590.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14910 first=0 last=-1 fps=87.236 done=-1.000000 timestamp=596.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15052 first=0 last=-1 fps=87.211 done=-1.000000 timestamp=602.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15194 first=0 last=-1 fps=87.226 done=-1.000000 timestamp=607.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15336 first=0 last=-1 fps=87.237 done=-1.000000 timestamp=613.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15478 first=0 last=-1 fps=87.277 done=-1.000000 timestamp=619.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15620 first=0 last=-1 fps=87.277 done=-1.000000 timestamp=624.800 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=15762 first=0 last=-1 fps=87.279 done=-1.000000 timestamp=630.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15904 first=0 last=-1 fps=87.298 done=-1.000000 timestamp=636.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16046 first=0 last=-1 fps=87.248 done=-1.000000 timestamp=641.840 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=16188 first=0 last=-1 fps=87.255 done=-1.000000 timestamp=647.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16330 first=0 last=-1 fps=87.297 done=-1.000000 timestamp=653.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16472 first=0 last=-1 fps=87.302 done=-1.000000 timestamp=658.880 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=16614 first=0 last=-1 fps=87.308 done=-1.000000 timestamp=664.560 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=16756 first=0 last=-1 fps=87.342 done=-1.000000 timestamp=670.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16898 first=0 last=-1 fps=87.360 done=-1.000000 timestamp=675.920 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=17040 first=0 last=-1 fps=87.360 done=-1.000000 timestamp=681.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17182 first=0 last=-1 fps=87.367 done=-1.000000 timestamp=687.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17324 first=0 last=-1 fps=87.422 done=-1.000000 timestamp=692.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17466 first=0 last=-1 fps=87.416 done=-1.000000 timestamp=698.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17608 first=0 last=-1 fps=87.436 done=-1.000000 timestamp=704.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17750 first=0 last=-1 fps=87.441 done=-1.000000 timestamp=710.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17892 first=0 last=-1 fps=87.421 done=-1.000000 timestamp=715.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18034 first=0 last=-1 fps=87.440 done=-1.000000 timestamp=721.360 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=18176 first=0 last=-1 fps=87.431 done=-1.000000 timestamp=727.040 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=18318 first=0 last=-1 fps=87.426 done=-1.000000 timestamp=732.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18460 first=0 last=-1 fps=87.416 done=-1.000000 timestamp=738.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18602 first=0 last=-1 fps=87.392 done=-1.000000 timestamp=744.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18744 first=0 last=-1 fps=87.396 done=-1.000000 timestamp=749.760 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=18886 first=0 last=-1 fps=87.418 done=-1.000000 timestamp=755.440 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=19028 first=0 last=-1 fps=87.450 done=-1.000000 timestamp=761.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19170 first=0 last=-1 fps=87.440 done=-1.000000 timestamp=766.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19312 first=0 last=-1 fps=87.473 done=-1.000000 timestamp=772.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19454 first=0 last=-1 fps=87.442 done=-1.000000 timestamp=778.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19596 first=0 last=-1 fps=87.428 done=-1.000000 timestamp=783.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19738 first=0 last=-1 fps=87.439 done=-1.000000 timestamp=789.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19880 first=0 last=-1 fps=87.441 done=-1.000000 timestamp=795.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
[/spoiler]
Part #2
encoding=1 frame=20022 first=0 last=-1 fps=87.450 done=-1.000000 timestamp=800.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20164 first=0 last=-1 fps=87.475 done=-1.000000 timestamp=806.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20306 first=0 last=-1 fps=87.489 done=-1.000000 timestamp=812.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20448 first=0 last=-1 fps=87.467 done=-1.000000 timestamp=817.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20590 first=0 last=-1 fps=87.503 done=-1.000000 timestamp=823.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20732 first=0 last=-1 fps=87.519 done=-1.000000 timestamp=829.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20874 first=0 last=-1 fps=87.549 done=-1.000000 timestamp=834.960 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=21016 first=0 last=-1 fps=87.568 done=-1.000000 timestamp=840.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=21158 first=0 last=-1 fps=87.582 done=-1.000000 timestamp=846.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=21300 first=0 last=-1 fps=87.625 done=-1.000000 timestamp=852.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
*** Error in /usr/bin/transcode': munmap_chunk(): invalid pointer: 0x00007fa3aa9e4e7a *** transcode v1.1.7 (C) 2001-2003 Thomas Oestreich, 2003-2010 Transcode Team [e[34;1mdvd_reader.ce[0m] DVD title 3/14: 1 chapter(s), 1 angle(s), title set 3 [e[34;1mdvd_reader.ce[0m] title playback time: 00:00:01.03 2 sec [e[34;1mdvd_reader.ce[0m] DVD title 3/14: 1 chapter(s), 1 angle(s), title set 3 [e[34;1mdvd_reader.ce[0m] title playback time: 00:00:01.03 2 sec [transcode] V: auto-probing | /dev/sr0 (OK) [transcode] V: import format | MPEG 2 program stream in DVD PAL (module=dvd) [transcode] A: auto-probing | /dev/sr0 (OK) [transcode] A: import format | AC3 in DVD PAL (module=dvd) [transcode] V: AV demux/sync | (1) sync AV at initial MPEG sequence [transcode] V: import frame | 720x576 1.25:1 encoded @ 16:9 [transcode] V: clip frame (<-) | 720x576 [transcode] V: zoom | 1024x576 1.78:1 (Lanczos3) [transcode] V: bits/pixel | 0.081 (low) [transcode] V: decoding fps,frc | 25.000,3 [transcode] V: multi-pass | (mode=1) writing data (pass 1) to /tmp/kde-pooky2483/k3b_0.log [transcode] V: video format | YUV420 (4:2:0) aka I420 [transcode] A: import format | 0x2000 AC3 [48000,16,2] [transcode] A: export | disabled [transcode] V: encoding fps,frc | 25.000,3 [transcode] A: language | en [transcode] A: bytes per frame | 7680 (7680.000000) [transcode] A: adjustment | 0@1000 [transcode] V: IA32/AMD64 accel | sse4a sse3 sse2 sse 3dnowext 3dnow mmxext mmx cmove asm [transcode] V: video buffer | 10 @ 1024x576 [0x2] [transcode] A: audio buffer | 10 @ 48000x2x16 [import_dvd.so] v0.4.1 (2007-07-15) (video) DVD | (audio) MPEG/AC3/PCM [export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null [export_ffmpeg.so] v0.3.18 (2008-11-29) (video) Lavc54.35.0 | (audio) MPEG/AC3/PCM [import_dvd.so] tccat -T 3,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0 [import_dvd.so] tccat -T 3,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p [import_dvd.so] delaying DVD access by 3 seconds [import_dvd.so] waiting... libdvdread: Attempting to retrieve all CSS keys libdvdread: This can take a _long_ time, please be patient libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000015d libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00003116 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00003273 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x000033f5 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00003552 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x0004054b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000406a8 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00040827 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00040984 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00040b03 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00040c60 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x0005b680 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00069686 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x000697e3 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00075cc2 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0008162e libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0034a10b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0034a268 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0035c6d9 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0035c836 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x0036bb9c libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x0036bdde libdvdread: Elapsed time 0 libdvdread: Found 11 VTS's libdvdread: Elapsed time 0 [import_dvd.so] waiting... === last message repeated 2 times. === [export_ffmpeg.so] Using FFMPEG codec 'mpeg4' (FourCC 'DIVX', MPEG4 compliant video). [export_ffmpeg.so] No profile selected [export_ffmpeg.so] Error opening configuration file ./ffmpeg.cfg: No such file or directory [export_ffmpeg.so] Starting 1 thread(s) [export_ffmpeg.so] Set display aspect ratio to input [mpeg4 @ 0x1235ea0] removing common factors from framerate [e[34;1mdecode_mpeg2.ce[0m] libmpeg2 acceleration: 3dnow libdvdread: Attempting to retrieve all CSS keys libdvdread: This can take a _long_ time, please be patient libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000015d libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00003116 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00003273 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x000033f5 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00003552 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x0004054b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000406a8 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00040827 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00040984 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00040b03 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00040c60 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x0005b680 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00069686 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x000697e3 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00075cc2 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0008162e libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0034a10b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0034a268 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0035c6d9 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0035c836 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x0036bb9c libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x0036bdde libdvdread: Elapsed time 0 libdvdread: Found 11 VTS's libdvdread: Elapsed time 0 encoding=1 frame=1 first=0 last=-1 fps=84.939 done=-1.000000 timestamp=0.