Tutorial - Installing DansGuardian Web Content Filtering in Peppermint 3
What is DansGuardian Web Content Filtering ?
OK, how to install/configure DansGuardian in Peppermint 3
First you need to install the dansguardian and squid packages … so open a terminal and run:
sudo apt-get install dansguardian squid
(don’t worry if you see a warning about dansguardian not being configured … just carry on below)
Now you need to edit the dansguardian.conf file … so back in the terminal run:
sudo gedit /etc/dansguardian/dansguardian.conf
When the file opens, look for the line that reads:-
UNCONFIGURED - Please remove this line after configuration
and comment it out, so it now reads:-
# UNCONFIGURED - Please remove this line after configuration
SAVE the file and exit gedit.
Now you need to edit squid.conf … so back in the terminal run:
sudo gedit /etc/squid3/squid.conf
Find the section that reads:-
# Squid normally listens to port 3128
http_port 3128
and add the word “transparent”, so it now reads:-
http_port 3128 transparent
Now just in case you got the error I mentioned earlier, you’re going to reinstall dansguardian and squid (this will then pick up the edited configs, and restart dansguardian) … so back in the terminal run:
sudo apt-get install --reinstall dansguardian squid
OK, now you need to add some system-wide environment variables … so back in the terminal run:
sudo gedit /etc/environment
A file should open (that probably contains a single line that starts with PATH=)
Add the following lines BELOW what’s already there (DO NOT remove what’s already there):-
http_proxy=127.0.0.1:8080/
https_proxy=127.0.0.1:8080/
ftp_proxy=127.0.0.1:8080/
no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com"
HTTP_PROXY=127.0.0.1:8080/
HTTPS_PROXY=127.0.0.1:8080/
FTP_PROXY=127.0.0.1:8080/
NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"
REBOOT.
Now fire up the Chromium web browser and try to access a websitet you wouldn’t want your kids to access.
If you use the Firefox web browser … you’ll also need to fire up Firefox, and go to:-
Edit>Preferences>Advanced>Network>Connection Settings (button)
And manually change the proxy settings to:-
HTTP proxy: 127.0.0.1 Port: 8080
and tick the “Use this proxy server for all protocols” box (as in the picture below).
Then click the “OK” button
http://linuxforums.org.uk/MGalleryItem.php?id=1574
Nice Tutorial.
I have DG up and running, no problem.
BUT
I need to form groups of users, per their IP address, and allow them Internet access, while blocking for example social_networking for IP1, but allowing it for IP2.
Any ideas how to do this?
My DG is 2.12.0.0, and I have CentOS 6U4.
I followed this tutorial exactly and it does not filter anything. I did use nano instead of gedit as i have problems with gedit but it seemed to save the setting fine. I am running mint cinammon. Any ideas?
