I’ve done that but it dosen’t seem to have gone in, I didn’t find anything that said setup but it’s not windows ?
Huh ???
That reply tells me exactly nothing :o
OK how about this
HP Linux Imaging and Printing System (ver. 3.12.2)
Dependency/Version Check Utility ver. 14.3
Copyright (c) 2011-14 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
- Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP. - Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run. - Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Saving output in log file: hp-check.log
Initializing. Please wait…
SYSTEM INFO |
Basic system information:
Linux gordon-desktop 3.2.0-26-generic-pae #41-Ubuntu SMP Thu Jun 14 16:45:14 UTC 2012 i686 i686 i386 GNU/Linux
Distribution:
ubuntu 12.04
Checking Python version…
OK, version 2.7.3 installed
Checking PyQt 4.x version…
OK, version 4.9.1 installed.
Checking for CUPS…
Status: scheduler is running
warning: Version: (cups-config) Not available. Unable to determine installed version of CUPS.)
error_log is set to level: warn
Checking for dbus/python-dbus…
dbus daemon is running.
python-dbus version: 1.0.0
RUNTIME DEPENDENCIES |
Checking for dependency: CUPS - Common Unix Printing System…
OK, found.
Checking for dependency: CUPS DDK - CUPS driver development kit…
warning: NOT FOUND! This is an OPTIONAL/RUNTIME ONLY dependency. Some HPLIP functionality may not function properly.
Checking for dependency: GhostScript - PostScript and PDF language interpreter and previewer…
OK, found.
Checking for dependency: PIL - Python Imaging Library (required for commandline scanning with hp-scan)…
OK, found.
Checking for dependency: PolicyKit - Administrative policy framework…
OK, found.
Checking for dependency: PyQt 4 DBus - DBus Support for PyQt4…
OK, found.
Checking for dependency: Python DBus - Python bindings for DBus…
OK, found.
Checking for dependency: Python libnotify - Python bindings for the libnotify Desktop notifications…
OK, found.
Checking for dependency: Python XML libraries…
OK, found.
Checking for dependency: Python 2.3 or greater - Required for fax functionality…
OK, found.
Checking for dependency: Reportlab - PDF library for Python…
OK, found.
Checking for dependency: SANE - Scanning library…
OK, found.
Checking for dependency: scanimage - Shell scanning program…
OK, found.
Checking for dependency: xsane - Graphical scanner frontend for SANE…
OK, found.
HPLIP INSTALLATION |
Currently installed HPLIP version…
HPLIP 3.12.2 currently installed in ‘/usr/share/hplip’.
Current contents of ‘/etc/hp/hplip.conf’ file:
hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.12.2
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-doc/HTML
icon=no
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv
Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=yes
foomatic-drv-install=yes
foomatic-ppd-install=yes
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.12.2
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
hpijs-only-build=no
lite-build=no
udev-acl-rules=yes
hpcups-only-build=no
hpijs-only-build=no
Current contents of ‘/var/lib/hp/hplip.state’ file:
hplip.state - HPLIP runtime persistent variables.
[plugin]
installed=0
eula=0
Current contents of ‘~/.hplip/hplip.conf’ file:
[settings]
systray_visible = 0
systray_messages = 0
[last_used]
device_uri = “hp:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT”
printer_name =
working_dir = .
[commands]
scan = /usr/bin/simple-scan %SANE_URI%
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[installation]
date_time = 14/07/12 11:29:22
version = 3.12.2
DISCOVERED USB DEVICES |
Device URI Model
hp:/usb/Deskjet_1050_J410_series HP Deskjet 1050 J410 series
INSTALLED CUPS PRINTER QUEUES |
Deskjet_1050_J410
Type: Printer
Device URI: hp:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT
PPD: /etc/cups/ppd/Deskjet_1050_J410.ppd
PPD Description: HP Deskjet 1050 j410 Series, hpcups 3.12.2
Printer status: printer Deskjet_1050_J410 is idle. enabled since Fri 13 Jul 2012 21:00:04 BST
Communication status: Good
Deskjet_1050_J410_2
Type: Printer
PPD: /etc/cups/ppd/Deskjet_1050_J410_2.ppd
PPD Description: HP Deskjet 1050 j410 Series hpijs, 3.12.2
Printer status: printer Deskjet_1050_J410_2 disabled since Sat 23 Jun 2012 23:15:42 BST Backend /usr/lib/cups/backend/hp does not exist!