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2 first=0 last=-1 fps=82.805 done=-1.000000 timestamp=0.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3 first=0 last=-1 fps=70.691 done=-1.000000 timestamp=0.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=4 first=0 last=-1 fps=80.927 done=-1.000000 timestamp=0.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=5 first=0 last=-1 fps=87.756 done=-1.000000 timestamp=0.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=6 first=0 last=-1 fps=84.371 done=-1.000000 timestamp=0.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=7 first=0 last=-1 fps=83.477 done=-1.000000 timestamp=0.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=8 first=0 last=-1 fps=83.583 done=-1.000000 timestamp=0.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=9 first=0 last=-1 fps=83.487 done=-1.000000 timestamp=0.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=10 first=0 last=-1 fps=80.866 done=-1.000000 timestamp=0.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=11 first=0 last=-1 fps=78.648 done=-1.000000 timestamp=0.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=12 first=0 last=-1 fps=79.202 done=-1.000000 timestamp=0.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=13 first=0 last=-1 fps=80.666 done=-1.000000 timestamp=0.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=14 first=0 last=-1 fps=81.471 done=-1.000000 timestamp=0.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=15 first=0 last=-1 fps=73.279 done=-1.000000 timestamp=0.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=16 first=0 last=-1 fps=76.502 done=-1.000000 timestamp=0.640 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=17 first=0 last=-1 fps=79.522 done=-1.000000 timestamp=0.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=18 first=0 last=-1 fps=80.577 done=-1.000000 timestamp=0.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=19 first=0 last=-1 fps=80.614 done=-1.000000 timestamp=0.760 timeleft=-1 decodebuf=1 filterbuf=9 encodebuf=10 encoding=1 frame=20 first=0 last=-1 fps=80.730 done=-1.000000 timestamp=0.800 timeleft=-1 decodebuf=3 filterbuf=8 encodebuf=9 encoding=1 frame=21 first=0 last=-1 fps=79.601 done=-1.000000 timestamp=0.840 timeleft=-1 decodebuf=5 filterbuf=7 encodebuf=8 encoding=1 frame=22 first=0 last=-1 fps=78.673 done=-1.000000 timestamp=0.880 timeleft=-1 decodebuf=7 filterbuf=6 encodebuf=7 encoding=1 frame=23 first=0 last=-1 fps=78.653 done=-1.000000 timestamp=0.920 timeleft=-1 decodebuf=9 filterbuf=5 encodebuf=6 encoding=1 frame=24 first=0 last=-1 fps=79.511 done=-1.000000 timestamp=0.960 timeleft=-1 decodebuf=11 filterbuf=4 encodebuf=5 encoding=1 frame=25 first=0 last=-1 fps=80.135 done=-1.000000 timestamp=1.000 timeleft=-1 decodebuf=13 filterbuf=3 encodebuf=4 encoding=1 frame=26 first=0 last=-1 fps=80.818 done=-1.000000 timestamp=1.040 timeleft=-1 decodebuf=15 filterbuf=2 encodebuf=3 *** Error in /usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007f367fd7de7a ***
[e[34;1mdvd_reader.ce[0m] DVD title 4/14: 1 chapter(s), 1 angle(s), title set 4
[import_dvd.so] tccat -T 4,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 4,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[mpeg4 @ 0x1ed1ea0] removing common factors from framerate
encoding=1 frame=1 first=0 last=-1 fps=101.297 done=-1.000000 timestamp=0.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2 first=0 last=-1 fps=102.521 done=-1.000000 timestamp=0.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3 first=0 last=-1 fps=103.008 done=-1.000000 timestamp=0.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4 first=0 last=-1 fps=79.500 done=-1.000000 timestamp=0.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5 first=0 last=-1 fps=77.824 done=-1.000000 timestamp=0.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6 first=0 last=-1 fps=80.337 done=-1.000000 timestamp=0.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=7 first=0 last=-1 fps=81.805 done=-1.000000 timestamp=0.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8 first=0 last=-1 fps=76.744 done=-1.000000 timestamp=0.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9 first=0 last=-1 fps=78.705 done=-1.000000 timestamp=0.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10 first=0 last=-1 fps=80.736 done=-1.000000 timestamp=0.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=11 first=0 last=-1 fps=82.267 done=-1.000000 timestamp=0.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12 first=0 last=-1 fps=81.524 done=-1.000000 timestamp=0.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13 first=0 last=-1 fps=82.710 done=-1.000000 timestamp=0.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14 first=0 last=-1 fps=83.715 done=-1.000000 timestamp=0.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=15 first=0 last=-1 fps=84.635 done=-1.000000 timestamp=0.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=16 first=0 last=-1 fps=84.621 done=-1.000000 timestamp=0.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17 first=0 last=-1 fps=85.053 done=-1.000000 timestamp=0.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18 first=0 last=-1 fps=86.791 done=-1.000000 timestamp=0.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=19 first=0 last=-1 fps=85.005 done=-1.000000 timestamp=0.760 timeleft=-1 decodebuf=1 filterbuf=9 encodebuf=10
encoding=1 frame=20 first=0 last=-1 fps=87.843 done=-1.000000 timestamp=0.800 timeleft=-1 decodebuf=3 filterbuf=8 encodebuf=9
encoding=1 frame=21 first=0 last=-1 fps=87.747 done=-1.000000 timestamp=0.840 timeleft=-1 decodebuf=5 filterbuf=7 encodebuf=8
encoding=1 frame=22 first=0 last=-1 fps=87.133 done=-1.000000 timestamp=0.880 timeleft=-1 decodebuf=7 filterbuf=6 encodebuf=7
encoding=1 frame=23 first=0 last=-1 fps=87.592 done=-1.000000 timestamp=0.920 timeleft=-1 decodebuf=9 filterbuf=5 encodebuf=6
encoding=1 frame=24 first=0 last=-1 fps=88.407 done=-1.000000 timestamp=0.960 timeleft=-1 decodebuf=11 filterbuf=4 encodebuf=5
encoding=1 frame=25 first=0 last=-1 fps=89.049 done=-1.000000 timestamp=1.000 timeleft=-1 decodebuf=13 filterbuf=3 encodebuf=4
encoding=1 frame=26 first=0 last=-1 fps=89.272 done=-1.000000 timestamp=1.040 timeleft=-1 decodebuf=15 filterbuf=2 encodebuf=3
*** Error in `/usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007facc126de7a ***
[e[34;1mdvd_reader.ce[0m] DVD title 5/14: 3 chapter(s), 1 angle(s), title set 5
[e[34;1mdvd_reader.ce[0m] title playback time: 00:04:34.19 275 sec
[import_dvd.so] tccat -T 5,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 5,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[mpeg4 @ 0x70bea0] removing common factors from framerate
Part #3
encoding=1 frame=45 first=0 last=-1 fps=93.700 done=-1.000000 timestamp=1.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=90 first=0 last=-1 fps=91.518 done=-1.000000 timestamp=3.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=135 first=0 last=-1 fps=91.499 done=-1.000000 timestamp=5.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=180 first=0 last=-1 fps=90.076 done=-1.000000 timestamp=7.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=225 first=0 last=-1 fps=90.166 done=-1.000000 timestamp=9.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=270 first=0 last=-1 fps=90.533 done=-1.000000 timestamp=10.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=315 first=0 last=-1 fps=90.993 done=-1.000000 timestamp=12.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=360 first=0 last=-1 fps=91.376 done=-1.000000 timestamp=14.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=405 first=0 last=-1 fps=91.143 done=-1.000000 timestamp=16.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=450 first=0 last=-1 fps=90.827 done=-1.000000 timestamp=18.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=495 first=0 last=-1 fps=91.069 done=-1.000000 timestamp=19.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=540 first=0 last=-1 fps=90.933 done=-1.000000 timestamp=21.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=585 first=0 last=-1 fps=90.800 done=-1.000000 timestamp=23.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=630 first=0 last=-1 fps=90.870 done=-1.000000 timestamp=25.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=675 first=0 last=-1 fps=90.538 done=-1.000000 timestamp=27.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=720 first=0 last=-1 fps=89.719 done=-1.000000 timestamp=28.800 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14
encoding=1 frame=765 first=0 last=-1 fps=89.481 done=-1.000000 timestamp=30.600 timeleft=-1 decodebuf=6 filterbuf=3 encodebuf=11
encoding=1 frame=810 first=0 last=-1 fps=84.593 done=-1.000000 timestamp=32.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=855 first=0 last=-1 fps=82.477 done=-1.000000 timestamp=34.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=900 first=0 last=-1 fps=82.221 done=-1.000000 timestamp=36.000 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=945 first=0 last=-1 fps=82.325 done=-1.000000 timestamp=37.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=990 first=0 last=-1 fps=82.241 done=-1.000000 timestamp=39.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1035 first=0 last=-1 fps=82.100 done=-1.000000 timestamp=41.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1080 first=0 last=-1 fps=81.268 done=-1.000000 timestamp=43.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1125 first=0 last=-1 fps=81.288 done=-1.000000 timestamp=45.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1170 first=0 last=-1 fps=79.818 done=-1.000000 timestamp=46.800 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=1215 first=0 last=-1 fps=78.802 done=-1.000000 timestamp=48.600 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=1260 first=0 last=-1 fps=78.958 done=-1.000000 timestamp=50.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1305 first=0 last=-1 fps=79.324 done=-1.000000 timestamp=52.200 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=1350 first=0 last=-1 fps=79.704 done=-1.000000 timestamp=54.000 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=1395 first=0 last=-1 fps=79.831 done=-1.000000 timestamp=55.800 timeleft=-1 decodebuf=4 filterbuf=5 encodebuf=11
encoding=1 frame=1440 first=0 last=-1 fps=79.652 done=-1.000000 timestamp=57.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1485 first=0 last=-1 fps=79.453 done=-1.000000 timestamp=59.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1530 first=0 last=-1 fps=79.552 done=-1.000000 timestamp=61.200 timeleft=-1 decodebuf=2 filterbuf=5 encodebuf=13
encoding=1 frame=1575 first=0 last=-1 fps=79.560 done=-1.000000 timestamp=63.000 timeleft=-1 decodebuf=0 filterbuf=1 encodebuf=19
encoding=1 frame=1620 first=0 last=-1 fps=79.765 done=-1.000000 timestamp=64.800 timeleft=-1 decodebuf=0 filterbuf=5 encodebuf=15
