How to call a special transparency that You see her date and tome and data?
like this in right side
& how to install & use it in linux lubuntu of desktop of LXDE?
Again something Peppermint has out of the box…
Install compton:
sudo apt-get install compton
you’ll now need to set it to autostart this command at every bootup
compton -cC
“Again something Peppermint has out of the box…”
What exactly do you mean?
What exactly does the compton? & how exactly to use it?
compton is a compositing manager … so gives you the ability to have desktop effects such as transparency and drop shadows, etc.
First install compton:
then open the autostart file for editing:
sudo leafpad /etc/xdg/lxsession/Lubuntu/autostart
add a single new line to the file that reads:
@compton -cC
SAVE the file and exit leafpad
Now log off/on (or reboot) to test it’s working
You can check it’s runnning with:
ps aux | grep [c]ompton
PeppermintOS is based on Lubuntu, but has compositing by default … no need for the user to add/configure anything.
so the name of the software in this link it’s compton?
I do not understand well the German language if it’s really German language.
No, that’s conky … but if you want transparency in conky (or anything else) you’ll also require compositing … LXDE/Lubuntu doesn’t have compositing be default (to keep it light), but it can be added with compton.