Deskjet_1050_J410_3
Type: Printer
PPD: /etc/cups/ppd/Deskjet_1050_J410_3.ppd
Printer status: printer Deskjet_1050_J410_3 disabled since Mon 09 Jul 2012 20:40:48 BST Backend /usr/lib/cups/backend/hp does not exist!
DJ
Type: Printer
PPD: /etc/cups/ppd/DJ.ppd
Printer Backend /usr/lib/cups/backend/hp does not exist!2 21:36:39 BST -
HP-Deskjet-1050-J410-series
Type: Unknown
Device URI: usb://HP/Deskjet%201050%20J410%20series?serial=CN19D1N19C05QT&interface=1
PPD: /etc/cups/ppd/HP-Deskjet-1050-J410-series.ppd
Printer status: printer HP-Deskjet-1050-J410-series now printing HP-Deskjet-1050-J410-seProcessing page 1…ce Sat 14 Jul 2012 11:17:55 BST
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend to function in HPLIP.
SANE CONFIGURATION |
‘hpaio’ in ‘/etc/sane.d/dll.conf’…
‘hpaio’ in ‘/etc/sane.d/dll.d/hplip’…
OK, found. SANE backend ‘hpaio’ is properly set up.
Checking output of ‘scanimage -L’…
device `hpaio:/usb/Deskjet_1050_J410_series?serial=CN19D1N19C05QT’ is a Hewlett-Packard Deskjet_1050_J410_series all-in-one
PYTHON EXTENSIONS |
Checking ‘cupsext’ CUPS extension…
OK, found.
Checking ‘pcardext’ Photocard extension…
OK, found.
Checking ‘hpmudext’ I/O extension…
OK, found.
Checking ‘scanext’ SANE scanning extension…
OK, found.
USB I/O SETUP |
Checking for permissions of USB attached printers…
HP Device 0x8911 at 002:002:
Device node: /dev/bus/usb/002/002
Mode: 0664
getfacl: Removing leading ‘/’ from absolute path names
file: dev/bus/usb/002/002
owner: root
group: lp
user::rw-
user:gordon:rw-
group::rw-
mask::rw-
other::r–
USER GROUPS |
gordon adm lp cdrom sudo dip plugdev lpadmin sambashare
User member of group ‘lp’. Enables print/ scan/ fax.
User member of group ‘lpadmin’.
SUMMARY |
error: 2 errors and/or warnings.
Please refer to the installation instructions at:
http://hplip.sourceforge.net/install/index.html
Done.
gordon@gordon-desktop:~$
OK, everything looks good EXCEPT, you still have 5 printer queues for the HP printer … they still need to be removed through the CUPS interface:
http://localhost:631
Does the HP Toolbox now work if you run:
hp-toolbox
the hp-toolbox will work but I have to copy and paste the printer still won’t print the test page it says I’m out of paper I checked made sure it was in properly
You’ll have to start explaining things better … “I have to copy and paste the printer” … means nothing to me ??? … where/when/why ?
And you haven’t mentioned if you’ve deleted all the printer queues or not ?
You’'re not giving enough feedback from the instructions given, such as … if you’ve carried them out, any problems, any error messages, etc. … so I’m finding it hard going giving assistance … please try to be more verbose and descriptive.
the select function won’t work I have to copy and paste the command into the terminal, … and the printer still won’t work after I deleted the job list deleted the printer and re installed it, the system sees the printer though it comes up as default option, but it wont print the test page,…it says at start up there is,…“no system tray on this system,…Unable to start,exiting”
Sorry for late response I’m forgetting thing’s again
it says at start up there is,...“no system tray on this system,...Unable to start,exiting”This seems to have been solved on the Ubuntu forums: http://ubuntuforums.org/showthread.php?p=12005929