encoding=1 frame=1665 first=0 last=-1 fps=80.002 done=-1.000000 timestamp=66.600 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=1710 first=0 last=-1 fps=80.241 done=-1.000000 timestamp=68.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1755 first=0 last=-1 fps=80.241 done=-1.000000 timestamp=70.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1800 first=0 last=-1 fps=80.185 done=-1.000000 timestamp=72.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1845 first=0 last=-1 fps=80.233 done=-1.000000 timestamp=73.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1890 first=0 last=-1 fps=80.112 done=-1.000000 timestamp=75.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1935 first=0 last=-1 fps=80.189 done=-1.000000 timestamp=77.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1980 first=0 last=-1 fps=79.619 done=-1.000000 timestamp=79.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2025 first=0 last=-1 fps=79.653 done=-1.000000 timestamp=81.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2070 first=0 last=-1 fps=79.563 done=-1.000000 timestamp=82.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2115 first=0 last=-1 fps=79.646 done=-1.000000 timestamp=84.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2160 first=0 last=-1 fps=79.551 done=-1.000000 timestamp=86.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2205 first=0 last=-1 fps=78.953 done=-1.000000 timestamp=88.200 timeleft=-1 decodebuf=3 filterbuf=6 encodebuf=11
encoding=1 frame=2250 first=0 last=-1 fps=78.460 done=-1.000000 timestamp=90.000 timeleft=-1 decodebuf=1 filterbuf=3 encodebuf=16
encoding=1 frame=2295 first=0 last=-1 fps=78.101 done=-1.000000 timestamp=91.800 timeleft=-1 decodebuf=8 filterbuf=1 encodebuf=11
encoding=1 frame=2340 first=0 last=-1 fps=77.640 done=-1.000000 timestamp=93.600 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=2385 first=0 last=-1 fps=77.470 done=-1.000000 timestamp=95.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2430 first=0 last=-1 fps=77.408 done=-1.000000 timestamp=97.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2475 first=0 last=-1 fps=76.745 done=-1.000000 timestamp=99.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2520 first=0 last=-1 fps=76.329 done=-1.000000 timestamp=100.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2565 first=0 last=-1 fps=76.518 done=-1.000000 timestamp=102.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2610 first=0 last=-1 fps=76.463 done=-1.000000 timestamp=104.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2655 first=0 last=-1 fps=76.525 done=-1.000000 timestamp=106.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2700 first=0 last=-1 fps=76.735 done=-1.000000 timestamp=108.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2745 first=0 last=-1 fps=76.772 done=-1.000000 timestamp=109.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2790 first=0 last=-1 fps=76.874 done=-1.000000 timestamp=111.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2835 first=0 last=-1 fps=76.961 done=-1.000000 timestamp=113.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2880 first=0 last=-1 fps=77.087 done=-1.000000 timestamp=115.200 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=2925 first=0 last=-1 fps=77.283 done=-1.000000 timestamp=117.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2970 first=0 last=-1 fps=77.419 done=-1.000000 timestamp=118.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3015 first=0 last=-1 fps=77.614 done=-1.000000 timestamp=120.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3060 first=0 last=-1 fps=77.744 done=-1.000000 timestamp=122.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3105 first=0 last=-1 fps=77.858 done=-1.000000 timestamp=124.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3150 first=0 last=-1 fps=77.800 done=-1.000000 timestamp=126.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3195 first=0 last=-1 fps=77.894 done=-1.000000 timestamp=127.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3240 first=0 last=-1 fps=78.005 done=-1.000000 timestamp=129.600 timeleft=-1 decodebuf=4 filterbuf=5 encodebuf=11
encoding=1 frame=3285 first=0 last=-1 fps=78.076 done=-1.000000 timestamp=131.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3330 first=0 last=-1 fps=78.223 done=-1.000000 timestamp=133.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3375 first=0 last=-1 fps=78.386 done=-1.000000 timestamp=135.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3420 first=0 last=-1 fps=78.434 done=-1.000000 timestamp=136.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3465 first=0 last=-1 fps=78.481 done=-1.000000 timestamp=138.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3510 first=0 last=-1 fps=78.634 done=-1.000000 timestamp=140.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3555 first=0 last=-1 fps=78.701 done=-1.000000 timestamp=142.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3600 first=0 last=-1 fps=78.758 done=-1.000000 timestamp=144.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3645 first=0 last=-1 fps=78.758 done=-1.000000 timestamp=145.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=3690 first=0 last=-1 fps=78.864 done=-1.000000 timestamp=147.600 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=3735 first=0 last=-1 fps=78.998 done=-1.000000 timestamp=149.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3780 first=0 last=-1 fps=79.062 done=-1.000000 timestamp=151.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3825 first=0 last=-1 fps=79.126 done=-1.000000 timestamp=153.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3870 first=0 last=-1 fps=79.252 done=-1.000000 timestamp=154.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3915 first=0 last=-1 fps=79.342 done=-1.000000 timestamp=156.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3960 first=0 last=-1 fps=79.411 done=-1.000000 timestamp=158.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4005 first=0 last=-1 fps=79.485 done=-1.000000 timestamp=160.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4050 first=0 last=-1 fps=79.494 done=-1.000000 timestamp=162.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4095 first=0 last=-1 fps=79.547 done=-1.000000 timestamp=163.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4140 first=0 last=-1 fps=79.646 done=-1.000000 timestamp=165.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4185 first=0 last=-1 fps=79.757 done=-1.000000 timestamp=167.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4230 first=0 last=-1 fps=79.804 done=-1.000000 timestamp=169.200 timeleft=-1 decodebuf=1 filterbuf=7 encodebuf=12
encoding=1 frame=4275 first=0 last=-1 fps=79.872 done=-1.000000 timestamp=171.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4320 first=0 last=-1 fps=79.897 done=-1.000000 timestamp=172.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4365 first=0 last=-1 fps=80.034 done=-1.000000 timestamp=174.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4410 first=0 last=-1 fps=79.946 done=-1.000000 timestamp=176.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=4455 first=0 last=-1 fps=79.730 done=-1.000000 timestamp=178.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4500 first=0 last=-1 fps=79.837 done=-1.000000 timestamp=180.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4545 first=0 last=-1 fps=79.951 done=-1.000000 timestamp=181.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4590 first=0 last=-1 fps=80.024 done=-1.000000 timestamp=183.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4635 first=0 last=-1 fps=80.134 done=-1.000000 timestamp=185.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4680 first=0 last=-1 fps=80.267 done=-1.000000 timestamp=187.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4725 first=0 last=-1 fps=80.388 done=-1.000000 timestamp=189.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=4770 first=0 last=-1 fps=80.480 done=-1.000000 timestamp=190.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4815 first=0 last=-1 fps=80.596 done=-1.000000 timestamp=192.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4860 first=0 last=-1 fps=80.642 done=-1.000000 timestamp=194.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4905 first=0 last=-1 fps=80.748 done=-1.000000 timestamp=196.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4950 first=0 last=-1 fps=80.824 done=-1.000000 timestamp=198.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=4995 first=0 last=-1 fps=80.889 done=-1.000000 timestamp=199.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5040 first=0 last=-1 fps=80.990 done=-1.000000 timestamp=201.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5085 first=0 last=-1 fps=81.069 done=-1.000000 timestamp=203.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5130 first=0 last=-1 fps=81.116 done=-1.000000 timestamp=205.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=5175 first=0 last=-1 fps=81.212 done=-1.000000 timestamp=207.000 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=5220 first=0 last=-1 fps=81.258 done=-1.000000 timestamp=208.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=5265 first=0 last=-1 fps=81.363 done=-1.000000 timestamp=210.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5310 first=0 last=-1 fps=81.436 done=-1.000000 timestamp=212.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5355 first=0 last=-1 fps=81.533 done=-1.000000 timestamp=214.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5400 first=0 last=-1 fps=81.571 done=-1.000000 timestamp=216.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5445 first=0 last=-1 fps=81.660 done=-1.000000 timestamp=217.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5490 first=0 last=-1 fps=81.719 done=-1.000000 timestamp=219.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5535 first=0 last=-1 fps=81.815 done=-1.000000 timestamp=221.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5580 first=0 last=-1 fps=81.909 done=-1.000000 timestamp=223.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5625 first=0 last=-1 fps=81.992 done=-1.000000 timestamp=225.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5670 first=0 last=-1 fps=82.032 done=-1.000000 timestamp=226.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5715 first=0 last=-1 fps=82.044 done=-1.000000 timestamp=228.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5760 first=0 last=-1 fps=82.077 done=-1.000000 timestamp=230.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5805 first=0 last=-1 fps=82.148 done=-1.000000 timestamp=232.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5850 first=0 last=-1 fps=82.214 done=-1.000000 timestamp=234.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5895 first=0 last=-1 fps=82.225 done=-1.000000 timestamp=235.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5940 first=0 last=-1 fps=82.262 done=-1.000000 timestamp=237.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5985 first=0 last=-1 fps=82.262 done=-1.000000 timestamp=239.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6030 first=0 last=-1 fps=82.289 done=-1.000000 timestamp=241.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6075 first=0 last=-1 fps=82.321 done=-1.000000 timestamp=243.000 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=6120 first=0 last=-1 fps=82.387 done=-1.000000 timestamp=244.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6165 first=0 last=-1 fps=82.444 done=-1.000000 timestamp=246.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6210 first=0 last=-1 fps=82.500 done=-1.000000 timestamp=248.400 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=6255 first=0 last=-1 fps=82.486 done=-1.000000 timestamp=250.200 timeleft=-1 decodebuf=2 filterbuf=7 encodebuf=11
