Hi All -
Ive been gifted a Toshiba Satellite Pro M70 laptop. It’s a bit old but in good nick overall. Sadly, it will only run 32bit (not sure if there’s a way to update it to 64bit?) so I’ve installed Linux Lite to get it up and running. All seems ok at present except the dreaded wifi refuses to work!! I was hoping it would be the old Broadcom solution but not this time - the wireless card is listed as PRO/Wireless 2200BG [Calexico2] Network Connection, vendor: Intel Corporation.
A web search hasn’t provided much - I assume it’s missing drivers but I’ve not found anything that helps. Any advice would be welcome and thanks in advance!
Rich
which distro/version ?
what’s the output from
lspci -vnn | grep -i net
ifconfig
iwconfig
sudo lshw -C network
rfkill list
iwlist scan
Hi Mark - as requested
richard@richard-Satellite-Pro-M70:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="16.04.6 LTS (Xenial Xerus)"
06:01.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
Subsystem: Toshiba America Info Systems RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [1179:ff00]
06:02.0 Network controller [0280]: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection [8086:4220] (rev 05)
Subsystem: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection [8086:2741]
ifconfig
enp6s1 Link encap:Ethernet HWaddr 00:0f:b0:a7:1f:4c
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:576 errors:0 dropped:0 overruns:0 frame:0
TX packets:576 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:53723 (53.7 KB) TX bytes:53723 (53.7 KB)
wlp6s2 Link encap:Ethernet HWaddr 00:13:ce:c0:d2:a2
wlx74da38007638 Link encap:Ethernet HWaddr 74:da:38:00:76:38
inet addr:192.168.0.8 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::aca:676d:99fd:e57f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5561 errors:0 dropped:0 overruns:0 frame:0
TX packets:4350 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5632381 (5.6 MB) TX bytes:530921 (530.9 KB)
iwconfig
wlp6s2 IEEE 802.11bg ESSID:off/any
Mode:Managed Channel:0 Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power=20 dBm Sensitivity=8/0
Retry limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
wlx74da38007638 IEEE 802.11bgn ESSID:"VM132089-2G"
Mode:Managed Frequency:2.472 GHz Access Point: C0:FF:D4:18:3D:98
Bit Rate=54 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Link Quality=42/70 Signal level=-68 dBm
Tx excessive retries:0 Invalid misc:23 Missed beacon:0
enp6s1 no wireless extensions.
[sudo] password for richard:
*-network:0
product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
physical id: 1
bus info: pci@0000:06:01.0
logical name: enp6s1
version: 10
serial: 00:0f:b0:a7:1f:4c
capacity: 100Mbit/s
width: 32 bits
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
resources: irq:21 ioport:5000(size=256) memory:c8006000-c80060ff
*-network:1
product: PRO/Wireless 2200BG [Calexico2] Network Connection
physical id: 2
bus info: pci@0000:06:02.0
logical name: wlp6s2
version: 05
serial: 00:13:ce:c0:d2:a2
width: 32 bits
capabilities: pm bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ipw2200 driverversion=1.2.2kmprq firmware=ABG:9.0.5.27 (Dec 12 2007) latency=32 link=no maxlatency=24 mingnt=3 multicast=yes wireless=IEEE 802.11bg
resources: irq:22 memory:c8007000-c8007fff
*-network
physical id: 2
bus info: usb@1:5
logical name: wlx74da38007638
serial: 74:da:38:00:76:38
configuration: broadcast=yes driver=rtl8192cu driverversion=4.4.0-158-generic firmware=N/A ip=192.168.0.8 link=yes multicast=yes wireless=IEEE 802.11bgn
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
iwlist scan
wlp6s2 Scan completed :
Cell 01 - Address: 02:03:D8:0E:CB:62
ESSID:"BTWifi-with-FON"
Protocol:IEEE 802.11bg
Mode:Master
Encryption key:off
9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s; 36 Mb/s
48 Mb/s; 54 Mb/s
Quality=44/100 Signal level=-74 dBm
Extra: Last beacon: 2808ms ago
Cell 02 - Address: 00:03:D8:0E:CB:62
ESSID:"BTHub3-7CWX"
Mode:Master
Encryption key:on
48 Mb/s; 54 Mb/s
Quality=42/100 Signal level=-75 dBm
IE: WPA Version 1
Group Cipher : TKIP
Group Cipher : TKIP
Extra: Last beacon: 2816ms ago
lo Interface doesn't support scanning.
wlx74da38007638 Scan completed :
Cell 01 - Address: C0:FF:D4:18:3D:98
Channel:13
Frequency:2.472 GHz (Channel 13)
Encryption key:on
ESSID:"VM132089-2G"
Mode:Master
Extra:tsf=0000000cf0a39e16
Extra: Last beacon: 75460ms ago
IE: Unknown: 000B564D3133323038392D3247
IE: Unknown: 03010D
IE: Unknown: 0706474220010D14
IE: Unknown: 2A0104
IE: Unknown: 32043048606C
Group Cipher : CCMP
Pairwise Ciphers (1) : CCMP
enp6s1 Interface doesn't support scanning.
Hope this helps
Rich
Hi - any joy or is it a non-starter?
Well I’m a bit baffled because wireless seems to be working ???
Is your router/network named BTHub3-7CWX ?
Mark Greaves (PCNetSpec) post:5:
You and me both!! No, network is “VM132089-2G”. Clicking the icon brings up the network manager authentication box but even with the correct password, it just cycles through then returns the same box. I tried deleting all instances and starting again but no joy.
It now shows the correct network but with ‘never’ alongside it and no amount of deleting/editing will remove the ‘never’ ???
EDIT: I just realised - the ‘never’ refers to 'never been used’ not ‘never use ’… Duh!!
EDIT 2: I ‘borrowed’ a dongle from another machine and that connects up ok and an ethernet cable connection also works so why the onboard card won’t connect is a mystery…
The 2200BG is a really old wireless adapter, maybe it simply doesn’t like the wireless modes your router is using.
Maybe get one of these
http://linuxforums.org.uk/index.php?topic=13634.msg110608#msg110608
which are tiny so don’t stick out of a laptop much … they’re also pretty cheap.
Direct link
https://www.amazon.co.uk/Edimax-EW-7811Un-N150-Wireless-Adapter/dp/B003MTTJOY
Yes, I think that’s right - the adapter wasn’t designed for the modern routers. The Edimax dongle is the exact same model that I ‘borrowed’ and which works fine so I’ll go down that route rather than mess about any longer.
Thanks for the advice
Rich
