Hi Guys
I’m trying to get steam running on Kubuntu 16.04, It installed ok from the repos via apt-get but when I click on the steam icon nothing happens, running from the terminal giver this error message
graeme@Media-Centre:~$ steam
Running Steam on ubuntu 16.04 64-bit
STEAM_RUNTIME is enabled automatically
[2016-06-10 19:47:42] Startup - updater built Apr 29 2016 22:18:33
SteamUpdateUI: An X Error occurred
X Error of failed request: BadValue (integer parameter out of range for operation)
I searched for a solution and found this page
This solution
LD_PRELOAD='/usr/$LIB/libstdc++.so.6' DISPLAY=:0 steam
worked except it wont load my steam library even though I’m logged in
Apparently this issue is caused by the open source AMD GPU drivers but I have an Nvidia Geforce card
graeme@Media-Centre:~$ sudo lshw -c display
[sudo] password for graeme:
*-display
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:20:00.0
version: a1
width: 64 bits
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
resources: irq:31 memory:f2000000-f2ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:1100(size=128) memory:f3080000-f30fffff
Any suggestions would be much appreciated