encoding=1 frame=6300 first=0 last=-1 fps=82.483 done=-1.000000 timestamp=252.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6345 first=0 last=-1 fps=82.507 done=-1.000000 timestamp=253.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6390 first=0 last=-1 fps=82.580 done=-1.000000 timestamp=255.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6435 first=0 last=-1 fps=82.609 done=-1.000000 timestamp=257.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6480 first=0 last=-1 fps=82.560 done=-1.000000 timestamp=259.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6525 first=0 last=-1 fps=82.584 done=-1.000000 timestamp=261.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6570 first=0 last=-1 fps=82.604 done=-1.000000 timestamp=262.800 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=6615 first=0 last=-1 fps=82.625 done=-1.000000 timestamp=264.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6660 first=0 last=-1 fps=82.574 done=-1.000000 timestamp=266.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6705 first=0 last=-1 fps=82.512 done=-1.000000 timestamp=268.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6750 first=0 last=-1 fps=82.542 done=-1.000000 timestamp=270.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6795 first=0 last=-1 fps=82.553 done=-1.000000 timestamp=271.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6840 first=0 last=-1 fps=82.597 done=-1.000000 timestamp=273.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
*** Error in `/usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007f21d72aae7a ***
[e[34;1mdvd_reader.ce[0m] DVD title 6/14: 2 chapter(s), 1 angle(s), title set 6
[e[34;1mdvd_reader.ce[0m] title playback time: 00:02:24.12 145 sec
[import_dvd.so] tccat -T 6,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 6,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
[import_dvd.so] waiting…
libdvdread: This can take a long time, please be patient
[mpeg4 @ 0x18b0ea0] removing common factors from framerate
encoding=1 frame=24 first=0 last=-1 fps=86.839 done=-1.000000 timestamp=0.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=48 first=0 last=-1 fps=84.548 done=-1.000000 timestamp=1.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=72 first=0 last=-1 fps=82.702 done=-1.000000 timestamp=2.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=96 first=0 last=-1 fps=76.355 done=-1.000000 timestamp=3.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=120 first=0 last=-1 fps=74.605 done=-1.000000 timestamp=4.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=144 first=0 last=-1 fps=72.727 done=-1.000000 timestamp=5.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=168 first=0 last=-1 fps=73.989 done=-1.000000 timestamp=6.720 timeleft=-1 decodebuf=2 filterbuf=7 encodebuf=11
encoding=1 frame=192 first=0 last=-1 fps=71.824 done=-1.000000 timestamp=7.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=216 first=0 last=-1 fps=71.401 done=-1.000000 timestamp=8.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=240 first=0 last=-1 fps=72.432 done=-1.000000 timestamp=9.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=264 first=0 last=-1 fps=73.161 done=-1.000000 timestamp=10.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=288 first=0 last=-1 fps=72.320 done=-1.000000 timestamp=11.520 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=312 first=0 last=-1 fps=71.598 done=-1.000000 timestamp=12.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=336 first=0 last=-1 fps=72.178 done=-1.000000 timestamp=13.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=360 first=0 last=-1 fps=71.190 done=-1.000000 timestamp=14.400 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=384 first=0 last=-1 fps=71.868 done=-1.000000 timestamp=15.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=408 first=0 last=-1 fps=72.524 done=-1.000000 timestamp=16.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=432 first=0 last=-1 fps=71.967 done=-1.000000 timestamp=17.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=456 first=0 last=-1 fps=72.545 done=-1.000000 timestamp=18.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=480 first=0 last=-1 fps=72.844 done=-1.000000 timestamp=19.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=504 first=0 last=-1 fps=73.455 done=-1.000000 timestamp=20.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=528 first=0 last=-1 fps=74.127 done=-1.000000 timestamp=21.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=552 first=0 last=-1 fps=74.557 done=-1.000000 timestamp=22.080 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=576 first=0 last=-1 fps=75.144 done=-1.000000 timestamp=23.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=600 first=0 last=-1 fps=75.711 done=-1.000000 timestamp=24.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=624 first=0 last=-1 fps=76.303 done=-1.000000 timestamp=24.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=648 first=0 last=-1 fps=76.482 done=-1.000000 timestamp=25.920 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=672 first=0 last=-1 fps=76.287 done=-1.000000 timestamp=26.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=696 first=0 last=-1 fps=76.627 done=-1.000000 timestamp=27.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=720 first=0 last=-1 fps=76.810 done=-1.000000 timestamp=28.800 timeleft=-1 decodebuf=1 filterbuf=6 encodebuf=13
encoding=1 frame=744 first=0 last=-1 fps=77.289 done=-1.000000 timestamp=29.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=768 first=0 last=-1 fps=76.769 done=-1.000000 timestamp=30.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=792 first=0 last=-1 fps=76.795 done=-1.000000 timestamp=31.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=816 first=0 last=-1 fps=76.651 done=-1.000000 timestamp=32.640 timeleft=-1 decodebuf=1 filterbuf=7 encodebuf=12
encoding=1 frame=840 first=0 last=-1 fps=76.784 done=-1.000000 timestamp=33.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=864 first=0 last=-1 fps=77.209 done=-1.000000 timestamp=34.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=888 first=0 last=-1 fps=77.536 done=-1.000000 timestamp=35.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=912 first=0 last=-1 fps=77.905 done=-1.000000 timestamp=36.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=936 first=0 last=-1 fps=77.907 done=-1.000000 timestamp=37.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=960 first=0 last=-1 fps=78.156 done=-1.000000 timestamp=38.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=984 first=0 last=-1 fps=78.421 done=-1.000000 timestamp=39.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1008 first=0 last=-1 fps=78.716 done=-1.000000 timestamp=40.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1032 first=0 last=-1 fps=78.820 done=-1.000000 timestamp=41.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1056 first=0 last=-1 fps=79.060 done=-1.000000 timestamp=42.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1080 first=0 last=-1 fps=79.106 done=-1.000000 timestamp=43.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1104 first=0 last=-1 fps=79.418 done=-1.000000 timestamp=44.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1128 first=0 last=-1 fps=79.647 done=-1.000000 timestamp=45.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1152 first=0 last=-1 fps=79.974 done=-1.000000 timestamp=46.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1176 first=0 last=-1 fps=80.229 done=-1.000000 timestamp=47.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1200 first=0 last=-1 fps=80.387 done=-1.000000 timestamp=48.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1224 first=0 last=-1 fps=80.561 done=-1.000000 timestamp=48.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1248 first=0 last=-1 fps=80.674 done=-1.000000 timestamp=49.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1272 first=0 last=-1 fps=80.874 done=-1.000000 timestamp=50.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1296 first=0 last=-1 fps=80.956 done=-1.000000 timestamp=51.840 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1320 first=0 last=-1 fps=81.195 done=-1.000000 timestamp=52.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1344 first=0 last=-1 fps=81.356 done=-1.000000 timestamp=53.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1368 first=0 last=-1 fps=81.565 done=-1.000000 timestamp=54.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1392 first=0 last=-1 fps=81.630 done=-1.000000 timestamp=55.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1416 first=0 last=-1 fps=81.821 done=-1.000000 timestamp=56.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1440 first=0 last=-1 fps=81.954 done=-1.000000 timestamp=57.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1464 first=0 last=-1 fps=82.067 done=-1.000000 timestamp=58.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1488 first=0 last=-1 fps=82.168 done=-1.000000 timestamp=59.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1512 first=0 last=-1 fps=82.330 done=-1.000000 timestamp=60.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1536 first=0 last=-1 fps=82.443 done=-1.000000 timestamp=61.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1560 first=0 last=-1 fps=82.566 done=-1.000000 timestamp=62.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1584 first=0 last=-1 fps=82.596 done=-1.000000 timestamp=63.360 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=1608 first=0 last=-1 fps=82.756 done=-1.000000 timestamp=64.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1632 first=0 last=-1 fps=82.905 done=-1.000000 timestamp=65.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1656 first=0 last=-1 fps=82.853 done=-1.000000 timestamp=66.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1680 first=0 last=-1 fps=83.000 done=-1.000000 timestamp=67.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1704 first=0 last=-1 fps=83.129 done=-1.000000 timestamp=68.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1728 first=0 last=-1 fps=83.280 done=-1.000000 timestamp=69.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1752 first=0 last=-1 fps=82.752 done=-1.000000 timestamp=70.080 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=1776 first=0 last=-1 fps=82.164 done=-1.000000 timestamp=71.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1800 first=0 last=-1 fps=82.018 done=-1.000000 timestamp=72.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1824 first=0 last=-1 fps=82.090 done=-1.000000 timestamp=72.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1848 first=0 last=-1 fps=82.111 done=-1.000000 timestamp=73.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1872 first=0 last=-1 fps=82.255 done=-1.000000 timestamp=74.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1896 first=0 last=-1 fps=82.405 done=-1.000000 timestamp=75.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1920 first=0 last=-1 fps=82.531 done=-1.000000 timestamp=76.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1944 first=0 last=-1 fps=82.688 done=-1.000000 timestamp=77.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1968 first=0 last=-1 fps=82.789 done=-1.000000 timestamp=78.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=1992 first=0 last=-1 fps=82.864 done=-1.000000 timestamp=79.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2016 first=0 last=-1 fps=82.993 done=-1.000000 timestamp=80.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2040 first=0 last=-1 fps=82.997 done=-1.000000 timestamp=81.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2064 first=0 last=-1 fps=83.084 done=-1.000000 timestamp=82.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2088 first=0 last=-1 fps=83.044 done=-1.000000 timestamp=83.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2112 first=0 last=-1 fps=83.109 done=-1.000000 timestamp=84.480 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2136 first=0 last=-1 fps=83.213 done=-1.000000 timestamp=85.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2160 first=0 last=-1 fps=83.285 done=-1.000000 timestamp=86.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2184 first=0 last=-1 fps=83.293 done=-1.000000 timestamp=87.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2208 first=0 last=-1 fps=83.191 done=-1.000000 timestamp=88.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2232 first=0 last=-1 fps=83.198 done=-1.000000 timestamp=89.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2256 first=0 last=-1 fps=83.229 done=-1.000000 timestamp=90.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2280 first=0 last=-1 fps=83.142 done=-1.000000 timestamp=91.200 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2304 first=0 last=-1 fps=83.161 done=-1.000000 timestamp=92.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2328 first=0 last=-1 fps=82.760 done=-1.000000 timestamp=93.120 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2352 first=0 last=-1 fps=82.650 done=-1.000000 timestamp=94.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2376 first=0 last=-1 fps=82.636 done=-1.000000 timestamp=95.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2400 first=0 last=-1 fps=82.598 done=-1.000000 timestamp=96.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2424 first=0 last=-1 fps=82.636 done=-1.000000 timestamp=96.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2448 first=0 last=-1 fps=82.677 done=-1.000000 timestamp=97.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2472 first=0 last=-1 fps=82.708 done=-1.000000 timestamp=98.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2496 first=0 last=-1 fps=82.755 done=-1.000000 timestamp=99.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2520 first=0 last=-1 fps=82.814 done=-1.000000 timestamp=100.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2544 first=0 last=-1 fps=82.911 done=-1.000000 timestamp=101.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2568 first=0 last=-1 fps=82.842 done=-1.000000 timestamp=102.720 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=2592 first=0 last=-1 fps=82.927 done=-1.000000 timestamp=103.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2616 first=0 last=-1 fps=82.975 done=-1.000000 timestamp=104.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2640 first=0 last=-1 fps=83.068 done=-1.000000 timestamp=105.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2664 first=0 last=-1 fps=83.147 done=-1.000000 timestamp=106.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2688 first=0 last=-1 fps=83.251 done=-1.000000 timestamp=107.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2712 first=0 last=-1 fps=83.298 done=-1.000000 timestamp=108.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2736 first=0 last=-1 fps=83.372 done=-1.000000 timestamp=109.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2760 first=0 last=-1 fps=83.421 done=-1.000000 timestamp=110.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2784 first=0 last=-1 fps=83.442 done=-1.000000 timestamp=111.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2808 first=0 last=-1 fps=83.501 done=-1.000000 timestamp=112.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2832 first=0 last=-1 fps=83.586 done=-1.000000 timestamp=113.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2856 first=0 last=-1 fps=83.620 done=-1.000000 timestamp=114.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2880 first=0 last=-1 fps=83.630 done=-1.000000 timestamp=115.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2904 first=0 last=-1 fps=83.680 done=-1.000000 timestamp=116.160 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12
encoding=1 frame=2928 first=0 last=-1 fps=83.694 done=-1.000000 timestamp=117.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2952 first=0 last=-1 fps=83.693 done=-1.000000 timestamp=118.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2976 first=0 last=-1 fps=83.696 done=-1.000000 timestamp=119.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3000 first=0 last=-1 fps=83.762 done=-1.000000 timestamp=120.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3024 first=0 last=-1 fps=83.820 done=-1.000000 timestamp=120.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3048 first=0 last=-1 fps=83.858 done=-1.000000 timestamp=121.920 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=3072 first=0 last=-1 fps=83.924 done=-1.000000 timestamp=122.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3096 first=0 last=-1 fps=83.832 done=-1.000000 timestamp=123.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3120 first=0 last=-1 fps=83.857 done=-1.000000 timestamp=124.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3144 first=0 last=-1 fps=83.946 done=-1.000000 timestamp=125.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3168 first=0 last=-1 fps=83.984 done=-1.000000 timestamp=126.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3192 first=0 last=-1 fps=84.054 done=-1.000000 timestamp=127.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3216 first=0 last=-1 fps=84.089 done=-1.000000 timestamp=128.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3240 first=0 last=-1 fps=84.127 done=-1.000000 timestamp=129.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3264 first=0 last=-1 fps=84.199 done=-1.000000 timestamp=130.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3288 first=0 last=-1 fps=84.199 done=-1.000000 timestamp=131.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3312 first=0 last=-1 fps=84.250 done=-1.000000 timestamp=132.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3336 first=0 last=-1 fps=84.248 done=-1.000000 timestamp=133.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3360 first=0 last=-1 fps=84.276 done=-1.000000 timestamp=134.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3384 first=0 last=-1 fps=84.298 done=-1.000000 timestamp=135.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3408 first=0 last=-1 fps=84.284 done=-1.000000 timestamp=136.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3432 first=0 last=-1 fps=84.275 done=-1.000000 timestamp=137.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3456 first=0 last=-1 fps=84.264 done=-1.000000 timestamp=138.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3480 first=0 last=-1 fps=84.329 done=-1.000000 timestamp=139.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3504 first=0 last=-1 fps=84.379 done=-1.000000 timestamp=140.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3528 first=0 last=-1 fps=84.370 done=-1.000000 timestamp=141.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3552 first=0 last=-1 fps=84.381 done=-1.000000 timestamp=142.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3576 first=0 last=-1 fps=84.328 done=-1.000000 timestamp=143.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=3600 first=0 last=-1 fps=84.382 done=-1.000000 timestamp=144.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
Part#4
*** Error in /usr/bin/transcode': munmap_chunk(): invalid pointer: 0x00007f8a4ff83e7a *** transcode v1.1.7 (C) 2001-2003 Thomas Oestreich, 2003-2010 Transcode Team [e[34;1mdvd_reader.ce[0m] DVD title 7/14: 2 chapter(s), 1 angle(s), title set 7 [e[34;1mdvd_reader.ce[0m] title playback time: 00:02:10.24 131 sec [e[34;1mdvd_reader.ce[0m] DVD title 7/14: 2 chapter(s), 1 angle(s), title set 7 [e[34;1mdvd_reader.ce[0m] title playback time: 00:02:10.24 131 sec [transcode] V: auto-probing | /dev/sr0 (OK) [transcode] V: import format | MPEG 2 program stream in DVD PAL (module=dvd) [transcode] A: auto-probing | /dev/sr0 (OK) [transcode] A: import format | AC3 in DVD PAL (module=dvd) [transcode] V: AV demux/sync | (1) sync AV at initial MPEG sequence [transcode] V: import frame | 720x576 1.25:1 encoded @ 16:9 [transcode] V: clip frame (<-) | 720x576 [transcode] V: zoom | 1024x576 1.78:1 (Lanczos3) [transcode] V: bits/pixel | 0.081 (low) [transcode] V: decoding fps,frc | 25.000,3 [transcode] V: multi-pass | (mode=1) writing data (pass 1) to /tmp/kde-pooky2483/k3b_0.log [transcode] V: video format | YUV420 (4:2:0) aka I420 [transcode] A: import format | 0x2000 AC3 [48000,16,2] [transcode] A: export | disabled [transcode] V: encoding fps,frc | 25.000,3 [transcode] A: language | en [transcode] A: bytes per frame | 7680 (7680.000000) [transcode] A: adjustment | 0@1000 [transcode] V: IA32/AMD64 accel | sse4a sse3 sse2 sse 3dnowext 3dnow mmxext mmx cmove asm [transcode] V: video buffer | 10 @ 1024x576 [0x2] [transcode] A: audio buffer | 10 @ 48000x2x16 [import_dvd.so] v0.4.1 (2007-07-15) (video) DVD | (audio) MPEG/AC3/PCM [export_null.so] v0.1.2 (2001-08-17) (video) null | (audio) null [export_ffmpeg.so] v0.3.18 (2008-11-29) (video) Lavc54.35.0 | (audio) MPEG/AC3/PCM [import_dvd.so] tccat -T 7,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0 [import_dvd.so] tccat -T 7,-1,1 -i "/dev/sr0" -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p [import_dvd.so] delaying DVD access by 3 seconds [import_dvd.so] waiting... libdvdread: Attempting to retrieve all CSS keys libdvdread: This can take a _long_ time, please be patient libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000015d libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00003116 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00003273 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x000033f5 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00003552 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x0004054b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000406a8 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00040827 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00040984 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00040b03 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00040c60 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x0005b680 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00069686 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x000697e3 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00075cc2 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0008162e libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0034a10b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0034a268 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0035c6d9 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0035c836 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x0036bb9c libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x0036bdde libdvdread: Elapsed time 0 libdvdread: Found 11 VTS's libdvdread: Elapsed time 0 [import_dvd.so] waiting... === last message repeated 2 times. === [export_ffmpeg.so] Using FFMPEG codec 'mpeg4' (FourCC 'DIVX', MPEG4 compliant video). [export_ffmpeg.so] No profile selected [export_ffmpeg.so] Error opening configuration file ./ffmpeg.cfg: No such file or directory [export_ffmpeg.so] Starting 1 thread(s) [export_ffmpeg.so] Set display aspect ratio to input [mpeg4 @ 0x263dea0] removing common factors from framerate [e[34;1mdecode_mpeg2.ce[0m] libmpeg2 acceleration: 3dnow libdvdread: Attempting to retrieve all CSS keys libdvdread: This can take a _long_ time, please be patient libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000015d libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x00003116 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x00003273 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_0.VOB at 0x000033f5 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_02_1.VOB at 0x00003552 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_0.VOB at 0x0004054b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_03_1.VOB at 0x000406a8 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_0.VOB at 0x00040827 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_04_1.VOB at 0x00040984 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_0.VOB at 0x00040b03 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_05_1.VOB at 0x00040c60 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_06_1.VOB at 0x0005b680 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_0.VOB at 0x00069686 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_07_1.VOB at 0x000697e3 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_0.VOB at 0x00075cc2 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_08_1.VOB at 0x0008162e libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_0.VOB at 0x0034a10b libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_09_1.VOB at 0x0034a268 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_0.VOB at 0x0035c6d9 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_10_1.VOB at 0x0035c836 libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_0.VOB at 0x0036bb9c libdvdread: Elapsed time 0 libdvdread: Get key for /VIDEO_TS/VTS_11_1.VOB at 0x0036bdde libdvdread: Elapsed time 0 libdvdread: Found 11 VTS's libdvdread: Elapsed time 0 encoding=1 frame=21 first=0 last=-1 fps=94.723 done=-1.000000 timestamp=0.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=42 first=0 last=-1 fps=90.992 done=-1.000000 timestamp=1.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=63 first=0 last=-1 fps=88.431 done=-1.000000 timestamp=2.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=84 first=0 last=-1 fps=88.048 done=-1.000000 timestamp=3.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=105 first=0 last=-1 fps=83.296 done=-1.000000 timestamp=4.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=126 first=0 last=-1 fps=83.076 done=-1.000000 timestamp=5.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=147 first=0 last=-1 fps=83.756 done=-1.000000 timestamp=5.880 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=168 first=0 last=-1 fps=84.824 done=-1.000000 timestamp=6.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=189 first=0 last=-1 fps=85.606 done=-1.000000 timestamp=7.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=210 first=0 last=-1 fps=86.378 done=-1.000000 timestamp=8.400 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=231 first=0 last=-1 fps=86.687 done=-1.000000 timestamp=9.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=252 first=0 last=-1 fps=86.593 done=-1.000000 timestamp=10.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=273 first=0 last=-1 fps=85.919 done=-1.000000 timestamp=10.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=294 first=0 last=-1 fps=85.800 done=-1.000000 timestamp=11.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=315 first=0 last=-1 fps=86.132 done=-1.000000 timestamp=12.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=336 first=0 last=-1 fps=85.258 done=-1.000000 timestamp=13.440 timeleft=-1 decodebuf=0 filterbuf=6 encodebuf=14 encoding=1 frame=357 first=0 last=-1 fps=86.177 done=-1.000000 timestamp=14.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=378 first=0 last=-1 fps=86.684 done=-1.000000 timestamp=15.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=399 first=0 last=-1 fps=86.572 done=-1.000000 timestamp=15.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=420 first=0 last=-1 fps=86.854 done=-1.000000 timestamp=16.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=441 first=0 last=-1 fps=86.977 done=-1.000000 timestamp=17.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=462 first=0 last=-1 fps=87.394 done=-1.000000 timestamp=18.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=483 first=0 last=-1 fps=87.526 done=-1.000000 timestamp=19.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=504 first=0 last=-1 fps=87.733 done=-1.000000 timestamp=20.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=525 first=0 last=-1 fps=87.621 done=-1.000000 timestamp=21.000 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=546 first=0 last=-1 fps=87.908 done=-1.000000 timestamp=21.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=567 first=0 last=-1 fps=88.165 done=-1.000000 timestamp=22.680 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=588 first=0 last=-1 fps=88.391 done=-1.000000 timestamp=23.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=609 first=0 last=-1 fps=88.341 done=-1.000000 timestamp=24.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=630 first=0 last=-1 fps=88.573 done=-1.000000 timestamp=25.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=651 first=0 last=-1 fps=88.829 done=-1.000000 timestamp=26.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=672 first=0 last=-1 fps=88.560 done=-1.000000 timestamp=26.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=693 first=0 last=-1 fps=88.642 done=-1.000000 timestamp=27.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=714 first=0 last=-1 fps=88.782 done=-1.000000 timestamp=28.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=735 first=0 last=-1 fps=88.895 done=-1.000000 timestamp=29.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=756 first=0 last=-1 fps=88.835 done=-1.000000 timestamp=30.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=777 first=0 last=-1 fps=89.006 done=-1.000000 timestamp=31.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=798 first=0 last=-1 fps=88.923 done=-1.000000 timestamp=31.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=819 first=0 last=-1 fps=89.054 done=-1.000000 timestamp=32.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=840 first=0 last=-1 fps=89.180 done=-1.000000 timestamp=33.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=861 first=0 last=-1 fps=89.038 done=-1.000000 timestamp=34.440 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=882 first=0 last=-1 fps=89.006 done=-1.000000 timestamp=35.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=903 first=0 last=-1 fps=89.057 done=-1.000000 timestamp=36.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=924 first=0 last=-1 fps=89.165 done=-1.000000 timestamp=36.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=945 first=0 last=-1 fps=89.195 done=-1.000000 timestamp=37.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=966 first=0 last=-1 fps=89.311 done=-1.000000 timestamp=38.640 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=987 first=0 last=-1 fps=89.200 done=-1.000000 timestamp=39.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1008 first=0 last=-1 fps=89.158 done=-1.000000 timestamp=40.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1029 first=0 last=-1 fps=88.990 done=-1.000000 timestamp=41.160 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=1050 first=0 last=-1 fps=88.667 done=-1.000000 timestamp=42.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1071 first=0 last=-1 fps=88.507 done=-1.000000 timestamp=42.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1092 first=0 last=-1 fps=88.575 done=-1.000000 timestamp=43.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1113 first=0 last=-1 fps=88.256 done=-1.000000 timestamp=44.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1134 first=0 last=-1 fps=88.222 done=-1.000000 timestamp=45.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1155 first=0 last=-1 fps=88.203 done=-1.000000 timestamp=46.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1176 first=0 last=-1 fps=88.317 done=-1.000000 timestamp=47.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1197 first=0 last=-1 fps=88.360 done=-1.000000 timestamp=47.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1218 first=0 last=-1 fps=88.483 done=-1.000000 timestamp=48.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1239 first=0 last=-1 fps=88.651 done=-1.000000 timestamp=49.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1260 first=0 last=-1 fps=88.719 done=-1.000000 timestamp=50.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1281 first=0 last=-1 fps=88.633 done=-1.000000 timestamp=51.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1302 first=0 last=-1 fps=88.679 done=-1.000000 timestamp=52.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1323 first=0 last=-1 fps=88.796 done=-1.000000 timestamp=52.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1344 first=0 last=-1 fps=88.784 done=-1.000000 timestamp=53.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1365 first=0 last=-1 fps=88.856 done=-1.000000 timestamp=54.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1386 first=0 last=-1 fps=88.908 done=-1.000000 timestamp=55.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1407 first=0 last=-1 fps=88.991 done=-1.000000 timestamp=56.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1428 first=0 last=-1 fps=88.974 done=-1.000000 timestamp=57.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1449 first=0 last=-1 fps=89.062 done=-1.000000 timestamp=57.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1470 first=0 last=-1 fps=88.996 done=-1.000000 timestamp=58.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1491 first=0 last=-1 fps=89.113 done=-1.000000 timestamp=59.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1512 first=0 last=-1 fps=89.027 done=-1.000000 timestamp=60.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1533 first=0 last=-1 fps=88.691 done=-1.000000 timestamp=61.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1554 first=0 last=-1 fps=88.603 done=-1.000000 timestamp=62.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1575 first=0 last=-1 fps=88.594 done=-1.000000 timestamp=63.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1596 first=0 last=-1 fps=88.582 done=-1.000000 timestamp=63.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1617 first=0 last=-1 fps=88.524 done=-1.000000 timestamp=64.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1638 first=0 last=-1 fps=88.618 done=-1.000000 timestamp=65.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1659 first=0 last=-1 fps=88.704 done=-1.000000 timestamp=66.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1680 first=0 last=-1 fps=88.821 done=-1.000000 timestamp=67.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1701 first=0 last=-1 fps=88.871 done=-1.000000 timestamp=68.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1722 first=0 last=-1 fps=88.920 done=-1.000000 timestamp=68.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1743 first=0 last=-1 fps=88.751 done=-1.000000 timestamp=69.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1764 first=0 last=-1 fps=88.873 done=-1.000000 timestamp=70.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1785 first=0 last=-1 fps=88.814 done=-1.000000 timestamp=71.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1806 first=0 last=-1 fps=88.910 done=-1.000000 timestamp=72.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1827 first=0 last=-1 fps=88.911 done=-1.000000 timestamp=73.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1848 first=0 last=-1 fps=88.885 done=-1.000000 timestamp=73.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1869 first=0 last=-1 fps=88.813 done=-1.000000 timestamp=74.760 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=1890 first=0 last=-1 fps=88.931 done=-1.000000 timestamp=75.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1911 first=0 last=-1 fps=88.906 done=-1.000000 timestamp=76.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1932 first=0 last=-1 fps=88.978 done=-1.000000 timestamp=77.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1953 first=0 last=-1 fps=89.024 done=-1.000000 timestamp=78.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1974 first=0 last=-1 fps=89.048 done=-1.000000 timestamp=78.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=1995 first=0 last=-1 fps=89.115 done=-1.000000 timestamp=79.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2016 first=0 last=-1 fps=89.158 done=-1.000000 timestamp=80.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2037 first=0 last=-1 fps=89.196 done=-1.000000 timestamp=81.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2058 first=0 last=-1 fps=89.174 done=-1.000000 timestamp=82.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2079 first=0 last=-1 fps=89.213 done=-1.000000 timestamp=83.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2100 first=0 last=-1 fps=89.139 done=-1.000000 timestamp=84.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2121 first=0 last=-1 fps=89.207 done=-1.000000 timestamp=84.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2142 first=0 last=-1 fps=89.225 done=-1.000000 timestamp=85.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2163 first=0 last=-1 fps=89.213 done=-1.000000 timestamp=86.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2184 first=0 last=-1 fps=89.239 done=-1.000000 timestamp=87.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2205 first=0 last=-1 fps=89.267 done=-1.000000 timestamp=88.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2226 first=0 last=-1 fps=89.256 done=-1.000000 timestamp=89.040 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=2247 first=0 last=-1 fps=89.332 done=-1.000000 timestamp=89.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2268 first=0 last=-1 fps=89.271 done=-1.000000 timestamp=90.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2289 first=0 last=-1 fps=89.225 done=-1.000000 timestamp=91.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2310 first=0 last=-1 fps=89.229 done=-1.000000 timestamp=92.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2331 first=0 last=-1 fps=89.124 done=-1.000000 timestamp=93.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2352 first=0 last=-1 fps=89.143 done=-1.000000 timestamp=94.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2373 first=0 last=-1 fps=89.143 done=-1.000000 timestamp=94.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2394 first=0 last=-1 fps=89.219 done=-1.000000 timestamp=95.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2415 first=0 last=-1 fps=89.229 done=-1.000000 timestamp=96.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2436 first=0 last=-1 fps=89.252 done=-1.000000 timestamp=97.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2457 first=0 last=-1 fps=89.213 done=-1.000000 timestamp=98.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2478 first=0 last=-1 fps=89.213 done=-1.000000 timestamp=99.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2499 first=0 last=-1 fps=89.215 done=-1.000000 timestamp=99.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2520 first=0 last=-1 fps=89.279 done=-1.000000 timestamp=100.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2541 first=0 last=-1 fps=89.257 done=-1.000000 timestamp=101.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2562 first=0 last=-1 fps=89.280 done=-1.000000 timestamp=102.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2583 first=0 last=-1 fps=89.314 done=-1.000000 timestamp=103.320 timeleft=-1 decodebuf=1 filterbuf=7 encodebuf=12 encoding=1 frame=2604 first=0 last=-1 fps=89.371 done=-1.000000 timestamp=104.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2625 first=0 last=-1 fps=89.441 done=-1.000000 timestamp=105.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2646 first=0 last=-1 fps=89.420 done=-1.000000 timestamp=105.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2667 first=0 last=-1 fps=89.450 done=-1.000000 timestamp=106.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2688 first=0 last=-1 fps=89.161 done=-1.000000 timestamp=107.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2709 first=0 last=-1 fps=89.170 done=-1.000000 timestamp=108.360 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=2730 first=0 last=-1 fps=89.236 done=-1.000000 timestamp=109.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2751 first=0 last=-1 fps=89.278 done=-1.000000 timestamp=110.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2772 first=0 last=-1 fps=89.332 done=-1.000000 timestamp=110.880 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2793 first=0 last=-1 fps=89.353 done=-1.000000 timestamp=111.720 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=2814 first=0 last=-1 fps=89.253 done=-1.000000 timestamp=112.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2835 first=0 last=-1 fps=89.264 done=-1.000000 timestamp=113.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2856 first=0 last=-1 fps=89.314 done=-1.000000 timestamp=114.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2877 first=0 last=-1 fps=89.377 done=-1.000000 timestamp=115.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2898 first=0 last=-1 fps=89.428 done=-1.000000 timestamp=115.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2919 first=0 last=-1 fps=89.267 done=-1.000000 timestamp=116.760 timeleft=-1 decodebuf=0 filterbuf=8 encodebuf=12 encoding=1 frame=2940 first=0 last=-1 fps=89.152 done=-1.000000 timestamp=117.600 timeleft=-1 decodebuf=1 filterbuf=5 encodebuf=14 encoding=1 frame=2961 first=0 last=-1 fps=89.298 done=-1.000000 timestamp=118.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=2982 first=0 last=-1 fps=89.331 done=-1.000000 timestamp=119.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3003 first=0 last=-1 fps=89.317 done=-1.000000 timestamp=120.120 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3024 first=0 last=-1 fps=89.346 done=-1.000000 timestamp=120.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3045 first=0 last=-1 fps=89.243 done=-1.000000 timestamp=121.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3066 first=0 last=-1 fps=89.288 done=-1.000000 timestamp=122.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3087 first=0 last=-1 fps=89.270 done=-1.000000 timestamp=123.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3108 first=0 last=-1 fps=89.248 done=-1.000000 timestamp=124.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3129 first=0 last=-1 fps=89.267 done=-1.000000 timestamp=125.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3150 first=0 last=-1 fps=89.298 done=-1.000000 timestamp=126.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3171 first=0 last=-1 fps=89.283 done=-1.000000 timestamp=126.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3192 first=0 last=-1 fps=89.334 done=-1.000000 timestamp=127.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3213 first=0 last=-1 fps=89.358 done=-1.000000 timestamp=128.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3234 first=0 last=-1 fps=89.404 done=-1.000000 timestamp=129.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 encoding=1 frame=3255 first=0 last=-1 fps=89.430 done=-1.000000 timestamp=130.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11 *** Error in /usr/bin/transcode’: munmap_chunk(): invalid pointer: 0x00007fe42bc9ce7a ***
[e[34;1mdvd_reader.ce[0m] DVD title 8/14: 16 chapter(s), 1 angle(s), title set 8
[e[34;1mdvd_reader.ce[0m] title playback time: 02:13:58.02 8039 sec
[import_dvd.so] tccat -T 8,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -a 0 -x ac3 -S 0 -M 1 -d 0 | tcextract -t vob -x ac3 -a 0 -d 0 | tcdecode -x ac3 -d 0 -s 1.000000,1.000000,1.000000 -A 0
[import_dvd.so] tccat -T 8,-1,1 -i “/dev/sr0” -t dvd -d 0 | tcdemux -s 0x80 -x mpeg2 -S 0 -M 1 -d 0 | tcextract -t vob -a 0 -x mpeg2 -d 0 | tcdecode -x mpeg2 -d 0 -y yuv420p
libdvdread: Found 11 VTS’s
[export_ffmpeg.so] Using FFMPEG codec ‘mpeg4’ (FourCC ‘DIVX’, MPEG4 compliant video).
[mpeg4 @ 0x1978ea0] removing common factors from framerate
encoding=1 frame=1339 first=0 last=-1 fps=94.101 done=-1.000000 timestamp=53.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=2678 first=0 last=-1 fps=90.484 done=-1.000000 timestamp=107.120 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=4017 first=0 last=-1 fps=89.628 done=-1.000000 timestamp=160.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=5356 first=0 last=-1 fps=89.896 done=-1.000000 timestamp=214.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=6695 first=0 last=-1 fps=88.643 done=-1.000000 timestamp=267.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=8034 first=0 last=-1 fps=87.753 done=-1.000000 timestamp=321.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=9373 first=0 last=-1 fps=87.234 done=-1.000000 timestamp=374.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=10712 first=0 last=-1 fps=86.877 done=-1.000000 timestamp=428.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=12051 first=0 last=-1 fps=87.026 done=-1.000000 timestamp=482.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=13390 first=0 last=-1 fps=87.011 done=-1.000000 timestamp=535.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=14729 first=0 last=-1 fps=87.260 done=-1.000000 timestamp=589.160 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
encoding=1 frame=16068 first=0 last=-1 fps=87.198 done=-1.000000 timestamp=642.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=17407 first=0 last=-1 fps=87.563 done=-1.000000 timestamp=696.280 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=18746 first=0 last=-1 fps=87.648 done=-1.000000 timestamp=749.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=20085 first=0 last=-1 fps=88.002 done=-1.000000 timestamp=803.400 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=21424 first=0 last=-1 fps=88.235 done=-1.000000 timestamp=856.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=22763 first=0 last=-1 fps=88.190 done=-1.000000 timestamp=910.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=24102 first=0 last=-1 fps=88.279 done=-1.000000 timestamp=964.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=25441 first=0 last=-1 fps=88.137 done=-1.000000 timestamp=1017.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=26780 first=0 last=-1 fps=88.208 done=-1.000000 timestamp=1071.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=28119 first=0 last=-1 fps=88.204 done=-1.000000 timestamp=1124.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=29458 first=0 last=-1 fps=88.225 done=-1.000000 timestamp=1178.320 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=30797 first=0 last=-1 fps=88.212 done=-1.000000 timestamp=1231.880 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=32136 first=0 last=-1 fps=88.203 done=-1.000000 timestamp=1285.440 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=33475 first=0 last=-1 fps=88.261 done=-1.000000 timestamp=1339.000 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=34814 first=0 last=-1 fps=88.268 done=-1.000000 timestamp=1392.560 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=36153 first=0 last=-1 fps=88.284 done=-1.000000 timestamp=1446.120 timeleft=-1 decodebuf=1 filterbuf=8 encodebuf=11
Part #5 (last)
[spoiler]encoding=1 frame=37492 first=0 last=-1 fps=88.309 done=-1.000000 timestamp=1499.680 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=38831 first=0 last=-1 fps=88.321 done=-1.000000 timestamp=1553.240 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=40170 first=0 last=-1 fps=88.395 done=-1.000000 timestamp=1606.800 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=41509 first=0 last=-1 fps=88.484 done=-1.000000 timestamp=1660.360 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=42848 first=0 last=-1 fps=88.548 done=-1.000000 timestamp=1713.920 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=44187 first=0 last=-1 fps=88.659 done=-1.000000 timestamp=1767.480 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=45526 first=0 last=-1 fps=88.722 done=-1.000000 timestamp=1821.040 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=46865 first=0 last=-1 fps=88.718 done=-1.000000 timestamp=1874.600 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=48204 first=0 last=-1 fps=88.767 done=-1.000000 timestamp=1928.160 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=49543 first=0 last=-1 fps=88.574 done=-1.000000 timestamp=1981.720 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=50882 first=0 last=-1 fps=88.540 done=-1.000000 timestamp=2035.280 timeleft=-1 decodebuf=0 filterbuf=7 encodebuf=13
encoding=1 frame=52221 first=0 last=-1 fps=88.436 done=-1.000000 timestamp=2088.840 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=53560 first=0 last=-1 fps=88.359 done=-1.000000 timestamp=2142.400 timeleft=-1 decodebuf=2 filterbuf=7 encodebuf=11
encoding=1 frame=54899 first=0 last=-1 fps=88.203 done=-1.000000 timestamp=2195.960 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=56238 first=0 last=-1 fps=88.150 done=-1.000000 timestamp=2249.520 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=57577 first=0 last=-1 fps=88.132 done=-1.000000 timestamp=2303.080 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=58916 first=0 last=-1 fps=88.064 done=-1.000000 timestamp=2356.640 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=60255 first=0 last=-1 fps=88.107 done=-1.000000 timestamp=2410.200 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
encoding=1 frame=61594 first=0 last=-1 fps=88.180 done=-1.000000 timestamp=2463.760 timeleft=-1 decodebuf=0 filterbuf=9 encodebuf=11
transcode command:
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 1 -i /dev/sr0 -x dvd -T 1,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 142 -i /dev/sr0 -x dvd -T 2,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 1 -i /dev/sr0 -x dvd -T 3,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 1 -i /dev/sr0 -x dvd -T 4,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 45 -i /dev/sr0 -x dvd -T 5,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 24 -i /dev/sr0 -x dvd -T 6,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 21 -i /dev/sr0 -x dvd -T 7,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
/usr/bin/transcode --nice 19 --log_no_color --progress_meter 2 --progress_rate 1339 -i /dev/sr0 -x dvd -T 8,-1,1 -a 0 -j 0,0,0,0 -R 1,/tmp/kde-pooky2483/k3b_0.log -y ffmpeg,null -o /dev/null -F mpeg4 -w 1200 -Z 1024x576
[/spoiler]
Seems like it’s a handbrake bug … take a look at the workaround suggested in post #5 here:
Where they guy rips the DVD to the HDD as an ISO, then uses handbrake to rip the contents of the ISO
Not ideal, but a workaround.
That’s actually what I am doing, I’m using K9Copy to rip to an .ISO so I can queue them up in Handbrake.
By installing libdvdcss on Handbrake, you can only remove the CSS encryption equipped on DVD disc, however, as for other DVD protection such as Sony ArccOS, UOPs, and Disney X-project DRM, you will fail to do the job even you have installed libdvdcss. You can have a try at MakeMKV or Free DVDAid which is clean and free and also can bypass all DVD copy protection and region.
Thanks for that, I will have a look at them, I actually think I have MakeMKV installed on my Desktop Kubuntu.
